Questa not opening
jasns
The following was shown when Questa Intel FPGA Starter Edition was opened :
Reading pref.tcl
e=unable to initialize OLE2
o=code 1 -level 0-errorstack {INNER { invokeStk1 GUIMAIN}}
while executing
"GUIMAIN"} -errorline 1
errInfo=unable to initialize OLE2 while executing "GUIMAIN"
**Fatal: Exiting VSIM license process
After showing the above content, the Questa software suddenly closes
NB: I have generated License as well the environment variables are also set.
How to solve this issue?
Thank you
ShengN_Intel
May I know which Quartus version you're using? Linux or Window?
Sheng
jasns
I am using Quartus prime lite edition (in windows ).
The Questa version is Questa Intel FPGA starter edition 2021.2
My windows specifications are:
Edition: windows 10 home single language
version: 22H2
Is this error due to any issue with my system?
thank you
ShengN_Intel
I'm able to open Questa Intel FPGA starter edition 2021.2 in Windows 11 22H2 check screenshot attached. Windows 10 22H2 should be no problem. Could you try to reinstall the Questa Tool?
Also, make sure license path in environment variable LM_LICENSE_FILE ..\<License>.dat
Sheng
ShengN_Intel
Do you have any further update or concern on previous post community.intel.com/t5/Intel-Quartus-Prime-Software/Questa-not-opening/m-p/1524226#M79998?
Sheng
