16642 Discussions
Quartus Fitter Crashing
audrey1
Hi, I'm looking to get some help to get my Quartus to work for my digital logic/comp org class. Its been giving me quite a headache. Currently I have the M1 Pro Macbook and I need to run Quartus using a Parallel Boot/VM. I'm able to install Quaratus and compile it however I run into an error while fitting. Is there anything I can do to fix this error. Thank you!
report.pngI noticed that similar cases appeared in the forum, but they were not solved. I have no problem compiling with a native Windows computer.
AR_A_Intel
Hello
Welcome to Intel forum. Apologies for the delay, could you share more detail of the problem. Provide error message screenshot or any warning notice.
audrey1
Problem Details
Error:
Internal Error: Sub-system: DYGR, File: /quartus/ddb/dygr/dygr_place_info.cpp, Line: 3270
Stack Trace:
    0x48b5e: DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID::operator unsigned __int64 + 0x2c08e (DDB_DYGR)
    0x1e210: std::_Hash<std::_Umap_traits<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID,DYGR_BLK_PORT_INFO const * __ptr64,std::_Uhash_compare<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID,STL_HASH_FUNCTOR<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID>,std::equal_to<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID> >,std::allocator<std::pair<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID const ,DYGR_BLK_PORT_INFO const * __ptr64> >,0> >::_Hashval + 0x10 (DDB_DYGR)
    0x1f91e: std::unordered_map<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID,DYGR_BLK_PORT_INFO const * __ptr64,STL_HASH_FUNCTOR<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID>,std::equal_to<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID>,std::allocator<std::pair<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID const ,DYGR_BLK_PORT_INFO const * __ptr64> > >::operator[] + 0x1e (DDB_DYGR)
    0x1d5bb: DYGR_BLK_PHYSICAL_IMPLEMENTATION::populate_port_info_transient_data + 0xff (DDB_DYGR)
    0x18586: DYGR_PLACE_INFO_BODY::set_transient_data_members + 0x66 (DDB_DYGR)
    0x3407b: DYGR_PLACE_INFO_BODY::load_data_from_pdb + 0x83 (DDB_DYGR)
    0x15188: DYGR_DIE_INFO_BODY::load_data + 0x2a4 (DDB_DYGR)
    0x1d1f7: MPP_ROOT::start + 0x587 (COMP_MPP)
     0x5e5a: qfit_execute_mpp + 0x42 (comp_qfit_legacy_flow)
     0x555b: QFIT_FRAMEWORK::execute + 0x22f (comp_qfit_legacy_flow)
     0x2768: qfit_legacy_flow_run_legacy_fitter_flow + 0x1d4 (comp_qfit_legacy_flow)
    0x14410: TclInvokeStringCommand + 0xf0 (tcl86)
    0x161e2: TclNRRunCallbacks + 0x62 (tcl86)
    0x17a65: TclEvalEx + 0xa65 (tcl86)
    0xa6f8b: Tcl_FSEvalFileEx + 0x22b (tcl86)
    0xa5646: Tcl_EvalFile + 0x36 (tcl86)
    0x12877: qexe_evaluate_tcl_script + 0x367 (comp_qexe)
    0x11ac3: qexe_do_tcl + 0x343 (comp_qexe)
    0x16c34: qexe_run_tcl_option + 0x584 (comp_qexe)
    0x39285: qcu_run_tcl_option + 0xf95 (comp_qcu)
    0x1658d: qexe_run + 0x39d (comp_qexe)
    0x17371: qexe_standard_main + 0xc1 (comp_qexe)
     0x2262: qfit2_main + 0x82 (quartus_fit)
    0x13258: msg_main_thread + 0x18 (CCL_MSG)
    0x14a5e: msg_thread_wrapper + 0x6e (CCL_MSG)
    0x16af0: mem_thread_wrapper + 0x70 (ccl_mem)
    0x12af1: msg_exe_main + 0xa1 (CCL_MSG)
     0x2a02: __tmainCRTStartup + 0x10e (quartus_fit)
    0xeb93b: uaw_wcsrchr + 0xe5e7b (KERNEL32)
    0x71ef7: uaw_wcsrchr + 0x6c437 (KERNEL32)
   0x1bc7ef: NtWaitLowEventPair + 0x1ae25f (ntdll)
End-trace
Executable: quartus_fit
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 20.1.0
Build: 711
Edition: Lite Edition
AR_A_Intel
Thanks for update. Based on my understanding, regrettably Quartus compilation don’t support Parallel Boot/VM.
Please accept my apologies for not being able to assist you fully as this is out of my expertise. Thank you for patience and understanding on this matter.
AR_A_Intel
We have not heard from you and I hope that my last note clears up this matter. If you don’t have any further question, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
