Hello!
I have developed a FPGA software (NB: I'm not sure it can be called software, but anyway
verilog code), about 2+ years ago. As it needed a sinewave, I used coefficients stored in a
double access ROM. 1024 coefficients, 18-bit. This should yield (and I think it did at that time)
18 kbits memory usage. See the following code.
Now when compiling that code, the memory usage is 16k (16384 bits to be accurate).
Could anybody explain me what's wrong and how to fix it?
Pascal
------------ DA ROM ---------------
// Quartus Prime Verilog Template
// Dual Port ROM
module sine_rom
//#(parameter DATA_WIDTH=`ROM_DATW-1, parameter ADDR_WIDTH=`ROM_ADDW)
#(parameter DATA_WIDTH=18, parameter ADDR_WIDTH=10) (
input [(ADDR_WIDTH-1):0] addr_a, addr_b,
input clk,
output reg signed[(DATA_WIDTH-1):0] q_a, q_b
// Declare the ROM variable
reg signed[DATA_WIDTH-1:0] rom[2**ADDR_WIDTH-1:0]; // 18 * 1024 in this case
initial
begin
$readmemh("SineFiles/sine18_1ks.hex", rom);
end
always @ (posedge clk)
begin
q_a <= rom[addr_a];
q_b <= rom[addr_b];
end
endmodule
Hello!
Thanks for your reply. Indeed, what you describe is right. I wanted to build a complete new version
from scratch because of beginner problems in my very first project, beginner that I still am.
I oversimplified the project. It used to make a linear interpolation between 2 consecutive samples,
caculating in 18 bits, then rendering the result in 16. An for a start, I was using only one of the
samples (i.e. no interpolation), therefore the 2 last bits were not used at all.
Thanks a lot for your help, it works now, and the compilation reports 18432 bits used, which is
exactly 18 * 1024. The numbers match, now.
Pascal
