This thread's initial OP appears below this Workaround Alert. Since folks afflicted by Intel's 'Linux Suspend > Dead NUC' intermittent defect can no doubt benefit most from learning how to avoid getting their NUCs bricked by it, it seems wise to present these bricking avoidance techniques at the top of this thread; and of course you're at liberty to read the whole conversation below, from which they derive.
Workaround Alert
or 'How To Avoid Getting Your NUC Bricked by Linux Suspend'
TL;DR – use wake-on-USB to wake with an input peripheral (eg: keyboard, mouse, trackpad, etc.) or wake-on-LAN from a smartphone app.
Many reports in these forums, dating back to August 2014, show that the Intel NUC is afflicted by an as yet unfixed design flaw: when run under several different distros of Linux (Ubuntu, Arch, Mint, Fedora, Debian), each use of the Linux Suspend function carries a small but real risk of initiating a NUC-bricking incident. Susceptible NUC users are those who use a short press on the Power button to wake from suspend, because the first symptoms of an impending NUC-bricking incident are as follows.
NUC-Bricking: Symptoms # 1
When Linux Suspend is used and works normally, the NUC goes into sleep mode, and the Power button LED winks amber. When the 'Linux Suspend > Dead NUC' problem occurs, these are the symptoms which afflict sleep mode:
- a short press on the Power button does not wake the NUC (as it ought to, and usually does) – the amber winking just continues; and
- a long press on the Power button does not switch the NUC off (as it ought to, and usually does) – the amber winking just continues.
See 'Bricking Avoidance Workaround' below for ways in which to successfully wake a NUC exhibiting these symptoms, rather than experience...
NUC-Bricking: Symptoms # 2
Once a NUC is in the grip of symptoms # 1, the only way to get the NUC to power off is by disconnecting the power cable. After the power cable is reconnected:
- a short press on the Power button does not switch the NUC on (as it ought to, and usually does) – the NUC is bricked; and
- a long press on the Power button does not start the NUC up in Power Button Menu mode (as it ought to, and usually does) – the NUC is bricked.
Unbricking Workaround: to get a thus bricked NUC to work again, you have to fully disassemble the NUC, disconnect and reconnect the CMOS battery from the far side of the motherboard, and reassemble the NUC. Such a drastic remedial action highlights the nature of this failure mode as a manufacturer design defect.
Two ways of avoiding the NUC-bricking consequence of symptoms # 2 are known to be effective, and both involve alternate ways of waking a sleeping NUC: by input peripheral (wake-on-USB), and by mobile device (wake-on-LAN). They both take some setting up, which is described below.
BIOS Settings for Wake-on-USB and Wake-on-LAN
On booting up your NUC, press 'F2 to Enter Setup' on your keyboard to go into Intel Visual BIOS Settings. On the Power tab (Advanced pull-down menu > Power), set your Secondary Power Settings to match those illustrated below.
Photo credit: sylvia_intel
Press 'F10 - Save and exit' (and 'Y' to confirm) to save these settings and reboot your NUC.This may well be all you need to do, so test to see if you can now wake from suspend with the USB-connected input peripheral of your choice (eg: keyboard, mouse, trackpad, etc.); if it works OK, then you should also be able to use it after a Linux shutdown to boot up your NUC.
OS Settings for Logitech Wireless Input Devices
My Logitech wireless keyboard+trackpad and wireless trackpad didn't work straight away to wake from suspend, but community assistance soon got them working flawlessly – so if you too are using Logitech wireless input devices, please see the '2. OS Settings' section of post # 39 below (" /message/362981# 362981 https://communities.intel.com/message/362981# 362981 ) for additional set up instructions.
Wake-on-LAN Apps
To boot up and wake from suspend using wake-on-LAN, you can use a smartphone/tablet app – so just search your mobile device's app store for 'wake on LAN' to acquire an appropriate app. For instance, I've tested the free 'Wake On Lan' Android app by Mike Webb, available in the Google Play store, and it works perfectly. Sim...
Hi Dalinian,
I had the identical problem on my i7 NUC as described here:
My solution was to return the poorly-designed merchandise and purchase a Linux-compatible computer from another manufacturer. Intel employees have repeatedly stated on these forums that Intel NUCs were never tested with Linux prior to launch, and Windows is the only tested/supported OS. Very disappointing, as a desire to get away from Windows is the reason many of us chose "barebones" kits.
