Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Help Verify
Squach
Ive been ate up with problems, virus?malware/unauthorized access.. each instance malice code has been found always showing the alphabet or months and days repeating then exploits in the errors created. This is a new install of win 2h20 and all was fine until intel drivers update now im seeing the alphabet thing appear in txt for running process.. Please verify
Logic problem? szsrc=
tyfD9 tsH
Component Categories
Failed to DeriveCapabilitySidsFromName with error=0x%x
Unexpected sid count
Failed to AllocateAndInitializeSid with error=0x%x
Failed to SetEntriesInAcl
Failed to InitializeSecurityDescriptor with error=0x%x
Failed to SetSecurityDescriptorDacl with error=0x%x
Unknown exception
Failed OpenSCManager()
Failed to LoadString!
Failed ChangeServiceConfig(SERVICE_AUTO_START, IDS_SERVICEDISPLAYNAME)!
Failed ChangeServiceConfig2(SERVICE_CONFIG_DESCRIPTION)!
Failed ChangeServiceConfig2(SERVICE_CONFIG_DELAYED_AUTO_START_INFO)!
Failed ChangeServiceConfig2(SERVICE_CONFIG_FAILURE_ACTIONS)!
Failed ChangeServiceConfig2(SERVICE_CONFIG_FAILURE_ACTIONS_FLAG)!
Failed ChangeServiceConfig2(SERVICE_CONFIG_SERVICE_SID_INFO)!
Failed ChangeServiceConfig2(SERVICE_CONFIG_REQUIRED_PRIVILEGES_INFO)!
Failed OpenService()
The AESM service is starting. PSW Version: %s
The AESM service is stopping or pausing.
Failed to create AESM service event
Failed to start AESM service
AESMRpcServerStart failed with error=0x%x
Bad service request
Service started/resumed
Could not open Service Manager
Could not open service
Could not stop service
Could not delete service
Could not start service
Handler not installed
Service stopped
bad array new length
invalid string position
vector too long
string too long
The service interface class has no CPPMICROSERVICES_DECLARE_SERVICE_INTERFACE macro
Service already exists.
Invalid service owner.
bad cast
Message text unavailable
Unknown error
Unknown error (%d)
The socket was closed due to a timeout
The operation timed out
Already open
End of file
Element not found
The descriptor does not fit into the select call's fd_set
asio.misc error
bad executor
class boost::asio::mutable_buffer __cdecl boost::beast::flat_static_buffer_base::prepare(unsigned __int64)
buffer overflow
class boost::beast::detail::buffers_pair<1> __cdecl boost::beast::static_buffer_base::prepare(unsigned __int64)
static_buffer overflow
bad address cast
The WebSocket stream was gracefully closed at both endpoints
The WebSocket operation caused a dynamic buffer overflow
The WebSocket stream produced an incomplete deflate block
The WebSocket message exceeded the locally configured limit
The WebSocket handshake was not HTTP/1.1
The WebSocket handshake method was not GET
The WebSocket handshake Host field is missing
The WebSocket handshake Connection field is missing
The WebSocket handshake Connection field is missing the upgrade token
The WebSocket handshake Upgrade field is missing
The WebSocket handshake Upgrade field is missing the websocket token
The WebSocket handshake Sec-WebSocket-Key field is missing
The WebSocket handshake Sec-WebSocket-Key field is invalid
The WebSocket handshake Sec-WebSocket-Version field is missing
The WebSocket handshake Sec-WebSocket-Version field is invalid
The WebSocket handshake Sec-WebSocket-Accept field is missing
The WebSocket handshake Sec-WebSocket-Accept field is invalid
The WebSocket handshake was declined by the remote peer
The WebSocket frame contained an illegal opcode
The WebSocket data frame was unexpected
The WebSocket continuation frame was unexpected
The WebSocket frame contained illegal reserved bits
The WebSocket control frame was fragmented
The WebSocket control frame size was invalid
The WebSocket frame was unmasked
The WebSocket frame was masked
The WebSocket frame size was not canonical
The WebSocket frame payload was not valid utf8
The WebSocket close frame reason code was invalid
The WebSocket close frame payload size was invalid
The WebSocket close frame payload was not valid utf8
The WebSocket handshake failed
end of stream
partial message
need more
unexpected body
need buffer
end of chunk
header limit exceeded
body limit exceeded
bad alloc
bad line ending
bad method
bad target
bad version
bad status
bad reason
bad field
bad value
bad Content-Length
bad Transfer-Encoding
bad chunk
bad chunk extension
bad obs-fold
stale parser
beast.http error
Switching Protocols
Non-Authoritative Information
No Content
Reset Content
Partial Content
Already Reported
Multiple Choices
Moved Permanently
See Other
Not Modified
Use Proxy
Temporary Redirect
Permanent Redirect
Bad Request
Payment Required
Not Found
Method Not Allowed
Not Acceptable
Proxy Authentication Required
Request Timeout
Length Required
Precondition Failed
Payload Too Large
URI Too Long
Unsupported Media Type
Range Not Satisfiable
Expectation Failed
Misdirected Request
Unprocessable Entity
Failed Dependency
Upgrade Required
Precondition Required
Too Many Requests
Request Header Fields Too Large
Connection Closed Without Response
Unavailable For Legal Reasons
Client Closed Request
Internal Server Error
Not Implemented
Bad Gateway
Service Unavailable
Gateway Timeout
HTTP Version Not Supported
Variant Also Negotiates
Insufficient Storage
Loop Detected
Not Extended
Network Authentication Required
Network Connect Timeout Error
need buffers
unexpected end of deflate stream
stream error
invalid block type
invalid stored block length
too many symbols
invalid code lengths
invalid bit length repeat
missing end of block code
invalid literal/length code
invalid distance code
invalid distance
over-subscribed length
incomplete length set
