I am new to FPGA's and i am trying to learn to work with them. while i was trying to run an rtl simlation on questasim(free ver) i encountered the following in questasim:
# Reading pref.tcl
# // Questa Intel Starter FPGA Edition-64
# // Version 2023.3 win64 Jul 17 2023
# // Copyright 1991-2023 Mentor Graphics Corporation
# // All Rights Reserved.
# // QuestaSim and its associated documentation contain trade
# // secrets and commercial or financial information that are the property of
# // Mentor Graphics Corporation and are privileged, confidential,
# // and exempt from disclosure under the Freedom of Information Act,
# // 5 U.S.C. Section 552. Furthermore, this information
# // is prohibited from disclosure under the Trade Secrets Act,
# // 18 U.S.C. Section 1905.
# do inv_run_msim_rtl_verilog.do
# vmap altera_ver C:/intelFPGA_lite/projects/P2/verilog_libs/altera_ver
# Questa Intel Starter FPGA Edition-64 vmap 2023.3 Lib Mapping Utility 2023.07 Jul 17 2023
# Copying C:/intelFPGA_lite/23.1std/questa_fse/win64/../modelsim.ini to modelsim.ini
# Modifying modelsim.ini
# ** Error (suppressible): (vmap-19) Failed to access library 'altera_ver' at "C:/intelFPGA_lite/projects/P2/verilog_libs/altera_ver".
# No such file or directory. (errno = ENOENT)
# Error in macro ./inv_run_msim_rtl_verilog.do line 2
# while executing
# "error [FixExecError $msg]"
# (procedure "vmap" line 29)
# invoked from within
# "vmap altera_ver C:/intelFPGA_lite/projects/P2/verilog_libs/altera_ver"
i can not find anything called altera_ver anywhere. i was getting a different error before which was :
C:/IntelFPGA_lite/23.1std/questa_fse/win64/vsim.exe this did not work and after running the quartus # vsim -t 1ps -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L cyclonev_ver -L cyclonev_hssi_ver -L cyclonev_pcie_hip_ver -L rtl_work -L work -voptargs="+acc" tb_inv.v
# vsim -t 1ps -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L cyclonev_ver -L cyclonev_hssi_ver -L cyclonev_pcie_hip_ver -L rtl_work -L work -voptargs=""+acc"" tb_inv.v
# Start time: 12:07:15 on Feb 06,2025
# ** Error (suppressible): (vsim-19) Failed to access library 'tb_inv' at "tb_inv".
# Error loading design
# Error: Error loading design
# Pausing macro execution
# MACRO ./inv_run_msim_rtl_verilog.do PAUSED at line 12
now iam stuck here for past few hours can you please help me out. i am just trying to run a simple inverter program
i have already added the quartus and questa directories to path. i tried to recompile the simulation libraries but there was another error there.
It's not usually a good idea to have your project in the Quartus installation directory.
But besides that, can you show your code?
module inv(
input a,
output y
assign y= ~a;
endmodule
`timescale 1ns/1ps
module tb_inv;
reg a;
wire y;
inv uut (
.a(a),
.y(y)
// Testbench logic
initial begin
a = 0; #10;
a = 1; #10;
end
endmodule
My suggestion is to follow step by steps given the instruction below:
https://www.intel.com/content/www/us/en/docs/programmable/691278/21-3/quick-start.html. I have try multiple times without any issues.
Hi, I'm sorry if i didn't mention but i am actually using the intel Quartus prime lite software version 23.1 std. with the free license for intel Questa. This specifically. the device i am using is the de-10 nano board by terrasic with intel cyclone 5 [5CSEBA6U23I7]. I have attached a screenshot of the questasim window too and the error message in questasim.
# Reading pref.tcl
# while executing
I can see you are using nativelink where Quartus Pro no longer support, in any case, can you double check the steps in
Then try the following solutions step by step:
1. Check if the altera_ver Library Exists
The error "No such file or directory" means that QuestaSim is trying to map altera_ver, but the directory doesn’t exist.