System76 has excellent customer service and, believe me, is well aware of the NUC/Meerkat reliability issues from numerous customer complaints. I'm sure they will take good care of you.
Hi Snowpine,
Thanks for your informative reply, which I appreciate.
I'm beginning to think that the world's leading CPU manufacturer is both too incompetent to build computers that work properly with Linux Suspend [1], and too disingenuous to admit that they've completely failed to address their 12-month-old 'Linux Suspend > Dead NUC' problem.
In my unpleasant experience, the polar opposite is the case:
- in a pre-purchase question to System76, I specifically asked if there were known issues with Ubuntu Suspend on the Meerkat – having explicitly highlighed and linked to 'Linux Suspend > Dead NUC' threads here at communities.intel.com – only to be told, "Suspend works absolutely fine on our Meerkat. It's tested frequently and we haven't had any known issues from our customers"; so it seems very likely that they're perfectly happy to lie to secure a sale of a computer which, as you say, they know full well to be defective;
- System76 tech support claim that my experience is both unique, and also something that's taken them by surprise (lie # 2); in addition, they've been worse than useless in dealing with their 'Ubuntu Suspend > Dead Meerkat' problem, and equally disingenuous in failing to acknowledge that they have no way to eliminate the fault that each use of Ubuntu Suspend risks bricking their Meerkat.
~ Johnny Rotten, after the last show by the Sex Pistols
My solution was to [...] purchase a Linux-compatible computer from another manufacturer.
Please could you share which Linux-compatible computer you purchased (make, model)?
And most importantly, does it execute the Linux Suspend function flawlessly?
Q. If Intel Atom and Core CPU chips are to blame for these multiple failures to properly execute the Linux Suspend function, are all Intel-CPU-based computers to be avoided when choosing which Linux-compatible computer to purchase?
Thanks in advance,
Tim Jones
__________________________________________________________________
[1] Intel are too incompetent to build computers that work properly with Linux Suspend:
- I bought an Intel Compute Stick with Ubuntu, only to find that Intel have removed Suspend from Ubuntu's session menu, because it doesn't work at all on their Compute Stick – eg: see 'ICS with Ubuntu: Missing Suspend Function'', from 19-Jul-2015 " /message/316842# 316842 https://communities.intel.com/message/316842
- I bought a System76 Meerkat, based on their explicit assurance that "Suspend works absolutely fine on our Meerkat", only to find that they lied – and in addition that Intel have completely failed to address their underlying 'Linux Suspend > Dead NUC' problem across several NUC models, despite numerous complaints from Linux customers for at least a year – eg: see 'NUC dead after suspend mode in Ubuntu 14.10', from 23-Dec-2014 " /message/270395# 270395 https://communities.intel.com/message/270395
Uh oh, I hope I have better luck with my System76 than you did! (It is in the mail.) As you say, they have a convincing sales person who reassured me their product is stable+linux-tested and all my concerns would be no problem. Their return policy seems generous. I am guessing that your suspend problems started after the 30 days; did they not offer to extend the return period because of your extenuating circumstances??
Honestly I feel badly for vendors like System76 and others who have staked their reputation as Linux+NUC resellers only to be stuck with a shoddy product. What can System76 do about it? They don't have the resources to write a new BIOS; that's Intel's job to get it right. I would not be surprised if there's a lawsuit in the works against Intel for continuing to sell a known-defective product over 1 year after the bug was first reported.
I considered going with an AMD system and jumping off the Intel bandwagon entirely after this debacle. But I wasn't able to find any AMD computers that were comparable in terms of performance and form factor. Was strongly considering the Compulab Fit PC for a while, but the benchmarks just don't compare to the Intel-based systems. If anyone has ideas/suggestions for a fast, small-form-factor AMD computer, let me know.
Hey folks, thanks for sharing your experiences. I'm also looking to buy an Ubuntu mini PC, so the System76 Meerkat is a potental purchase candidate for me - but I also need a computer I can depend upon to sleep when I'm not using it, and wake up again reliably.