beast.zlib error
void __cdecl boost::beast::zlib::detail::deflate_stream::doReset(int,int,int,enum boost::beast::zlib::Strategy)
invalid level
invalid windowBits
invalid memLevel
void __cdecl boost::beast::zlib::detail::inflate_stream::doReset(int)
windowBits out of range
void __cdecl boost::beast::zlib::detail::inflate_stream::doWrite(struct boost::beast::zlib::z_params &,enum boost::beast::zlib::Flush,class boost::system::error_code &)
auto __cdecl boost::beast::zlib::detail::inflate_stream::inflate_table::<lambda_229dd1dfc3fa9661a1798e08ddc85292>::operator ()(void) const
insufficient output size when inflating tables
cdecl boost::beast::zlib::detail::inflate_stream::get_fixed_tables::fixed_codes::fixed_codes(void)
BOOST BEAST System Error in handle_request: %s
STD Exception in handle_request: %s
AESM will not bind to a TCP socket. Attempting to open the AESM_SOCKETS REGISTRY_SETTING_BIND_ADDR registry entry returned = %d
AESM will not bind to a TCP socket - Unable to find ':' while parsing the HOST:PORT in AESM_SOCKETS REGISTRY_SETTING_BIND_ADDR, which was set to: %s
AESM will not bind to a TCP socket - Invalid host or port value in AESM_SOCKETS REGISTRY_SETTING_BIND_ADDR, which was set to: %s
Exception parsing %s
Invalid port value in aesm_registry_entry_t::AESM_SOCKETS REGISTRY_SETTING_BIND_ADDR: %s
BOOST BEAST System Error in AesmAcceptorLoop: %s
STD Exception in in AesmAcceptorLoop: %s
list too long
void __cdecl boost::beast::static_string<28,char,struct std::char_traits<char> >::resize(unsigned __int64)
cdecl boost::beast::static_string<512,char,struct std::char_traits<char> >::static_string(const char *)
class boost::beast::static_string<512,char,struct std::char_traits<char> > &__cdecl boost::beast::static_string<512,char,struct std::char_traits<char> >::insert(unsigned __int64,const char *,unsigned __int64)
void __cdecl boost::beast::websocket::stream<class boost::asio::basic_stream_socket<class boost::asio::ip::tcp,class boost::asio::executor>,1>::accept(void)
unsigned __int64 __cdecl boost::beast::websocket::stream<class boost::asio::basic_stream_socket<class boost::asio::ip::tcp,class boost::asio::executor>,1>::read<class boost::beast::basic_flat_buffer<class std::allocator<char> >>(class boost::beast::basic_flat_buffer<class std::allocator<char> > &)
unsigned __int64 __cdecl boost::beast::websocket::stream<class boost::asio::basic_stream_socket<class boost::asio::ip::tcp,class boost::asio::executor>,1>::write<class boost::asio::const_buffers_1>(const class boost::asio::const_buffers_1 &)
struct boost::beast::http::basic_fields<class std::allocator<char> >::element &__cdecl boost::beast::http::basic_fields<class std::allocator<char> >::new_element(enum boost::beast::http::field,class boost::basic_string_view<char,struct std::char_traits<char> >,class boost::basic_string_view<char,struct std::char_traits<char> >)
field name too large
field value too large
void __cdecl boost::beast::static_string<11,char,struct std::char_traits<char> >::resize(unsigned __int64)
unsigned __int64 __cdecl boost::basic_string_view<char,struct std::char_traits<char> >::copy(char *,unsigned __int64,unsigned __int64) const
void __cdecl boost::beast::http::header<1,class boost::beast::http::basic_fields<class std::allocator<char> > >::method(enum boost::beast::http::verb)
unknown method
class boost::asio::mutable_buffer __cdecl boost::beast::basic_flat_buffer<class std::allocator<char> >::prepare(unsigned __int64)
basic_flat_buffer too long
void __cdecl boost::beast::http::message<0,struct boost::beast::http::basic_string_body<char,struct std::char_traits<char>,class std::allocator<char> >,class boost::beast::http::basic_fields<class std::allocator<char> > >::prepare_payload(struct std::integral_constant<bool,0>)
invalid response body
void __cdecl boost::beast::static_string<123,char,struct std::char_traits<char> >::resize(unsigned __int64)
void __cdecl boost::beast::static_string<125,char,struct std::char_traits<char> >::resize(unsigned __int64)
iostream stream error
bad locale name
ios_base::badbit set
ios_base::failbit set
ios_base::eofbit set
This program requires version
of the Protocol Buffer runtime library, but the installed version is
This program was compiled against version
of the Protocol Buffer runtime library, which is not compatible with the installed version (
). Contact the program author for an update. If you compiled the program yourself, make sure that your headers are from the same version of Protocol Buffers as your link-time library. (Version verification failed in "
bytes). To increase the limit (or to disable these warnings), see CodedInputStream::SetTotalBytesLimit() in third_party/protobuf/src/google/protobuf/io/coded_stream.h.
CHECK failed: (min_bytes) <= (std::numeric_limits<size_t>::max() - kBlockHeaderSize):
(cannot determine missing fields for lite message)
MessageLite at 0x
CHECK failed: (byte_size_before_serialization) == (byte_size_after_serialization):
was modified concurrently during serialization.
CHECK failed: (bytes_produced_by_serialization) == (byte_size_before_serialization):
Byte size calculation and serialization were inconsistent. This may indicate a bug in protocol buffers or it may be caused by concurrent modification of
This shouldn't be called if all the sizes are equal.
message of type "
exceeded maximum protobuf size of 2GB:
Not implemented field number
CHECK failed: (scc->visit_status.load(std::memory_order_relaxed)) == (SCCInfoBase::kRunning):
with type
Can't happen
Division or mod by zero: dividend.hi=
CHECK failed: dest:
FastHexToBuffer() wants non-negative integers, not
CHECK failed: value != nullptr:
nullptr output boolean given.