Manually verify the directory:
Open File Explorer and navigate to:
Check if the altera_ver folder exists.
If it's missing, the libraries were not correctly installed or compiled.
2. Generate the Missing Intel Simulation Libraries
If altera_ver is missing, you need to generate the required Quartus simulation libraries.
Follow these steps:
A. Open the Nativelink script
Open Quartus Prime Lite 23.1.
Go to Tools → Tcl Scripts.
Look for compile_simlib.tcl (this script compiles the simulation libraries).
B. Run the Simulation Library Compilation
Open QuestaSim Intel FPGA Starter Edition.
Navigate to the questa_fse/bin directory in your Intel FPGA installation path:
cd C:/intelFPGA_lite/23.1std/questa_fse/bin
Run the following command to compile the libraries:
vsim -do "do C:/intelFPGA_lite/23.1std/quartus/common/tcl/internal/nativelink/compile_simlib.tcl"
Select Verilog when prompted.
Ensure you specify the correct path where the compiled libraries should be stored.
3. Correct the vmap Command
Once the libraries are compiled, map them correctly in QuestaSim:
Delete any incorrect mappings
vdel -lib altera_ver -all
Re-map altera_ver correctly:
vlib C:/intelFPGA_lite/23.1std/questa_fse/verilog_libs/altera_ver
vmap altera_ver C:/intelFPGA_lite/23.1std/questa_fse/verilog_libs/altera_ver
Verify the mapping
vmap
This should list altera_ver mapped to the correct path.
4. Check modelsim.ini for Incorrect Paths
Open the modelsim.ini file inside your project directory (C:/intelFPGA_lite/projects/P2/).
Look for the [Library] section.
Ensure it has an entry like:
altera_ver = C:/intelFPGA_lite/23.1std/questa_fse/verilog_libs/altera_ver
If the path is incorrect or missing, manually add it.
5. Restart QuestaSim and Re-run the Simulation
After doing all the above:
Restart QuestaSim.
Run:
vmap
to check if altera_ver is now mapped.
Try running your simulation again.
i tried the steps from the document attached, not similar to my quartus prime lite but i did follow similar steps to compile the test bench from the starting itself and i am not sure which file to add along with it so i have added the screenshot.
Coming to the steps you provided there was no alter_ver folder in
C:/intelFPGA_lite/projects/P2/verilog_libs/.
" A. Open the Nativelink script
Look for compile_simlib.tcl (this script compiles the simulation libraries)."
for thew above steps i could not find any tcl scripts in the tcl script window.
next I tried is :
but there was no bin folder in the directory also on searching for "compile_simlib.tcl" there were no results in questa_fse folder
So, basically none of it worked.
i tried installing everything again and got the following error which is same as before
# Reading pref.tcl
# while executing
In that case, can you send over your design.qar files?
Also, what is the OS that you were using?
i am using windows 11. the files generated by quartus are .qpf. qsf & .qws an the other files cant find any .qar
i have attached screenshots of 2 projects both have a different issue.