I asked a sales question over at System76 (mentioning other folks problems with NUCs bricked by Ubuntu suspend), and their answer (from System76 saleswoman Emma) - which included "The suspend issue is definitely not a concern on our current units" - led me to discover this thread. Sounds like they told snowpine and Tim the same thing - "[our] product is stable+linux-tested and all [your] concerns would be no problem", and "Suspend works absolutely fine on our Meerkat. It's tested frequently and we haven't had any known issues from our customers" respectively.
So I asked a couple of follow up questions: "which is the version of bios which addresses the suspend problem? Have System76 coded a solution to a problem that Intel themselves haven't yet solved?" They replied as follows:
"We ship with v.0350 and it works. The bios fix was implemented at the end of November and it did resolve the suspend issue. We wouldn't be selling it if it were still an issue. I spoke with tech support and they confirmed it."
@Tim: am I right in thinking you installed v.0350 in your Meerkat, and yet it still got bricked after you used Ubuntu suspend?
"Curiouser and curiouser!" cried Tim (he was so much surprised, that for the moment he quite forgot how to speak good English).
@snowpine: so it looks to me like, by "It is in the mail", you mean that you're expecting a System76 Meerkat to be delivered to you shortly – is that correct?
While it's certainly conceivable that only a subset of all NUCs and Meerkats are afflicted by the 'Linux Suspend > Dead Computer' problem (in which case I sincerely hope you luck out by receiving an unafflicted Meerkat), I'm sorry to say that you may find as how you've traded in your defective Intel NUC Kit 5i7RYH for a built-to-order and similarly afflicted NUC5i7RYH with a "76" logo etched on to its lid.
Thanks for the heads up on a non-Intel-CPUed mini PC – I agree as how the raw performance of an AMD-APU-based CompuLab fit-PC4 Pro Linux looks to be less than an Intel-Core-based system, but it still seems like it may well suit my modest needs, so it's bookmarked against the contingency of my having to return my Meerkat for a refund.
Talking of returns... I don't know if your post was influential ("Their return policy seems generous"), but System76 have sent me return shipping labels for my defective Meerkat. If it is true that only a subset of all NUCs and Meerkats are afflicted by the 'Linux Suspend > Dead Computer' problem, then I may yet end up with an unafflicted NUC5i5RYH with a "76" logo etched on to its lid - provided, that is, that System76 can appropriately redeem themselves (and here's hoping they can).
@Angela: your skepticism is well-founded – my System76 Meetkat (ie: a built-to-order Intel NUC5i5RYH) has indeed been bricked by Ubuntu Suspend while Intel BIOS v.0350 was installed.
System76 have sent me a 'meer1-0350.bio' BIOS updater file, which I'm currently stress testing – but I'm expecting 'Ubuntu Suspend > Dead Meerkat' incident # 6 within 1-4 weeks, because:
- in Intel's Power Button Menu [1], the detailed version data for System76's 'meer1-0350.bio' is IDENTICAL to Intel's v.0350 BIOS update, namely "RYBDWi35.86a.0350.2015.0812.1722";
- 'Ubuntu Suspend > Dead Meerkat' incident # 4 (on Fri 04 Dec 2015) occurred 8 days after I flashed Intel's v.0350 BIOS update to my Meerkat's firmware (on Thu 26 Nov 2015); and 'Ubuntu Suspend > Dead Meerkat' incident # 5 (on Mon 14 Dec 2015) occurred 4 days after I flashed Intel's v.0352 BIOS update to my Meerkat's firmware (on Thu 10 Dec 2015) – conclusion: Intel have failed to fix their 'Linux Suspend > Dead NUC' problem in their v.0350 and v.0352 BIOS updates;
- of their 'meer1-0350.bio' BIOS updater file, System76 told me "We have not modifies [sic] the suspending routine in the release we have." – conclusion: System76 have failed to fix their 'Ubuntu Suspend > Dead Meerkat' problem in their 'meer1-0350.bio' BIOS update;
- AFAIK, Intel themselves have made no such claim that they've fixed their 'Linux Suspend > Dead NUC' problem with any particular BIOS update – neither in this thread, nor in any of the other 'Linux Suspend > Dead NUC' threads here, nor anywhere else.
~ System76, pre-sales customer support
My experience so far flatly contradicts this claim. IF it is true that only a subset of all NUCs and Meerkats are afflicted by the 'Linux Suspend > Dead Computer' problem, you may be lucky in getting an unafflicted Meerkat (ie: YMMV) – but I'd suggest it would be wise for you to proceed with skepticism and caution.