This can't happen; base64 decoder state =
CHECK failed: result != nullptr:
This ZeroCopyOutputStream doesn't support aliasing. Reaching here usually means a ZeroCopyOutputStream implementation bug.
BackUp() can only be called after a successful Next().
Cannot allocate buffer larger than kint32max for
BackUp() can only be called after Next().
Can't back up over more bytes than were returned by the last call to Next().
Parameter to BackUp() can't be negative.
CHECK failed: !is_closed_:
Can't BackUp() after failed Next().
Requested size is too large to fit into size_t.
map/set too long
can't reach here.
Multiple extension registrations for type "
CHECK failed: (type) != (WireFormatLite::TYPE_ENUM):
CHECK failed: (type) != (WireFormatLite::TYPE_MESSAGE):
CHECK failed: (type) != (WireFormatLite::TYPE_GROUP):
CHECK failed: (type) == (WireFormatLite::TYPE_ENUM):
CHECK failed: type == WireFormatLite::TYPE_MESSAGE || type == WireFormatLite::TYPE_GROUP:
Don't lookup extension types if they aren't present (1).
Don't lookup extension types if they aren't present (2).
CHECK failed: extension != NULL:
Index out-of-bounds (field is empty).
Extension not found.
Non-primitive types can't be packed.
Can't get here.
Invalid message set extension.
unordered_map/set too long
invalid hash bucket count
String field
contains invalid
UTF-8 data when
buffer. Use the 'bytes' type if you intend to send raw
CHECK failed: (v.size()) <= (kStringPrintfVectorMaxArgs):
StringPrintfVector currently only supports up to
Feel free to add support for more if you need it.
bad allocation
bad function call
regex_error(error_collate): The expression contained an invalid collating element name.
regex_error(error_ctype): The expression contained an invalid character class name.
regex_error(error_escape): The expression contained an invalid escaped character, or a trailing escape.
regex_error(error_backref): The expression contained an invalid back reference.
regex_error(error_brack): The expression contained mismatched [ and ].
regex_error(error_paren): The expression contained mismatched ( and ).
regex_error(error_brace): The expression contained mismatched { and }.
regex_error(error_badbrace): The expression contained an invalid range in a { expression }.
regex_error(error_range): The expression contained an invalid character range, such as [b-a] in most encodings.
regex_error(error_space): There was insufficient memory to convert the expression into a finite state machine.
regex_error(error_badrepeat): One of *?+{ was not preceded by a valid regular expression.
regex_error(error_complexity): The complexity of an attempted match against a regular expression exceeded a pre-set level.
regex_error(error_stack): There was insufficient memory to determine whether the regular expression could match the specified character sequence.
device or resource busy
invalid argument
no such process
not enough memory
operation not permitted
resource deadlock would occur
resource unavailable try again
invalid random_device value
unknown error
ERROR : Unable to initialize critical section in CAtlBaseModule
address family not supported
address in use
address not available
already connected
argument list too long
argument out of domain
bad address
bad file descriptor
bad message
broken pipe
connection aborted
connection already in progress
connection refused
connection reset
cross device link
destination address required
directory not empty
executable format error
file exists
file too large
filename too long
function not supported
host unreachable
identifier removed
illegal byte sequence
inappropriate io control operation
invalid seek
io error
is a directory
message size
network down
network reset
network unreachable
no buffer space
no child process
no lock available
no message available
no message
no protocol option
no space on device
no stream resources
no such device or address
no such device
no such file or directory
not a directory
not a socket
not a stream
not connected
not supported
operation canceled
operation in progress
operation not supported
operation would block
owner dead
permission denied
protocol error
protocol not supported
read only file system
result out of range
state not recoverable
stream timeout
text file busy
timed out
too many files open in system
too many files open
too many links
too many symbolic link levels
value too large
wrong protocol type
bad exception
local static guard'
vbase destructor'
vector deleting destructor'
default constructor closure'
scalar deleting destructor'
vector constructor iterator'
vector destructor iterator'
vector vbase constructor iterator'
virtual displacement map'
eh vector constructor iterator'
eh vector destructor iterator'
eh vector vbase constructor iterator'
copy constructor closure'
udt returning'
local vftable'
local vftable constructor closure'
omni callsig'
placement delete closure'
placement delete[] closure'
managed vector constructor iterator'
managed vector destructor iterator'
eh vector copy constructor iterator'
eh vector vbase copy constructor iterator'
dynamic initializer for '
dynamic atexit destructor for '
managed vector copy constructor iterator'
local static thread guard'
operator co_await
Type Descriptor'
Base Class Descriptor at (
Base Class Array'
Class Hierarchy Descriptor'
Complete Object Locator'
anonymous namespace'
local static destructor helper'
template static data member constructor helper'
template static data member destructor helper'
unknown ecsu'
Visual C++ CRT: Not enough memory to complete call to strerror.
Runtime Error!
