16635 Discussions
Inconsistency detected by ld.so: dl-close.c: 764: _dl_close: Assertion `map->l_init_c
I keep getting this message whenever I run Quartus (15.0) on most non-supported Linux distributions. The message does not seem to be fatal, but some tools/scripts will check the output of Quartus and fail whenever the above error is written to stdout.
According to https://www.altera.com/support/support-resources/knowledge-base/solutions/rd01272015_37.html this should (or maybe that was a fatal version?) have been fixed in 15.0.
Any ideas to get around the problem or if it will it be fixed in 15.1?
The problem appears even after software update to 15.0.2
Checked on Gentoo Linux and Arch Linux.
quartus_map --version Quartus II 64-Bit Analysis & Synthesis Version 15.0.2 Build 153 07/15/2015 SJ Web Edition Copyright (C) 1991-2015 Altera Corporation. All rights reserved.
I'm seeing this in 15.02. Keeps me from executing a .tcl script to assign DDR pins for Cyclone V.
I see this too but it does not prevent me to do anything - at least whatever I notice.
I first noticed the problem when the DDR generation script would fail. Also noted by jon_herr above. But anything which will rely on the output or maybe even return value (have not verified this yet) would fail. Unfortunately it's also present in 15.1.
I think this is related and exists in RedHat (before someone starts crying it's because I'm using Ubuntu)
https://sourceware.org/bugzilla/show_bug.cgi?id=12454
I'm using Quartus Prime Pro and Standard with the latest updates, and this issue still persists. The problem lies within the curl libraries packaged in $QUARTUS_ROOTDIR/linux64. I was able to remove ALL Quartus errors/warnings by backing up libccl_curl_drl.so, libcrypto.so.1.0.0, libcurl.so.4, libssl.so.1.0.0 and then deleting them.
sudo cp libccl_curl_drl.so libccl_curl_drl.so.bak sudo cp libcrypto.so.1.0.0 libcrypto.so.1.0.0.bak sudo cp libcurl.so.4 libcurl.so.4.bak sudo libssl.so.1.0.0.bak sudo rm libccl_curl_drl.so libcrypto.so.1.0.0 libcurl.so.4 libssl.so.1.0.0
This worked for me and allowed me to complete OpenCL compilation (finally). I also had some GLIBCXX errors, which were resolved by following the same process on libstdc++.so.6.
sudo cp libstdc++.so.6 libstdc++.so.6.bak sudo rm libstdc++.so.6
You may need to then add the i386 architecture (if on 64 Bit) and install the libraries to your system that you just removed from here. I don't remember all the commands I ran to complete this, so you may need to search a bit to find the appropriate apt-get commands to install what you removed. I fought with this issue for a week before finally working it all out!
Good catch. But do you have libccl_curl_drl.so etc. local on your computer, e.g. in /lib64 or /usr/lib64? If yes, which versions are these?
Also what is the output of e.g:
ldd /your/altera/root/quartus/linux64/quartus_cpf | grep curl
Replace /yousr/altera/root with the root path of your Quartus installation.
TO_BE_DONE
I had same problem.
wbgreen's solution seemed to be correct answer. but, it didn't work.
so, I restored .bak files one by one except 'libccl_curl_drl.so.bak'
I don't know why, Quartus Prime goes well. Anyone knows about this?
Hi all,
I have Quartus 17.0.1 running on Ubuntu 16.04 64bit LTS. After doing a fresh installation I corrected the following 2 errors:
Fix error 1:
intelFPGA/17.0/quartus/linux64/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by /usr/lib/x86_64-linux-gnu/libproxy.so.1)
Failed to load module: /usr/lib/x86_64-linux-gnu/gio/modules/libgiolibproxy.so
$ cd ~/intelFPGA/17.0/quartus/linux64
$ mv libstdc++.so.6 libstdc++.so.6.bak
$ ln -s /usr/lib/x86_64-linux-gnu/libstdc++.so.6 libstdc++.so.6
Fix error 2:
Inconsistency detected by ld.so: dl-close.c: 811: _dl_close: Assertion `map->l_init_called' failed!
$ mv libccl_curl_drl.so libccl_curl_drl.so.bak
