16970 Discussions
Query in the Post Route results.
PravinKumar
May I know how implemented frequency is calculated here and why the FMax is calculated in that way.
I am seeing the difference in calculating Fmax for the design.
Highlighted the considered values from reports and attached snapshots.
I have attached the project folder for your reference.
Can you help me to identify the issue.
ShengN_Intel
I had tried to extract the folder and open the design. However can't find the related files in screenshot:
Could you provide the missing files as well?
Sheng
ShengN_Intel
May I know do you have any further concern or consideration?
Sheng
PravinKumar
Yes, I have attached the hdl_prj folder which is having hdlsrc and quartus_prj.
Please let me know how to proceed.
Pravin
FvM
Honored Contributor I
your design fails timing analysis because Arria 10 maximum core clock frequency of 644 MHz is exceeded (timing analyser uses rounded value of 645.16MHz = 1/1.55ns). This causes a "minimum pulsewidth" violation for clk and a respective restricted Fmax value.
Possible contradicting reported values in timing analysis are referred. You need to solve the minimum pulsewidth problem first.
Frank
ShengN_Intel
FvM is right. You may check this document link https://cdrdv2-public.intel.com/666844/a10_datasheet-683771-666844.pdf (page 36):
Parameter Performance (All Speed Grades) Unit
Global clock, regional clock, and small periphery clock 644 MHz
Large periphery clock 525 MHz
As for setup slack, you may go to Assignments -> Settings -> Compiler Settings -> choose Performance
Sheng
FvM
this .sdc passes timing analysis
create_clock -name clk -period 1.56ns -waveform {0.0ns 0.78ns} [get_ports {clk}]
derive_clock_uncertainty
set_false_path -to [all_outputs]
set_false_path -from [all_inputs]
Presume NR_symbol_modulator is planned to be used inside an Arria 10 design with some kind of high speed interface. Consider that FPGA fabric side of the interface can't run above 644 MHz clock. If intended 780 MHz clock is required by interface throughput, you'll need more bits for the parallel data stream.
ShengN_Intel
May I know do you have any further update or concern?
Sheng