Microsoft Visual C++ Runtime Library
No error
Operation not permitted
No such file or directory
No such process
Interrupted function call
Input/output error
No such device or address
Arg list too long
Exec format error
Bad file descriptor
No child processes
Resource temporarily unavailable
Not enough space
Permission denied
Bad address
Resource device
File exists
Improper link
No such device
Not a directory
Is a directory
Invalid argument
Too many open files in system
Too many open files
Inappropriate I/O control operation
File too large
No space left on device
Invalid seek
Read-only file system
Too many links
Broken pipe
Domain error
Result too large
Resource deadlock avoided
Filename too long
No locks available
Function not implemented
Directory not empty
Illegal byte sequence
american english
english-south africa
english-trinidad y tobago
spanish-costa rica
spanish-dominican republic
spanish-el salvador
spanish-puerto rico
great britain
pr china
south africa
south korea
trinidad & tobago
SGX.AESM.1 = s 'AESMInterface Class'
SGX.AESM = s 'AESMInterface Class'
CurVer = s 'SGX.AESM.1'
NoRemove CLSID
ForceRemove {82367CAB-F2B9-461A-B6C6-889D13EFC6CA} = s 'AESMInterface Class'
ProgID = s 'SGX.AESM.1'
VersionIndependentProgID = s 'SGX.AESM'
LocalServer32 = s '%MODULE%'
val ServerExecutable = s '%MODULE_RAW%'
val AppID = s '%APPID%'
Intel Corporation
SGX Application Enclave Services Manager
Copyright (C) 2021 Intel Corporation
SGX AESM_The system services management agent for Intel
Software Guard Extensions enabled applications.
AESMService: %1
Santa Clara1
Intel Corporation1%0#
Intel External Issuing CA 7B0
Santa Clara1
Intel Corporation1/0-
&Intel(R) Software Development Products0
Greater Manchester1
COMODO CA Limited1+0)
"COMODO RSA Certification Authority0
Santa Clara1
Santa Clara1
Santa Clara1
Intel Corporation1&0
QuoVadis Limited1%0#
Root Certification Authority1.0,
QuoVadis Limited1
QuoVadis Issuing CA G40
QuoVadis Limited1
Santa Clara1
QuoVadis Limited1
QuoVadis Limited1
Microsoft Corporation1806
/Microsoft Windows Third Party Component CA 20120
Microsoft Corporation1;09
2Microsoft Windows Hardware Compatibility Publisher0
Microsoft Operations Puerto Rico1
Microsoft Corporation1200
)Microsoft Root Certificate Authority 20100
Microsoft Corporation1)0'
Microsoft Operations Puerto Rico1&0
Microsoft Time-Stamp Service
Microsoft Corporation1&0
Microsoft Time-Stamp PCA 20100
Microsoft Time-Stamp Service0
"Intel Corporatio
Legal_Policy_Statement
Redmond1
Washington1
Redmond1
Washington1
Redmond1
Washington1
Redmond1
Washington1
1http://www.microsoft.com/PKI/docs/CPS/default.htm0@
>http://www.microsoft.com/pki/certs/MicRooCerAut_2010-06-23.crt0
Ehttp://crl.microsoft.com/pki/crl/products/MicRooCerAut_2010-06-23.crl0Z
Redmond1
Washington1
Redmond1
Washington1
>http://www.microsoft.com/pki/certs/MicTimStaPCA_2010-07-01.crt0
Ehttp://crl.microsoft.com/pki/crl/products/MicTimStaPCA_2010-07-01.crl0Z
Redmond1
Washington1
Redmond1
Washington1
Redmond1
Washington1
(https://www.microsoft.com/en-us/windows 0
Redmond1
Washington1
Redmond1
Washington1
Redmond1
Washington1
ehttp://www.microsoft.com/pkiops/certs/Microsoft%20Windows%20Third%20Party%20Component%20CA%202012.crt0
chttp://www.microsoft.com/pkiops/crl/Microsoft%20Windows%20Third%20Party%20Component%20CA%202012.crl0
Redmond1
Washington1
Redmond1
Washington1
)http://crl.quovadisglobal.com/qvicag4.crl0
(http://www.quovadisglobal.com/repository0
+http://trust.quovadisglobal.com/qvicag4.crt0O
http://ocsp.quovadisglobal.com07
timestamp.intel.com0
'http://crl.quovadisglobal.com/qvrca.crl0
)http://trust.quovadisglobal.com/qvrca.crt0
http://ocsp.quovadisglobal.com05
%QuoVadis Root Certification Authority0
timestamp.intel.com
intel.com0
intel.com0
http://ocsp.comodoca.com05
/http://crt.comodoca.com/COMODORSAAddTrustCA.crt0
;http://crl.comodoca.com/COMODORSACertificationAuthority.crl0q
Salford1
http://OCSP.intel.com/0
&http://pki.intel.com/crt/IntelCA7B.crt0"
&http://pki.intel.com/crl/IntelCA7B.crl0f
testLevelName255
testLevelName16
win:Informational
win:Warning
win:Error
win:Critical
AESMService
<assembly xmlns="urn:schemas-microsoft-com:asm.v1" manifestVersion="1.0"><trustInfo xmlns="urn:schemas-microsoft-com:asm.v3"><security><requestedPrivileges><requestedExecutionLevel level="asInvoker" uiAccess="false"></requestedExecutionLevel></requestedPrivileges></security></trustInfo><application xmlns="urn:schemas-microsoft-com:asm.v3"><windowsSettings><dpiAware xmlns="http://schemas.microsoft.com/SMI/2005/WindowsSettings">true</dpiAware></windowsSettings></application></assembly>