UPDATE # 1: in post # 6 below, Intel's very own Mike C. says, "We are working on this behavior, hopefully we will have a solution soon." The implicit logical corollaries are that:
- Intel knows full well that neither their BIOS update v.0350 nor v.0352 fixes their year-long 'Linux Suspend > Dead NUC' problem; and that
- System76 are lying to potential customers, such as Angela and snowpine, for the sake of selling defective Meerkats to them, by falsely claiming that "v.0350 works. The bios fix was implemented at the end of November and it did resolve the suspend issue."
UPDATE # 2: in post # 8 below, I document for Intel how 'Ubuntu Suspend > Dead Meerkat' incident # 6 occurred today, the day after I flashed System76's 'meer1-0350.bio' BIOS updater file to my Meerkat's firmware. So we now know for sure that the System76 v.0350 BIOS Update fails to eliminate their 'Ubuntu Suspend > Dead Meerkat' defect. This sixth failure:
- validates the 4-point list above; and
- provides positive practical evidence that falsifies System76's bogus claim that "v.0350 works. The bios fix was implemented at the end of November and it did resolve the suspend issue."
[1] Intel's Power Button Menu – accessed on an Intel NUC by plugging headphones into the sound out socket of a switched-off NUC, holding the Power button down until three beeps are heard, and releasing the Power button; the Power Button Menu appears in under a minute:
Hi All,
Mike C
Since I have the very same problem with a nuc5i5RYK, I would love to see it solved very soon.
Hi All,
In an adjoining thread [1], Intel's Mike C. responded to a post I made there as follows:
"We noted some compatible issues between our NUCs and some Linux flavors. It is hard to provide support with each distro. I would appreciate if you can reply with the kernel version, BIOS version and customized settings that you are using. If you are using a customized kernel, please send a copy of it (ISO); you can send it as a private message or use dropbox or any other method."
~ Mike C., Intel technical support
@Mike: Thank you for your response, which I warmly appreciate.
While I have your attention, I'm sure as how we'd all find it valuable if you could answer this question directly:
Q. Do Intel claim to have fixed their well-known 'Linux Suspend > Dead NUC' problem with a particular Intel BIOS Update, and if so, which one?
[NOTE: Updates are in red below]
Software & Firmware Version Information for My Five Six 'Ubuntu Suspend > Dead NUC' Incidents
For all five six 'Ubuntu Suspend > Dead NUC' incidents on my Intel NUC5i5RYH (rebadged as a System76 Meerkat), the Ubuntu version and Linux kernel version have remained the same, as pre-installed by System76 at delivery on 14 Oct 2015:
• Ubuntu 15.04 'Vivid Vervet', 64-bit
• Linux 3.19.0-41-generic # 46-Ubuntu SMP Fri Dec 4 18:18:11 UTC 2015 x86_64 GNU/Linux
I've used the Ubuntu 'Software Updater' app to keep up-to-date with periodic 'Linux 3.19.0 generic' updates.
I'm not using a customised kernel. See further below for command line version info output and an 'About This Computer' screenshot.
'Ubuntu Suspend > Dead NUC' incident # 1
- Date: 26 Oct 2015
- Failed after: 12 days usage
- BIOS firmware: Intel BIOS v.0249 (as pre-installed)
- BIOS settings: default (as pre-installed)
'Ubuntu Suspend > Dead NUC' incident # 2
- Date: 31 Oct 2015
- Failed after: 5 days usage
- Date: 31 Oct 2015
Settings change: I implemented prigaux's possible software fix (source: post # 10 in " /message/309188# 309188 https://communities.intel.com/message/309188 ) as follows:
"I copied my /etc/rc.local to /etc/rc.local.original for safe keeping, and added the following to /etc/rc.local on Sat 31 Oct 2015.
# Suggested remedy to 'Ubuntu Suspend > Dead NUC' problem
Only time will tell if this solution proves to be effective."
