ARM DS-5 compiler
naitgacem
Is it possible to use Intel SOC EDS without the ARM DS-5 compiler which requires a license ? What exactly are these 2 tools and what purpose does each one serve?
I want to program the HPS and run software on it baremetal (No Linux OS or other).
JingyangTeh
Hi naitgacem
There is a new IDE that is the RiscFree IDE. It is free to use.
https://www.intel.com/content/www/us/en/docs/programmable/730783/22-1std/about-the-ide.html
However the example projects are currently limited and still in the progress of being added.
Jingyang, Teh
JingyangTeh
Hi
Any update on this case?
Jingyang, Teh
naitgacem
Hello, I apologize for the late reply. I have Quartus 18.1 already installed and unfortuantely it does not support this new RiscFree IDE.
JingyangTeh
Hi naitgacem
Unfortunately there are no other option other than RiscFree and ArmDS5.
Is there are reason sticking to Quartus 18.1? The latest version of Quartus is now at 22.3.
Jingyang, Teh
naitgacem
This is such a nasty business model. The newer versions of Quartus lack IP blocks I need and used to be available for free. I have my reasons to stick to Quartus 18 including the already established developement environment. What about ARM-DS community edition license, how does one acquire it ?
JingyangTeh
Hi naigatcem
So sorry about that, we are moving forward with the RiscFree in the future which is free to use.
You could try the Arm DS5-compiler evaluation license.
https://developer.arm.com/documentation/dui0478/t/ris1367341319622
Jingyang, Teh
JingyangTeh
Hi
Jingyang, Teh
JingyangTeh
Hi
Since there are no feedback for this thread, I shall set this thread to close pending. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