EventData
EventData
attrAnsiString
attrAnsiString
attrUnicodeString
attrUnicodeString
Application
SGX/Diagnostic
SGX/Admin
Application
Information
Warning
Critical
AESMService
Translation
VarFileInfo
ProductVersion
ProductName
aesm_service.exe
OriginalFilename
InternalName
LegalCopyright
FileVersion
FileDescription
CompanyName
StringFileInfo
VS_VERSION_INFO
WEVT_TEMPLATE
REGISTRY
RtlUnwind
WriteConsoleW
GetProcessHeap
FreeEnvironmentStringsW
GetEnvironmentStringsW
GetCommandLineA
IsValidCodePage
FindFirstFileExW
GetTimeZoneInformation
GetFileSizeEx
SetConsoleCtrlHandler
SetFilePointerEx
SetEndOfFile
SetStdHandle
FlushFileBuffers
EnumSystemLocalesW
GetUserDefaultLCID
IsValidLocale
GetLocaleInfoW
LCMapStringW
CompareStringW
GetTimeFormatW
GetDateFormatW
HeapReAlloc
HeapSize
GetCurrentThread
HeapAlloc
HeapFree
ExitProcess
GetStdHandle
GetConsoleCP
WriteFile
ReadConsoleW
GetConsoleMode
ReadFile
DuplicateHandle
FileTimeToSystemTime
SystemTimeToTzSpecificLocalTime
PeekNamedPipe
GetFileInformationByHandle
GetDriveTypeW
GetFileType
CreateFileW
GetFileAttributesExW
CreateDirectoryW
SetCurrentDirectoryW
SetEnvironmentVariableW
FreeLibraryAndExitThread
ResumeThread
ExitThread
CreateThread
FlsFree
FlsSetValue
FlsGetValue
FlsAlloc
InterlockedFlushSList
InterlockedPushEntrySList
RtlUnwindEx
GetStartupInfoW
InitializeSListHead
GetSystemTimeAsFileTime
GetCurrentProcessId
IsProcessorFeaturePresent
TerminateProcess
GetCurrentProcess
SetUnhandledExceptionFilter
RtlVirtualUnwind
RtlLookupFunctionEntry
RtlCaptureContext
GetCPInfo
CompareStringEx
GetLocaleInfoEx
LCMapStringEx
EncodePointer
SleepConditionVariableSRW
SleepConditionVariableCS
WakeAllConditionVariable
WakeConditionVariable
InitializeConditionVariable
RtlPcToFileHeader
GetStringTypeW
InitOnceExecuteOnce
TryEnterCriticalSection
TryAcquireSRWLockExclusive
ReleaseSRWLockExclusive
InitializeSRWLock
GetNativeSystemInfo
GetExitCodeThread
SwitchToThread
WaitForSingleObjectEx
GetSystemTimePreciseAsFileTime
QueryPerformanceFrequency
QueryPerformanceCounter
OutputDebugStringW
IsDebuggerPresent
api-ms-win-security-base-l1-2-2.dll
ADVAPI32.dll
OLEAUT32.dll
USER32.dll
KERNEL32.dll
GetCurrentDirectoryW
C_specific_handler
WSAStringToAddressW
WSAAddressToStringW
WSASocketW
WideCharToMultiByte
VerifyVersionInfoW
FormatMessageW
FormatMessageA
TlsFree
TlsSetValue
TlsGetValue
TlsAlloc
TerminateThread
QueueUserAPC
CreateWaitableTimerW
WaitForMultipleObjects
SetWaitableTimer
SleepEx
SetEvent
InitializeCriticalSectionAndSpinCount
PostQueuedCompletionStatus
GetQueuedCompletionStatus
CreateIoCompletionPort
SetLastError
VerSetConditionMask
GetModuleHandleExW
GetModuleFileNameA
WaitForSingleObject
GetFullPathNameW
FindNextFileW
FindFirstFileW
FindClose
SetEntriesInAclW
StartServiceCtrlDispatcherW
SetServiceStatus
RegisterServiceCtrlHandlerW
OpenServiceW
OpenSCManagerW
DeleteService
CreateServiceW
ControlService
CloseServiceHandle
ChangeServiceConfig2W
ChangeServiceConfigW
CoTaskMemFree
CoTaskMemRealloc
CoTaskMemAlloc
CoCreateInstance
CoReleaseServerProcess
CoAddRefServerProcess
RegGetValueW
RegSetValueExW
RegQueryValueExW
RegQueryInfoKeyW
RegDeleteValueW
RegDeleteKeyW
RegCreateKeyExW
RegCloseKey
MultiByteToWideChar
MessageBoxW
CharNextW
CharUpperW
ReportEventW
RegisterEventSourceW
DeregisterEventSource
LocalFree
FreeSid
LoadLibraryW
FindResourceW
SizeofResource
LoadStringW
LoadResource
LoadLibraryExW
GetProcAddress
GetModuleHandleW
GetModuleFileNameW
FreeLibrary
GetCurrentThreadId
CreateEventW
ResetEvent
LeaveCriticalSection
CloseHandle
GetCommandLineW
UnregisterClassW
DeleteCriticalSection
InitializeCriticalSectionEx
GetLastError
RaiseException
DecodePointer
RPCRT4.dll
RpcEpUnregister
RpcEpRegisterW
RpcMgmtStopServerListening
RpcServerUseProtseqEpW
RpcServerUnregisterIf
RpcServerRegisterIf3
RpcServerListen
RpcServerInqBindings
RpcBindingVectorFree
Ndr64AsyncServerCallAll
NdrAsyncServerCall
RpcAsyncCompleteCall
utils.dll
?aesm_write_registry_stringa@@YA?AW4_ae_error_t@@W4_aesm_registry_entry_t@@PEBD1I@Z
?aesm_read_registry_stringa@@YA?AW4_ae_error_t@@W4_aesm_registry_entry_t@@PEBDQEADI@Z
CppMicroServices4.dll
??1ServiceException@cppmicroservices@@UEAA@XZ
??0ServiceException@cppmicroservices@@QEAA@AEBV01@@Z
??1FrameworkEvent@cppmicroservices@@QEAA@XZ
?NewFramework@FrameworkFactory@cppmicroservices@@QEAA?AVFramework@2@XZ
??1Framework@cppmicroservices@@UEAA@XZ
duration@_JU?
?WaitForStop@Framework@cppmicroservices@@QEAA?AVFrameworkEvent@2@AEBV?