'Ubuntu Suspend > Dead NUC' incident # 3
- Date: 24 Nov 2015
- Failed after: 24 days usage
- Settings change conclusion: prigaux's possible software fix fails to eliminate the 'Ubuntu Suspend > Dead NUC' problem
- Date: 26 Nov 2015
- BIOS Update: flashed Intel BIOS v.0350 to my NUC's firmware (source: Intel " https://downloadcenter.intel.com/product/83255/Intel-NUC-Kit-NUC5i5RYH https://downloadcenter.intel.com/product/83255/Intel-NUC-Kit-NUC5i5RYH )
'Ubuntu Suspend > Dead NUC' incident # 4
- Date: 04 Dec 2015
- Failed after: 10 days usage
- BIOS firmware: Intel BIOS v.0350 (as installed on 26 Nov 2015)
- BIOS Update conclusion: Intel BIOS v.0350 fails to eliminate the 'Ubuntu Suspend > Dead NUC' problem
- Date: 10 Dec 2015
- BIOS Update: flashed Intel BIOS v.0352 to my NUC's firmware (source: Intel " https://downloadcenter.intel.com/product/83255/Intel-NUC-Kit-NUC5i5RYH https://downloadcenter.intel.com/product/83255/Intel-NUC-Kit-NUC5i5RYH )
- BIOS Settings change: I implemented the BIOS Settings suggestions by mikec_intel (source " /message/331090# 331090 https://communities.intel.com/message/331090# 331090 ) – I found my default BIOS Settings to be as described by mikec_intel, with only one exception:
"Effective change: Devices tab > USB configuration > xHCI Mode > changed from 'Smart Auto' to 'Enabled'
'Ubuntu Suspend > Dead NUC' incident # 5
- Date: 14 Dec 2015
- BIOS firmware: Intel BIOS v.0352 (as installed on 10 Dec 2015)
- BIOS settings: as suggested by mikec_intel
- BIOS Update conclusion: Intel BIOS v.0352 fails to eliminate the 'Ubuntu Suspend > Dead NUC' problem
BIOS Settings conclusion: the BIOS Settings suggestions by mikec_intel fail to eliminate the 'Ubuntu Suspend > Dead NUC' problem
- Date: 17 Dec 2015
- BIOS Update: flashed System76 BIOS v.0350 to my NUC's firmware (source: System76 " https://www.dropbox.com/s/t68ud9lotno5c3x/meer1-0350.bio.zip?dl=0 https://www.dropbox.com/s/t68ud9lotno5c3x/meer1-0350.bio.zip?dl=0 )
UPDATE: well, that didn't take lon...
Hi all,
I just wanted to add I have the EXACT same issue with the initiator of this thread. Same Meerkat, ubuntu version, BIOS version etc. I got it end of September and ran into the suspend > brick issue about a week after that.
I did contact System76 once I did the CMOS trick (what a pain), and I also got the "This is new to us" story and I'm yet to hear anything back. What's certain here is that System 76 are indeed lying to their customers.
@Mike: I also appreciate your response and looking forward to seeing this issue fixed.
nik
Hey Tim, thanks for all the effort you're putting in to highlight and document this problem, and to help Intel find a fix for it.
Like you, I need an Ubuntu computer that I can rely upon to sleep and wake. Seems that necessarily excludes Intel NUCs just now, since so many NUC+Linux owners are reporting that Linux suspend risks bricking their NUC - and without a reset button, only fully taking the computer apart can unbrick it: that's not for me, thank you. Yet at least Intel seem to be honest enough to admit that this is an on-going problem for which they've yet to bring out a fix.
Seems like System76 aren't so trustworthy, though: with regard to their "We fixed it!" bios upgrade, their tech support is telling you "We have not modifies [sic] the suspending routine in the release we have" - so not surprisingly your Meerkat still gets bricked with it installed - while their saleswoman Emma is telling me "We do different development once we receive our products and still do not have any issues with the suspend feature since the new Bios was implemented."; and "We don't speak for Intel, so if they don't have a fix, that's on them." (wait, what?!!!). Now nikitas, another Meerkat owner, is reporting identical bricking - and in his opinion, "What's certain here is that System 76 are indeed lying to their customers." That's more than enough red flags for me - I'm out of here.
Since a System76 Meerkat is a re-badged Intel NUC, Meerkats obviously inherit the NUC's design flaws, and all the reported evidence points to neither System76 nor Intel having yet stopped the Linux suspend command from risking bricking these computers. So thank you Tim, for helping me to understand why I need to look elsewhere for a dependable Ubuntu system - and here's hoping System76 will do the right thing by you, so you get either a non-defective Meerkat or a refund.