module inv has the missing library issue
module mux1 has the following error:
# do mux1_run_msim_rtl_verilog.do
# if {[file exists rtl_work]} {
# vdel -lib rtl_work -all
# vlib rtl_work
# vmap work rtl_work
# vlog -vlog01compat -work work +incdir+C:/Users/KANAADA\ NMIT\ 2/Desktop/proj\ questa/projects/p1 {C:/Users/KANAADA NMIT 2/Desktop/proj questa/projects/p1/mux1.v}
# Questa Intel Starter FPGA Edition-64 vlog 2023.3 Compiler 2023.07 Jul 17 2023
# Start time: 10:29:46 on Feb 20,2025
# vlog -reportprogress 300 -vlog01compat -work work "+incdir+C:/Users/KANAADA NMIT 2/Desktop/proj questa/projects/p1" C:/Users/KANAADA NMIT 2/Desktop/proj questa/projects/p1/mux1.v
# -- Compiling module mux1
# Top level modules:
# mux1
# End time: 10:29:46 on Feb 20,2025, Elapsed time: 0:00:00
# Errors: 0, Warnings: 0
# vlog -vlog01compat -work work +incdir+C:/Users/KANAADA\ NMIT\ 2/Desktop/proj\ questa/projects/p1 {C:/Users/KANAADA NMIT 2/Desktop/proj questa/projects/p1/mux1_tb.v}
# vlog -reportprogress 300 -vlog01compat -work work "+incdir+C:/Users/KANAADA NMIT 2/Desktop/proj questa/projects/p1" C:/Users/KANAADA NMIT 2/Desktop/proj questa/projects/p1/mux1_tb.v
# -- Compiling module mux1_tb
# mux1_tb
# vsim -t 1ps -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L cyclonev_ver -L cyclonev_hssi_ver -L cyclonev_pcie_hip_ver -L rtl_work -L work -voptargs="+acc" mux1_tb.v
# vsim -t 1ps -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L cyclonev_ver -L cyclonev_hssi_ver -L cyclonev_pcie_hip_ver -L rtl_work -L work -voptargs=""+acc"" mux1_tb.v
# ** Error (suppressible): (vsim-19) Failed to access library 'mux1_tb' at "mux1_tb".
# MACRO ./mux1_run_msim_rtl_verilog.do PAUSED at line 12
this is relevant because i used to get this same error in the module inv also but after a while it changes to the other error somehow.
You can share the .qar project by archiving the project (Project > Archive Project).
I recommend going through the NativeLink simulation flow, using the example design provided in the user guide below.
The NativeLink feature helps automatically compile your design, Altera IP, simulation model libraries, and testbench.
https://www.intel.com/content/www/us/en/docs/programmable/703090/21-1/simulation-quick-start.html
Once you can simulate the example design, try using the same flow with your current design.
Additionally, as Strell mentioned, try moving your project directory out of the C drive, as you might encounter permission errors when reading/writing files.
Richard Tan
Sorry just got to work after long. PFA requested files. I have attached files of the 2 projects that were showing the errors above.
Device i am using:
5CSEBA6U23I7 |
Thank you for the replies
Two things that you need to change in your mux1.qar:
1) In the Nativelink setting where you add the testbench file, when the tool ask for "Test bench name" and "Top level module in test bench", you wrote "mux1_tb.v". Instead you should write "mux1_tb" without the ".v" at the end. This will solve your current error.
2) After solving the first error, you will get another simulation error that indicate the mux module can not be instantiate. Go to your mux1_tb.v file, change "mux uut" to mux1 uut".
Simulation should run after implement all the changes.
Richard Tan
mux_nativelink_simulation.rpt
Info: Start Nativelink Simulation process
Info: NativeLink has detected Verilog design -- Verilog simulation models will be used
========= EDA Simulation Settings =====================
Sim Mode : RTL
Family : cyclonev
Quartus root : d:/intel/quartus/bin64/
Quartus sim root : d:/intel/quartus/eda/sim_lib
Simulation Tool : questa intel fpga
Simulation Language : verilog
Simulation Mode : GUI
Sim Output File :
Sim SDF file :
Sim dir : simulation\questa
Info: Starting NativeLink simulation with Questa Intel FPGA software
Sourced NativeLink script d:/intel/quartus/common/tcl/internal/nativelink/modelsim.tcl
Info: Spawning Questa Intel FPGA Simulation software
Info: NativeLink simulation flow was successful
i got this in the report but the questa sim window did not open. Using a different system with windows10, shifted license to the new system.
pfa qar files
What you mean by "Using a different system with windows10, shifted license to the new system." I don't understand. What is the different system and what is the new system?
Could you invoke the Questa software standalone?
Richard Tan
I am using a different computer now which has the windows 10 OS. when i open vsim.exe it opens a command terminal and closes automatically. no error screen shown. Application not opening.
terminal output
license file
whenv i click on questasim.exe this opens and closes immediately.
Seem to be a license setup issue.
Have you setup your LM_LICENSE_FILE environment variable?
https://www.intel.com/content/www/us/en/docs/programmable/683472/24-3-1/and-software-license.html
Richard Tan