?Init@Framework@cppmicroservices@@QEAAXXZ
??4BundleContext@cppmicroservices@@QEAAAEAV01@
??1BundleContext@cppmicroservices@@QEAA@XZ
char_traits@D@std@@V?
basic_string@DU?
allocator@VBundle@cppmicroservices@@@std@@@std@@AEBV?
vector@VBundle@cppmicroservices@@V?
?InstallBundles@BundleContext@cppmicroservices@@QEAA?AV?
shared_ptr@X@std@@AEBVServiceReferenceBase@2@@Z
?GetService@BundleContext@cppmicroservices@@QEAA?AV?
basic_string@DU?
ServiceReference@X@2@AEBV?
?GetServiceReference@BundleContext@cppmicroservices@@QEAA?AV?
allocator@VBundle@cppmicroservices@@@std@@@std@@XZ
?GetBundles@BundleContext@cppmicroservices@@QEBA?AV?
??BBundleContext@cppmicroservices@@QEBA_NXZ
??0BundleContext@cppmicroservices@@QEAA@XZ
basic_string@DU?
?SetInterfaceId@ServiceReferenceBase@cppmicroservices@@AEAAXAEBV?
basic_string@DU?
?IsConvertibleTo@ServiceReferenceBase@cppmicroservices@@QEBA_NAEBV?
allocator@D@2@@std@@XZ
basic_string@DU?
?GetInterfaceId@ServiceReferenceBase@cppmicroservices@@QEBA?AV?
?GetBundle@ServiceReferenceBase@cppmicroservices@@QEBA?AVBundle@2@XZ
??1ServiceReferenceBase@cppmicroservices@@QEAA@XZ
??4ServiceReferenceBase@cppmicroservices@@QEAAAEAV01@
??BServiceReferenceBase@cppmicroservices@@QEBA_NXZ
??0ServiceReferenceBase@cppmicroservices@@QEAA@AEBV01@@Z
allocator@D@2@@std@@AEBVtype_info@@@Z
basic_string@DU?
?GetDemangledName@detail@cppmicroservices@@YA?AV?
allocator@D@2@@std@@AEBW4Type@01@@Z
basic_string@DU?
??0ServiceException@cppmicroservices@@QEAA@AEBV?
?Stop@Bundle@cppmicroservices@@QEAAXXZ
?Start@Bundle@cppmicroservices@@QEAAXXZ
?GetVersion@Bundle@cppmicroservices@@QEBA?AVBundleVersion@2@XZ
?GetBundleContext@Bundle@cppmicroservices@@QEBA?AVBundleContext@2@XZ
??BBundle@cppmicroservices@@QEBA_NXZ
??1Bundle@cppmicroservices@@UEAA@XZ
??1BundleVersion@cppmicroservices@@QEAA@XZ
?GetMajor@BundleVersion@cppmicroservices@@QEBAIXZ
.?AVpairNode@@
.?AVDNameStatusNode@@
.?AVpDNameNode@@
.?AVpcharNode@@
.?AVcharNode@@
.?AVDNameNode@@
ostreambuf_iterator@DU?
time_put@DV?
istreambuf_iterator@DU?
time_get@DV?
moneypunct@D
Mpunct@D@std@@
moneypunct@D
money_put@DV?
money_get@DV?
messages@D@std@@
collate@D@std@@
ostreambuf_iterator@GU?
time_put@GV?
istreambuf_iterator@GU?
time_get@GV?
moneypunct@G
Mpunct@G@std@@
moneypunct@G
money_put@GV?
money_get@GV?
messages@G@std@@
collate@G@std@@
numpunct@G@std@@
num_put@GV?
num_get@GV?
ostreambuf_iterator@_WU?
istreambuf_iterator@_WU?
moneypunct@_W
moneypunct@_W
money_put@_WV?
money_get@_WV?
messages@_W@std@@
numpunct@_W@std@@
.?AUmoney_base@std@@
.?AUmessages_base@std@@
codecvt@GDU_Mbstatet@@@std@@
codecvt@_WDU_Mbstatet@@@std@@
codecvt@DDU_Mbstatet@@@std@@
num_get@DV?
.?AVcodecvt_base@std@@
.?AVstl_condition_variable_win7@details@Concurrency@@
.?AVstl_condition_variable_vista@details@Concurrency@@
.?AVstl_condition_variable_interface@details@Concurrency@@
ExceptionPtr_static@Vbad_exception@std@@@?A0xe7b3fade@@
ExceptionPtr_static@Vbad_alloc@std@@@?A0xe7b3fade@@
.?AV_ExceptionPtr_normal@?A0xe7b3fade@@
.?AVbad_exception@std@@
.?AV_Locimp@locale@std@@
.?AV_System_error_category@std@@
.?AVstl_critical_section_win7@details@Concurrency@@
.?AVstl_critical_section_vista@details@Concurrency@@
.?AVstl_critical_section_interface@details@Concurrency@@
.?AVregex_error@std@@
.?AVbad_function_call@std@@
.?AVoverflow_error@std@@
basic_stringstream@_WU?
basic_stringbuf@_WU?
basic_iostream@_WU?
basic_ostream@_WU?
basic_istream@_WU?
basic_streambuf@_WU?
basic_ios@_WU?
.?AVGeneratedExtensionFinder@internal@protobuf@google@@
.?AVExtensionFinder@internal@protobuf@google@@
.?AVCodedOutputStreamFieldSkipper@internal@protobuf@google@@
.?AVFieldSkipper@internal@protobuf@google@@
CBHUExtension@ExtensionSet@internal@protobuf@google@@@std@@@7@@std@@
allocator@U?
map@HUExtension@ExtensionSet@internal@protobuf@google@@U?
RepeatedPtrField@VMessageLite@protobuf@google@@@protobuf@google@@
allocator@D@2@@std@@@protobuf@google@@
basic_string@DU?
RepeatedPtrField@V?
