16606 Discussions
How to open ModelSim simulator?
LChow3
I have installed Quartus Prime Pro Edition v20.1 and ModelSim.
Refer to the Tutorial ModelSim_GUI_Introduction.pdf attached below, I couldn't find where to open the ModelSim simulator.
RichardTanSY_Intel
May I know which OS platform you are using?
You can launch Modelsim Intel FPGA Edition directly by searching it in the window start menu or from the Quartus installation directory e.g. C:\intelFPGA\19.1\modelsim_ae\win32aloem
Attach video in the link below for your reference: ModelSim*-Intel FPGA Edition Simulation with Intel Quartus Prime Pro Edition
https://www.youtube.com/watch?v=eviC0jP90ZA&t=202s
For Linux, you can launch the Modelsim with ./vsim at directory ~/intelFPGA/19.1/modelsim_ase/bin
p.s. Don’t forget to Reply, and Select the Best Solution. :)
LChow3
Thank you for the link, I can open the ModelSim now.
I'm using Windows 8.
In that YouTube video, it opened a folder 'mentor' in the project directory. However I don't have this directory.
RichardTanSY_Intel
Glad to know that you are able to open the Modelsim.
The folder will only be generated when you run Tools > Generate Simulator Setup Script for IP, after compiling your project.
LChow3
