hi
i use quartus ii 7.0 web edition + modelsim 6.1d to compile and simulate the ep2c35 development board which is within the quartus ii 7.0 software. i have no problem in complie process. however i got fatal error when i simulate in modelsim 6.1d just like below: run 500 # ** Error: function From_Hex: string "-- # Time: 0 ns Iteration: 0 Instance: /test_bench/the_ext_ssram/ext_ssram_lane3 # ** Fatal: (vsim-3471) Slice range (35 downto 32) does not belong to the prefix index range (11 downto 0). # Time: 0 ns Iteration: 0 Process: /test_bench/the_ext_ssram/ext_ssram_lane3/line__12001 File: D:/altera/projects/work/std_2C35.vhd # Fatal error at D:/altera/projects/work/std_2C35.vhd line 11977 i guess,,that would be sth wrong with the ssram but i can not find the point,,i m a new leaner. could u help me to shoot this problem. tks very much.!Link Copied
ModelSim works somewhat different than a HDL compiler, it's processing part of the code at runtime. Some errors, particularly range errors with indexes or overflow of variables is causing a runtime error. It's not certainly a real eror, some overflows are causing normal behaviour in RTL, only needing special handling with ModelSim. In your case, it looks like a real coding error, but this can't be seen without looking into the code, at the error location said in the message.
I didn't exactly understand about the design. Is it an example design shipped with the board? Did you modify it?![](/skins/images/7400F44FEAF4312DA521E61720D9D5D9/responsive_peak/images/icon_anonymous_message.png)
