We observed a peculiar behavior of Intel MPI with exit status emitted from STOP statement.
PROGRAM hello USE mpi IMPLICIT NONE INTEGER :: rank, size, ierror CALL MPI_INIT(ierror) CALL MPI_COMM_SIZE(MPI_COMM_WORLD, size, ierror) CALL MPI_COMM_RANK(MPI_COMM_WORLD, rank, ierror) PRINT *, 'rank', rank, ': Hello, World!' CALL MPI_FINALIZE(ierror) STOP 2 END
The exit status will be utilized for quick debugging purpose in our codes.
With Intel MPI 2019 Update 4, we received bad termination errors, for instance using 2 MPI ranks:
rank 1 : Hello, World! rank 0 : Hello, World! 2 2 =================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = RANK 0 PID 167623 RUNNING AT login03 = EXIT STATUS: 2 =================================================================================== =================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = RANK 1 PID 167624 RUNNING AT login03 = EXIT STATUS: 2 ===================================================================================
This behavior was not observed with previous versions of the library. We are not sure whether this is a bug of IMPI or an intended feature.
Ideally, we are looking for a way to suppress this bad termination error.
Please check 2019 Update 5. As far as I know this issue was fixed there.
Best regards, Anatoliy
Thanks for your reply.
We have confirmed that upgrading to Update 5 resolved this issue.
Thank you!
