16640 Discussions
Interfacing switches with led in de-1 soc using nios v processor in quartus prime software
BCPRAVEEN1234
respected sir/mada
is there any examples for using nios v processor in quartus prime software at specially how to interface the switch with leds in de-1 soc(cyclone-v ) board or any other examples  also please send me sir
Vipin_Singh1
Hi Bonthu, we would like to inform you that we are routing your query to the dedicated team for further assistance.
EBERLAZARE_I_Intel
I just had this ticket routed to me today, can you share me your Quartus software version and your host PC environment?
Also, have you run any design using the previous Nios II? Are you familiar with the Nios II SBT eclipse tools?
BCPRAVEEN1234
intel quartus 23.1 std prime verision with nios v/m processor i have only cyclone -v (de-1soc) i run the different examples like interfacing led ,lnterfacing lcd, different examples using nios ii and also iam familiar with eclipse tool.so now i had learn nios v processor with different examples i tried already hello world example with nios v processor in 23.1 std version with riscfree ide  and nios v command shell so further i need different examples for practicing nios v processor so please forward me for differnt examples it is helpful to me praticiing the nios v processor
thanking you
BCPRAVEEN1234
no sir problem not sloved
EBERLAZARE_I_Intel
Thanks for the info, I will check from my side on what I can help you with.
I shall get back to you soon
EBERLAZARE_I_Intel
You may create your own hardware design for your board DE1-SoC, you may follow the steps here:
https://www.intel.com/content/www/us/en/docs/programmable/726952/23-4/processor-application-executes-in-place-31167.html
As your board need the Quartus Standard version, you may refer here when doing the BSP package:
https://www.intel.com/content/www/us/en/docs/programmable/778829/current/generating-the-bsp-in-standard-edition.html
Once you able to boot the Nios V and observe the hello world output, you may go further and check out the LED design from Nios II previously and edit your design accordingly to set the LED etc, for e.g this design:
https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-examples/horizontal/exm-hardware-tutorial.html
EBERLAZARE_I_Intel
Let me know if your have further questions.
EBERLAZARE_I_Intel
I hope that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