@snowpine: hope you also get a non-defective Meerkat, too - but sorry to say that the chance of that happening doesn't look at all high right now (IMHO).
Anybody else have a suggestion for a mini PC that runs Ubuntu flawlessly, including reliable sleep/wake functionality?
Hi Folks, gotta say – it's good to know I'm not alone in suffering these tribulations.
@nikitas: thank you for letting us know that your Meerkat is also expressing the 'Ubuntu Suspend > Dead Meerkat' defect; and I'm sorry to hear that you're also having unpleasant experiences with System76. If I may, I'd like to ask you a couple questions:
Q1. On what date did you report your 'Ubuntu Suspend > Dead Meerkat' experience to System76?
Q2. What's the name of the System76 tech support person who gave you the "This is new to us" story?
@Angela.Smith: thanks for your kind appreciation, and you're welcome, citizen. Sorry to be the bearer of bad news about System76 and their defective Meerkat; and I respect your choice to shop somewhere else for a reliable Ubuntu mini PC.
Thanks too for sharing the deceptive sales pitch you were given – at best, maybe the System76 Sales Department really do believe their techs have solved the 'Ubuntu Suspend > Dead Meerkat' defect, even though their Tech Support Department knows that no fix yet exists. Such corporate doublethink is indeed a Big Red Flag.
@venik212: sorry to hear that you're also suffering from a second defect – "intermittent, unpredictable starting from a shutdown". This hasn't yet occurred on my Meerkat, but I'm nearly always using a self-coded shutdown script, that's called by a power button icon on my Unity Launcher bar:
My custom shutdown shell script (click to embiggen)
Can't recall the source of the shutdown code (case 0 in the script below) beyond "I googled for it", yet it does the 'OFF' job swiftly; so in case you'd like to try this out, here's the code in my 'shutdown-1.sh' shell script:
# !/bin/bash
zenity --question \
--title "Confirmation Request" \
--text "Shut down Dalinian Meerkat now?" \
--ok-label "Shut Down" \
--cancel-label "Cancel" \
--window-icon="/usr/share/icons/LoginIcons/apps/48/system-shutdown.svg"
# Get exit status
# 0 means user hit [Shut Down] button.
# 1 means user hit [Cancel] button or [Esc] key.
response=$?
case $response in
0) dbus-send --system --print-reply --dest=org.freedesktop.login1 /org/freedesktop/login1 "org.freedesktop.login1.Manager.PowerOff" boolean:true;;
1) echo "Don't Shutdown";;
esac
@snowpine: please forgive my misunderstanding of your System76 purchase – here's hoping their due diligence for the model you're getting was superior to their NUC > Meerkat fail, and that your new system runs Ubuntu flawlessly.
Thanks for your suggestion of taking my misgivings to the top, to System76 CEO Carl Richell. Having discovered the simplicity of their email addy schema, email address verification [1] confirms that "mailto:carl@system76.com carl@system76.com is a valid deliverable e-mail box address." So if another unreasonable obstacle is placed in my path by System76 tier 1 staff, I've a self-escalation pathway for my complaints.
Thanks too for the timely "$50 off Meerkats + Free Shipping!" alert – or "Flogging Faulty PCs Fast!!!", as we've discovered the subtext to be.
[1] Email address verification " http://www.ip-tracker.org/checker/email-lookup.php http://www.ip-tracker.org/checker/email-lookup.php
Dalinian Here's the copy/paste from my first message to System76 and their response (timestamps after each message text):
Hi, I got the meerkat about 2 weeks ago and after about a week of normal operation, the meerkat wasn't responding to power button press after I had suspended it in ubuntu. I unplugged it from the socket which shut it down. Then the button wasn't responding to anything and I couldn't power it on. Everything was ok with the power socket, and plugging a USB mouse showed it was getting power. I searched on the internet about the issue and found in Intel NUC forums people reporting this issue and seemingly the only thing that solved it was open it up and unplug the CMOS battery for a few seconds. So I tried that, and I was able to power it back on.
Since I was able to find that on forums, I'm assuming you're aware of this problem. I would like to be able to use the suspend feature of ubuntu and I'm waiting for instructions on how to fix this issue.
I'm using the meerkat as it came. No OS or hardware changes.
Thank you.