RepeatedField@_N@protobuf@google@@
RepeatedField@N@protobuf@google@@
RepeatedField@M@protobuf@google@@
RepeatedField@_K@protobuf@google@@
RepeatedField@I@protobuf@google@@
RepeatedField@_J@protobuf@google@@
RepeatedField@H@protobuf@google@@
.?AUKeyValue@ExtensionSet@internal@protobuf@google@@
basic_string@DU?
.?AVImplicitWeakMessage@internal@protobuf@google@@
.?AVConcatenatingInputStream@io@protobuf@google@@
.?AVCopyingOstreamOutputStream@OstreamOutputStream@io@protobuf@google@@
.?AVOstreamOutputStream@io@protobuf@google@@
.?AVCopyingIstreamInputStream@IstreamInputStream@io@protobuf@google@@
.?AVIstreamInputStream@io@protobuf@google@@
.?AVCopyingFileOutputStream@FileOutputStream@io@protobuf@google@@
.?AVFileOutputStream@io@protobuf@google@@
.?AVCopyingFileInputStream@FileInputStream@io@protobuf@google@@
.?AVFileInputStream@io@protobuf@google@@
.?AVCopyingOutputStream@io@protobuf@google@@
.?AVCopyingInputStream@io@protobuf@google@@
.?AVLimitingInputStream@io@protobuf@google@@
.?AVCopyingOutputStreamAdaptor@io@protobuf@google@@
.?AVCopyingInputStreamAdaptor@io@protobuf@google@@
.?AVStringOutputStream@io@protobuf@google@@
.?AVArrayOutputStream@io@protobuf@google@@
.?AVArrayInputStream@io@protobuf@google@@
numpunct@D@std@@
num_put@DV?
.?AVZeroCopyOutputStream@io@protobuf@google@@
.?AVZeroCopyInputStream@io@protobuf@google@@
.?AVZeroCopyCodedInputStream@protobuf@google@@
.?AVFunctionClosure0@internal@protobuf@google@@
.?AVClosure@protobuf@google@@
.?AUctype_base@std@@
.?AVfacet@locale@std@@
.?AV_Iostream_error_category@std@@
.?AV_Generic_error_category@std@@
.?AVerror_category@std@@
basic_ostringstream@DU?
basic_stringbuf@DU?
basic_ostream@DU?
basic_streambuf@DU?
basic_ios@DU?
.?AVFatalException@protobuf@google@@
.?AVfailure@ios_base@std@@
.?AV_System_error@std@@
.?AVsystem_error@std@@
00@websocket@beast@boost@@@detail@5@@detail@boost@@
basic_stream_socket@Vtcp@ip@asio@boost@@Vexecutor@34@@asio@boost@@
stream@V?
sp_ms_deleter@Uimpl_type@?
00@websocket@beast@boost@@V?
stream@V?
sp_counted_impl_pd@PEAUimpl_type@?
allocator@X@std@@@executor@asio@boost@@
impl@Vexecutor_type@io_context@asio@boost@@V?
Ref_count_resource@PEAXUnoop_deleter@socket_ops@detail@asio@boost@@@std@@
Ref_count_obj2@Usequence@chunk_size@detail@http@beast@boost@@@std@@
func@Utimer_thread_function@win_iocp_io_context@detail@asio@boost@@@win_thread@detail@asio@boost@@
func@Uthread_function@win_iocp_io_context@detail@asio@boost@@@win_thread@detail@asio@boost@@
.?AVwin_iocp_socket_service_base@detail@asio@boost@@
win_iocp_socket_service@Vtcp@ip@asio@boost@@@detail@asio@boost@@@detail@asio@boost@@
execution_context_service_base@V?
00@detail@websocket@beast@boost@@
impl_base@
empty_value@V?
stream@V?
.?AVMessageLite@protobuf@google@@
.?AUbasic_parser_base@detail@http@beast@boost@@
00@http@beast@boost@@
basic_parser@
allocator@D@std@@@http@beast@boost@@
00Uempty_body@http@beast@boost@@V?
enable_shared_from_this@Vimpl_type@service@detail@websocket@beast@boost@@@boost@@
.?AVimpl_type@service@detail@websocket@beast@boost@@
service_base@Vservice@detail@websocket@beast@boost@@@detail@beast@boost@@
.?AVservice@detail@websocket@beast@boost@@
.?AVerror_codes@detail@zlib@beast@boost@@
.?AVhttp_error_category@detail@http@beast@boost@@
.?AVerror_conditions@detail@websocket@beast@boost@@
.?AVerror_codes@detail@websocket@beast@boost@@
wait_traits@Usteady_clock@chrono@std@@@asio@boost@@@detail@asio@boost@@@detail@asio@boost@@
chrono_time_traits@Usteady_clock@chrono@std@@U?
timer_queue@U?
wait_traits@Usteady_clock@chrono@std@@@asio@boost@@@detail@asio@boost@@@detail@asio@boost@@@detail@asio@boost@@
deadline_timer_service@U?
.?AVimpl_base@executor@asio@boost@@
.?AVsp_counted_base@detail@boost@@
.?AVtimer_queue_base@detail@asio@boost@@
execution_context_service_base@Vwin_iocp_io_context@detail@asio@boost@@@detail@asio@boost@@
.?AVwin_iocp_io_context@detail@asio@boost@@
.?AVfunc_base@win_thread@detail@asio@boost@@
.?AVthread_context@detail@asio@boost@@
.?AVnoncopyable@detail@asio@boost@@
.?AVservice@execution_context@asio@boost@@
.?AVmisc_category@detail@error@asio@boost@@
.?AVerror_conditions@detail@beast@boost@@
.?AVerror_codes@detail@beast@boost@@
.?AVsystem_error_category@detail@system@boost@@
.?AVgeneric_error_category@detail@system@boost@@
.?AVerror_category@system@boost@@
typeid_wrapper@V?
allocator@D@2@@std@@VInternalMetadataWithArenaLite@internal@protobuf@google@@@internal@protobuf@google@@
basic_string@DU?
