OS: Ubuntu Xenial 16.04
Installation went through smoothly. Sadly quartus just crashes at startup. What is the best way to file a bug? $ ~/intelFPGA_lite/16.1/quartus/bin/quartus Inconsistency detected by ld.so: dl-close.c: 811: _dl_close: Assertion `map->l_init_called' failed! *** Error in `quartus': free(): invalid size: 0x00007fb3a337ff50 *** ======= Backtrace: ========= /lib/x86_64-linux-gnu/libc.so.6(+0x777e5)[0x7fb3ac3f67e5] /lib/x86_64-linux-gnu/libc.so.6(+0x7fe0a)[0x7fb3ac3fee0a] /lib/x86_64-linux-gnu/libc.so.6(cfree+0x4c)[0x7fb3ac40298c] /lib/x86_64-linux-gnu/libudev.so.1(+0x10a50)[0x7fb3a20e4a50] /lib/x86_64-linux-gnu/libudev.so.1(+0x90b1)[0x7fb3a20dd0b1] /lib/x86_64-linux-gnu/libudev.so.1(+0x7dbb)[0x7fb3a20dbdbb] /lib/x86_64-linux-gnu/libudev.so.1(+0x10238)[0x7fb3a20e4238] /lib/x86_64-linux-gnu/libudev.so.1(+0x105d7)[0x7fb3a20e45d7] /lib/x86_64-linux-gnu/libudev.so.1(udev_enumerate_scan_devices+0x26c)[0x7fb3a20da5ac] /home/primiano/intelFPGA_lite/16.1/quartus/linux64/libsys_cpt.so(+0xe0ab7)[0x7fb3b8926ab7] /home/primiano/intelFPGA_lite/16.1/quartus/linux64/libsys_cpt.so(Ox3476f8750e1da711+0x9)[0x7fb3b8926f19] /home/primiano/intelFPGA_lite/16.1/quartus/linux64/libsys_cpt.so(+0xb27f6)[0x7fb3b88f87f6] /home/primiano/intelFPGA_lite/16.1/quartus/linux64/libsys_cpt.so(Ox3476f8367c6535b1+0xc8)[0x7fb3b88f8328] /home/primiano/intelFPGA_lite/16.1/quartus/linux64/libsys_cpt.so(+0xa2e58)[0x7fb3b88e8e58] /home/primiano/intelFPGA_lite/16.1/quartus/linux64/libsys_cpt.so(lc_getid_type+0x57)[0x7fb3b88e95c7] /home/primiano/intelFPGA_lite/16.1/quartus/linux64/libsys_cpt.so(+0x55f13)[0x7fb3b889bf13] /home/primiano/intelFPGA_lite/16.1/quartus/linux64/libsys_cpt.so(+0x56064)[0x7fb3b889c064] /home/primiano/intelFPGA_lite/16.1/quartus/linux64/libsys_cpt.so(+0x39581)[0x7fb3b887f581] /home/primiano/intelFPGA_lite/16.1/quartus/linux64/libsys_cpt.so(_ZN11CPT_MANAGER16get_local_hostidE15CPT_HOSTID_TYPEPSt6vectorISsSaISsEE+0xa6)[0x7fb3b888385e] /home/primiano/intelFPGA_lite/16.1/quartus/linux64/libsys_cpt_guiq.so(+0x18507)[0x7fb3a210c507] /home/primiano/intelFPGA_lite/16.1/quartus/linux64/libsys_cpt_guiq.so(+0x18dd5)[0x7fb3a210cdd5] /home/primiano/intelFPGA_lite/16.1/quartus/linux64/libsys_cpt_guiq.so(cpt_guiq_dyn_init+0x1bb)[0x7fb3a20ffa1b] /home/primiano/intelFPGA_lite/16.1/quartus/linux64/libsys_qui.so(_ZN7QUI_APP13init_instanceEiPPKcP11QUI_CMDLINE+0x3ec)[0x7fb3e94a030e] /home/primiano/intelFPGA_lite/16.1/quartus/linux64/libsys_qgq.so(_ZN7QGQ_APP13init_instanceEiPPKcP11QUI_CMDLINE+0xdf)[0x7fb3e9a2c02d] quartus[0x401e9f] /home/primiano/intelFPGA_lite/16.1/quartus/linux64/libccl_msg.so(+0x407e0)[0x7fb3b7d6d7e0] /home/primiano/intelFPGA_lite/16.1/quartus/linux64/libccl_thr.so(+0x602c)[0x7fb3b50c502c] /home/primiano/intelFPGA_lite/16.1/quartus/linux64/libccl_msg.so(+0x4089f)[0x7fb3b7d6d89f] /home/primiano/intelFPGA_lite/16.1/quartus/linux64/libccl_mem.so(+0xa559)[0x7fb3b5736559] /home/primiano/intelFPGA_lite/16.1/quartus/linux64/libccl_err.so(+0x8f92)[0x7fb3b5503f92] /home/primiano/intelFPGA_lite/16.1/quartus/linux64/libccl_thr.so(thr_thread_wrapper+0x15)[0x7fb3b50c53f2] /home/primiano/intelFPGA_lite/16.1/quartus/linux64/libccl_msg.so(_Z12msg_exe_mainiPPKcPFiiS1_E+0xa3)[0x7fb3b7d6fc37] quartus[0x401f7a] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7fb3ac39f830] quartus[0x401d59]Link Copied
I have Quartus 17.0.1 running on my Ubuntu16.04 64 bits LTS. After the fresh instalation you just need to fix the following 2 errors: Fix error 1: intelFPGA/17.0/quartus/linux64/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by /usr/lib/x86_64-linux-gnu/libproxy.so.1) Failed to load module: /usr/lib/x86_64-linux-gnu/gio/modules/libgiolibproxy.so $ cd ~/intelFPGA/17.0/quartus/linux64 $ mv libstdc++.so.6 libstdc++.so.6.bak $ ln -s /usr/lib/x86_64-linux-gnu/libstdc++.so.6 libstdc++.so.6 Fix error 2: Inconsistency detected by ld.so: dl-close.c: 811: _dl_close: Assertion `map->l_init_called' failed! $ mv libccl_curl_drl.so libccl_curl_drl.so.bak