Nikitas, 9/27/2015 3:10 pm
HI Nikitas
Thank you for contacting us. Glad t hat solution worked for you. I'll pass this information onto my developer. From where I sit, this is the only case I've seen where this has happened.
Mark, 9/28/2015 8:53 amBy "solution" Mark meant the CMOS battery unplug, which I followed up on to say I didn't consider to be a "solution" at all. He said he'll pass along to his "developer" (whatever that means) and I never heard back anything after that. Given this thread, I'll write a message again to see what they tell me.
So, if you wrote to them after 09/28 and they responded they didn't know about the problem, they either lied to you or they just don't bother with the issues customers report to them. And if you guys wrote to them before 09/28, then they lied to me too
Hi nikitas,
Thank you for sharing your verbatim exchange with System76 Tech support person Mark – he's the same dodgy character I've been dealing with, and we can now expose him as a liar, as follows.
- On 27 Sep 2015, you reported your 'Ubuntu Suspend > Dead Meerkat' defect to Mark, as well as the Dead Meerkat Resurrection Workaround that you'd discovered from prior 'Linux Suspend > Dead NUC' victims, via your own online research – ie: disconnecting/reconnecting the CMOS battery from the motherboard (source: your post # 15 in this thread, above).
- On 26 Oct 2015, Mark's first response to my report of my first 'Ubuntu Suspend > Dead Meerkat' incident included an instruction that I should "Open the box and clear the cmos by removing the battery," ie: he passed on to me the Dead Meerkat Resurrection Workaround which he learned about from you (source: my own System76 tech support case log).
- On 04 Nov 2015, I posted to Mark direct quotes (and source URL's) from 11 Intel NUC users, describing their 'Linux Suspend > Dead NUC' experiences, all of which pre-dated the launch of the Meerkat in March 2015 – in order to demonstrate the apparent failure of System76's prior due diligence to detect that the computer they are rebadging as their Meerkat exhibits a well-known Linux-specific bricking defect. Here is Mark's reply (copy-&-pasted from my System76 tech support case log, with my emphasis), including timestamp:
"Tim
We're actually investigating based on your complaint. This is the only report we've had like this. Some of the info you have in the links is pretty old, however we're also taking into account what you have presented."
Mark, 11/5/2015 3:08 pm
Given that System76 had been selling Meerkats for seven months before your 'Ubuntu Suspend > Dead Meerkat' defect showed up in September, it seems highly likely that yours wasn't the first 'Ubuntu Suspend > Dead Meerkat' to be reported to System76 tech support. But given that we've established that Mark lied to me in November ("This is the only report we've had like this"), it seems eminently reasonable to suspect that he lied about prior reports of this defect to System76 tech support, when he told you "This is the only case I've seen where this has happened."
It's beginning to look like the "It's an isolated unique case" deception, delivered in private, may actually be company policy at System76.
Two Bricked Meerkats, One System76 Liar
Holy crap, you guys – seems like I very much did right to steer well clear of this bunch of lousy decepticons!
Guess what I was told about Tim's bricked Meerkat case by the System76 sales team?
Hi Angela,
I know that the one customer posting in the forums is a unique case. [snip]
Emma, Friday @ 4:25 PM
Alongside faulty computers, seems very much like private falsehoods are another of System76's stock-in-trade:
• Lying to Meerkat owners who complain about how Ubuntu suspend bricked their computer - "This is the only report we've had like this" and "This is the only case I've seen where this has happened." ~ Mark, System76 tech support (a)
• Lying to potential Meerkat customers that they've beaten Intel in the race to fix this defect - "The suspend issue is definitely not a concern on our current units" and "We ship with v.0350 and it works. The bios fix was implemented at the end of November and it did resolve the suspend issue." ~ Emma, System76 sales (b)
• Lying to potential Meerkat customers that only one Meerkat ever got bricked by Ubuntu suspend - "I know that the one customer posting in the forums is a unique case." ~ Emma, System76 sales (a)
Guess we can "thank'' Intel for providing the public forum that's empowered folks to publicly expose System76's 'Decieve the Public' policy - which is the least Intel could do, given that it's their Linux-suspend-bricks-NUCs fault which is the driving force behind System76's private deceptions.
I know I really ought to switch notifications off, but I gotta confess to a morbid rubbernecking fascination to see how this mess plays out.
