ddr3 megawizard on cyclone V device
ramsoffer_123
Hey everyone,
Im trying to implement the DDR3 example from the megawizard in quartus 14.1 version.
Im using the Cyclone V Soc development Suite.
in the generation section Im getting those errors:
do you know maybe what is the problem?
(i uploaded the picture seperately for a better display).
thanks,
Ram.
AdzimZM_Intel
Hi Ram,
Thank you for submitting your question in Intel Community.
I'm Adzim from Penang Global Application Engineer will assist you in this thread.
I've tried to generate the example design in Quartus v14.1 and the generating process is successfully. I will attach the snapshot.
I may not use the exact IP parameter setting as your setup.
It's great if you can share the IP parameter setting for issue replication purpose.
Adzim
ramsoffer_123
Hey Adzim,
thank you for the fast answer.
Im using the Micron MT41K256M16HA -125 supplied by the Cyclone V Soc development suite.
the only parameter I changed is the speed grade = 8.
thanks,
Ram.
ramsoffer_123
hey,
I still didn't get answer for my problem.
can you figure it out what the problem is?
thanks,
BR,
Ram.
AdzimZM_Intel
Hi Ram,
I'm not able to replicate the issue from my end.
It's looks like a environmental issue when it's shown this errors.
Have you tried to generate it with different PC that has different OS?
What is the memory size that operate on your PC?
Adzim
ramsoffer_123
Hi Adzmin,
I don't think its a memory issue.
about the different OS - I tried to download that version from your download center but it says that there is no longer support
for that version.
in my company we need to work with that version on linux server. we are not working locally on the PC.
can you supply me the 14.1 version for windows and also  for linux so I can try to work on it locally and see if it works?
BR,
Ram.
AR_A_Intel
Hi
Pls share with me CNDA number and your details for verification purpose before I can request Quartus 14.1 version file to be share with you. Thanks.
Name:
Email Address:
Company Name:
Company Address:
CNDA number:
And for privacy, you can reply/attach your file in private message.
AR_A_Intel
We have not heard from you and It is not recommended to keep a Case idle too long without activities. I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
ramsoffer_123
hey to all,
sorry about the delay. we were in vacation.
i managed to succeed with that error.
thank you for all.
best regards,
Ram.
ramsoffer_123
there was a problem in the installation of the quartus.
