I had a previous post about using runtime arguments in the Questa simulation flow that was solved, but that post used Quartus Pro simulation flow. Now I am using Quartus Lite and I want to see if there is a way to implement this with the Quartus Lite simulation flow. The flow is the same as in Quartus Standard Edition, found here. What I've tried doing is going to Assignment s> Settings > EDA Tool Settings > Simulation > More NativeLink Settings, and in the "Additional custom simulation elaboration options" field, I would add my runtime argument like "+RUNTIME_ARG". However, when I try this, nothing in the simulation changes. I didn't see any indication that adding the custom options there changes anything, so maybe that wasn't the right approach. Is there something else I can do?
I have never used these "additional custom simulation elaboration options" and haven't seen anyone use them before, so it's best to avoid them for now.
When using Nativelink, it automatically generates a .do file in your 'simulation' directory. You can modify it and add the arguments directly there.
Richard Tan
Dropping a note to ask if my last reply was helpful to you?
Do you need any further assistance from my side?
Richard Tan
I believe your inquiries are answered. Now, I will transition this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out.
Thank you and have a great day!
Richard Tan
Hi Richard,
Yes this answered my question. I just added my arguments to the generated do file and ran that. Thanks so much for the help.
Best,
Allen
![](/skins/images/7400F44FEAF4312DA521E61720D9D5D9/responsive_peak/images/icon_anonymous_message.png)
