Hi all, I am printing my data from trasnceiver at UART output terminal (putty). My setup consists of a counter running at 100 Mhz. this counter is connected to transciever. The transceiver pll clock is also 100 MHz. Now when I try to print my coutner data which i received back in serial loopback of the transciever onto the ARM UART terminal. I am running Linux on arm. I have cyclone V Arrow Sockit board. Now my data is inconsistant like I am receiving 1,4,4,12,12,4,3,6,7,12,14,.... but I wana see consistent counter sequence like 1,2,3,4,5,6,7,...,15.
Any help please?
As I understand it, you seems to observe some issue with RX parallel data output display at UART output terminal.
By the way, I notice that you have filed another case 04274469, just would like to check with you if both of the cases 04274469 and 04274941 are similar? If they are the same, then we could follow up using a single case for better tracking purpose.
Regarding your RX parallel data output issue, we would require further debugging to further narrow down the issue. Just would like to check with you on the following:
1. Just wonder if you have had a chance to SignalTap the transceiver RX parallel data output to see if the output is something expected?
2. You may also cross check the SignalTap data with the UART terminal to see if there is any discrepancy.
3. Would you mind to share with me your transceiver Native PHY's .qsys file so that I can have a better understanding on your transceiver configuration.
Please let me know if there is any concern. Thank you.
Chee Pin
Thanks for your update and clarification. Seems like both the case get routed to me at the same time yesterday. I will set the 04274469 to close and we shall continue to follow up using this case.
Let's try to debug and isolate any potential issue at the transceiver level first before proceed to UART. If required, I will further engage UART expert for further assistance.
Would you mind to signaltap the Native PHY's status signals for me? This include reset, rx_is_lockedtoref, rx_islockedtodata, tx/rx_ready and the RX parallel data. This would be helpful for me to check if there is any anomaly as well as to check on the RX parallel data output at the Native PHY directly.
You may try to attach your signaltap file and the test design QAR directly to the Forum if it is something OK to viewing by public. My previous experience is that customer who open the Forum case can attach/upload file. Only me cannot attach to the thread. The server will prompt me some permission error. If the files are confidential, please feel free to let me know, I will drop you an email for sharing.
Chee Pin
Hi...
thanks for the reply. I am using Arrow Sockit Board with (cyclone V SoC chip 5CSXFC6D6F31C8). I have already emailed you the files. I am really sorry about the signal tap but the problem is that I dont know how to use it.
I shall try sending a fix pattern over the transceiver and see the result.
Thank you so much again for the support
Thanks for sharing the info on the Arrow SocKit eval board. For your information, as I look into the start guide (https://rocketboards.org/foswiki/pub/Documentation/ArrowSoCKitEvaluationBoard/SoCKit_Getting_Started_Guide.pdf) , I notice that the board has built in USB Blaster II. You can refer to the Figure 3-5 USB and Power Cables. It is a microB USB connector. Generally if you directly connect a USB cable to this, your Quartus will be able to detect and program the CV device through JTAG. You can use SignalTap with this USB Blaster II. Just would like to check with you how do you program the CV device currently?
Chee Pin
Thank you so much for your message. Oh I didn't know that the board has a build in USB blaster 2. Thanks a lot for letting me know. So that means that I take a usual USB cable, connect it to the USB Blaster 2 port and my quartus software will be able to detect it.
For now, to program my CV device, I convert my project.sof into project.rbf (raw binary file) using quartus software. Then I copy this project.rbf file into the fat partition of a micro SD card. Then I plug this MicroSD card into my CV device board. I then use uboot to program my CV device. It's a really time consuming and lengthy process because I have to remember many uboot script commands to program my CV device.
Thanks a lot again, I shall try this microUSB port to check if it is working as a USB blaster port? Thanks a lot again..
Just would like to follow up with you on this. Thank you.
Thanks again so much for your support and help. I just tested my design on signal tab logic analyzer. I noticed that the data sequence is perfectly fine. I have also emailed you the design files together with signal tab logic analyzer file so that you can also have a look. The transciever signals like rx_syncstatus and rx_pattern detect are also working fine. Now I am confident that my HDL design is all working fine.
But I still have issues with printing of inconsistent data on UART output terminal. I have the feeling that to display my data on UART terminal, I need to make a whole soc_system which requires to incorporate HPS into the design. Now I utilised Qsys tool in Quartus software to connect my HDL design with HPS. Now my transceiver's pll clock is 62.5MHz. I am running Linux on my HPS. So that means the Linux application that I wrote for the HPS to print my transceiver received parallel data onto the UART terminal is running on much lower clock than that of my transceiver's pll clock. Is it possible to involve an UART terminal expert who can help us in this issue?
Thanks for sharing the files. As I look into the SignalTap file, yes, your understanding is correct. Your XCVR design is working fine, all ready signals asserted, RX achieved sync and RX parallel data output is correct.
We will need to further engage our UART expert to provide further assistance. I will try to see if I can duplicate a case and route to UART team. If not, I will let you know to seek your help to open a new case so that I could route it.
Chee Pin
It seems like I am unable to duplicate a case from my side. Would you mind to help open a new case and add your latest note to the case as description? Please feel free to let me know the case number so that I could help to expedite the routing.
Chee Pin
Thank you so much for your support and help. I have created a new case here
Thank you so much for your support. I really appreciate your help. I shall keep you informed of the progress.
