15775 Discussions
Error (292014): Can't find valid feature line for core SLL_CA_HBC_T001_Hyperbus_Memory_Controller_10
YangrootG
I am trying SSS communication with Intel® Cyclone® 10 LP FPGA Evaluation Board.
https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/cyclone/10-lp-evaluat...
The project is from
https://www.intel.com/content/www/us/en/design-example/714923/cyclone-10-lp-nios-ii-simple-socket-se...?
Then I got these two errors:
Error (292014): Can't find valid feature line for core SLL_CA_HBC_T001_Hyperbus_Memory_Controller_10min_trial_edition (AE7C_0014) in current license.
Error (10003): Can't open encrypted VHDL or Verilog HDL file "C:/Work/FPGA/C10_SSS/db/ip/q_sys/submodules/sll_ca_hbc_t001_top_enc.v" -- current license file does not contain a valid license for encrypted file
I can compile other projects successfully.
Also updated all license (University Program), tried 17.1, 19.1, 22.1std, nothing helped
There is similar post here (@AR_A_Intel)
https://community.intel.com/t5/Intel-Quartus-Prime-Software/Error-292014-Can-t-find-valid-feature-li...
It seems I need third-party license (if same reason), but no idea how/where to get it....
Very appreciate if anybody could help!!
Yangroot
Just realized that when compiling "golden_system_ref_design" downloading from Terasic, I get the same error.
AR_A_Intel
Hello
Welcome to INTEL forum. Further check, can you provide detail below?
1) License.dat file
2) Screenshot of Quartus >> tools >> license setup
3) assembler report .asm.rpt file
•          The assembler report is located in <Project directory>/Output_files/<project_name>.asm.rpt.
 And for privacy, you can reply/attach your file in private message.
YangrootG
@AR_A_Intel  Thanks for your reply.  I will send you all files.
AR_A_Intel
We received and will respond you in the private message. TQ
AR_A_Intel
Continue support in private message mail. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