(a) We know that System76 knows of at least two Meerkats bricked by Ubuntu suspend, with both tech support cases - Tim and nikitas - being dealt with by Mark (and it's probable more cases were reported, March-September 2015)
(b) We know that System76 knows that Tim's Meerkat was bricked by Ubuntu suspend with System76's v.0350 BIOS installed (and was also similarly bricked with Intel's v.0350 BIOS installed)
OK, so I'm gonna post the final two entries in my System76 sales team chat stream with Emma (my post 1st, followed by Emma's reply) - then I'm gonna try to quit this morbid fascination once and for all.
"A Unique case" - oh, really? According to nikitas, another System76 customer who is reporting identical Meerkat bricking, his case pre-dates Tim's by a month - details: https://communities.intel.com/message/360663# 360663 https://communities.intel.com/message/360663# 360663
Nobody appreciates being taken for a fool.
That's more than enough red flags for me - I'll be looking elsewhere for a reliable Ubuntu mini PC. For a fuller rationale, see my post # 10 in 'NUC5i5RYH Bricked by Ubuntu Suspend for Fifth Time' at https://communities.intel.com/message/360688# 360688 https://communities.intel.com/message/360688# 360688
A word to the wise: what's been most impressive is the technical competence and moral integrity of Tim Jones in highlighting, documenting, and helping Intel to solve their Linux-suspend-bricks-NUCs problem, which defect is clearly and logically inherited by your Meerkat - and these are virtues which I'm NOT seeing in the way System76 chooses to conduct itself. I'm also grateful that his diligence saved me from making what could have been an expensive mistake. He very much strikes me as the kind of customer you really want on the inside of the tent pissing out, and NOT on the outside pissing in, as is currently the case. Let's just hope you folks can shape up and get him onside with a virtuous and generous replacement/refund process, before his winning determination loses you yet more Meerkat sales - just sayin'.
Angela, Saturday @ 8:10 AM
HI Angela,
I'm sorry you feel that way. The percentage of customers who experienced this was .0075%. That's less than .01 percent of total customers and Tim is the only customer who continued to experience it, which we've offered to have replaced/repaired.
Good luck with your search. Have a great day.
Emma, Today @ 10:30 AM
Notice how Emma dodges confronting the truth that her bogus "Tim's is a unique case" claim is actually a lie? SMH
Hmm... OK, so if (for the sake of argument) we choose to adopt the ultra-conservative assumption that ONLY these two known Meerkat owners have reported the Ubuntu-suspend-bricked-my-Meerkat fault to System76, then...
Q. Tim + nikitas = 0.0075% of all Meerkat owners; how many Meerkats have been sold?
A. 26,667 Meerkats have been sold in 9 months (math in footnote below), ie: an average of 2,963 Meerkats are sold per month.
As world class lousy decepticon Francis Underwood might say, "You may consider this to be an unfeasibly and inordinately high number; I couldn't possibly comment."
If 2 = 1% then 100% = 2 x 100 = 200
If 2 = 0.1% then 100% = 2 x 1000 = 2000
(1 / 0.1 = 10 and 10 × 100 = 1000)
If 2 = 0.01% then 100% = 2 x 10,000 = 20,000
(1 / 0.01 = 100 and 100 × 100 = 10,000)
If 2 = 0.0075% then 100% = 2 x 13,333.3333333 = 26,667 - when rounded to the nearest integer
(1 / 0.0075 = 133.333333333 and 133.333333333 × 100 = 13,333.3333333)
Hence 26,667 Meerkats have been sold - IF you believe Emma and System76 can be trusted, that is.
Does this issue also occur when using an MCE remote to suspend and wake Ubuntu?
As far as I know from reading several threads the bricking issue only happens when the power button is used to wake or start it. The workaround is to use USB or Wake On Lan to wake or start. Since the infrared receiver for the remote is connected by USB there shouldn't be a problem.
Hi venik212,
Go to BIOS>Advanced>Power and enable:
Wake from S3 via CIR
Wake from S4 and S5 via CIR
USB S4/S5 power
Let me know how your remote control works.
Mike C
All of these are already set as you indicated. The main problem I now have is the occasional loss of communication between the RF receiver and my wireless keyboard, which I correct by unplugging and re-plugging the RF receiver from the NUC's USB port.
Hi venik212,
Thank you for your feedback. By any chance, did you do a test with any other battery?
Mike C