InternalMetadataWithArenaBase@V?
.?AUContainer@?
typeid_wrapper@V?
00@websocket@beast@boost@@@detail@boost@@
stream@V?
.?AVexecutor_type@io_context@asio@boost@@
typeid_wrapper@Vwin_iocp_io_context@detail@asio@boost@@@detail@asio@boost@@
.?AUnoop_deleter@socket_ops@detail@asio@boost@@
.?AVResponse@message@aesm@@
.?AVResponse_GetSupportedAttKeyIDsResponse@message@aesm@@
.?AVResponse_GetSupportedAttKeyIDNumResponse@message@aesm@@
.?AVResponse_UnsupportedRequestResponse@message@aesm@@
.?AVResponse_GetQuoteExResponse@message@aesm@@
.?AVResponse_GetQuoteSizeExResponse@message@aesm@@
.?AVResponse_InitQuoteExResponse@message@aesm@@
.?AVResponse_SelectAttKeyIDResponse@message@aesm@@
.?AVResponse_SGXRegisterResponse@message@aesm@@
.?AVResponse_SGXSwitchExtendedEpidGroupResponse@message@aesm@@
.?AVResponse_SGXGetExtendedEpidGroupIdResponse@message@aesm@@
.?AVResponse_GetWhiteListResponse@message@aesm@@
.?AVResponse_GetWhiteListSizeResponse@message@aesm@@
.?AVResponse_GetPsCapResponse@message@aesm@@
.?AVResponse_CloseSessionResponse@message@aesm@@
.?AVResponse_ExchangeReportResponse@message@aesm@@
.?AVResponse_InvokeServiceResponse@message@aesm@@
.?AVResponse_CreateSessionResponse@message@aesm@@
.?AVResponse_CheckUpdateStatusResponse@message@aesm@@
.?AVResponse_ReportAttestationErrorResponse@message@aesm@@
.?AVResponse_GetLaunchTokenResponse@message@aesm@@
.?AVResponse_GetQuoteResponse@message@aesm@@
.?AVResponse_InitQuoteResponse@message@aesm@@
.?AVRequest@message@aesm@@
.?AVRequest_GetSupportedAttKeyIDsRequest@message@aesm@@
.?AVRequest_GetSupportedAttKeyIDNumRequest@message@aesm@@
.?AVRequest_GetQuoteExRequest@message@aesm@@
.?AVRequest_GetQuoteSizeExRequest@message@aesm@@
.?AVRequest_SelectAttKeyIDRequest@message@aesm@@
.?AVRequest_InitQuoteExRequest@message@aesm@@
.?AVRequest_SGXRegisterRequest@message@aesm@@
.?AVRequest_SGXSwitchExtendedEpidGroupRequest@message@aesm@@
.?AVRequest_SGXGetExtendedEpidGroupIdRequest@message@aesm@@
.?AVRequest_GetWhiteListRequest@message@aesm@@
.?AVRequest_GetWhiteListSizeRequest@message@aesm@@
.?AVRequest_GetPsCapRequest@message@aesm@@
.?AVRequest_CloseSessionRequest@message@aesm@@
.?AVRequest_ExchangeReportRequest@message@aesm@@
.?AVRequest_InvokeServiceRequest@message@aesm@@
.?AVRequest_CreateSessionRequest@message@aesm@@
.?AVRequest_CheckUpdateStatusRequest@message@aesm@@
.?AVRequest_ReportAttestationErrorRequest@message@aesm@@
.?AVRequest_GetLaunchTokenRequest@message@aesm@@
.?AVRequest_GetQuoteRequest@message@aesm@@
.?AVRequest_InitQuoteRequest@message@aesm@@
error_info_injector@Vlogic_error@std@@@exception_detail@boost@@
error_info_injector@Vlogic_error@std@@@exception_detail@boost@@@exception_detail@boost@@
clone_impl@U?
wrapexcept@Vlogic_error@std@@@boost@@
.?AVdomain_error@std@@
error_info_injector@Vdomain_error@std@@@exception_detail@boost@@
error_info_injector@Vdomain_error@std@@@exception_detail@boost@@@exception_detail@boost@@
clone_impl@U?
wrapexcept@Vdomain_error@std@@@boost@@
.?AVinvalid_argument@std@@
error_info_injector@Vinvalid_argument@std@@@exception_detail@boost@@
error_info_injector@Vinvalid_argument@std@@@exception_detail@boost@@@exception_detail@boost@@
clone_impl@U?
wrapexcept@Vinvalid_argument@std@@@boost@@
.?AVlength_error@std@@
error_info_injector@Vlength_error@std@@@exception_detail@boost@@
error_info_injector@Vlength_error@std@@@exception_detail@boost@@@exception_detail@boost@@
clone_impl@U?
wrapexcept@Vlength_error@std@@@boost@@
.?AVbad_address_cast@ip@asio@boost@@
error_info_injector@Vbad_address_cast@ip@asio@boost@@@exception_detail@boost@@
error_info_injector@Vbad_address_cast@ip@asio@boost@@@exception_detail@boost@@@exception_detail@boost@@
clone_impl@U?
wrapexcept@Vbad_address_cast@ip@asio@boost@@@boost@@
error_info_injector@Vout_of_range@std@@@exception_detail@boost@@
error_info_injector@Vout_of_range@std@@@exception_detail@boost@@@exception_detail@boost@@
clone_impl@U?
wrapexcept@Vout_of_range@std@@@boost@@
.?AVbad_executor@asio@boost@@
error_info_injector@Vbad_executor@asio@boost@@@exception_detail@boost@@
error_info_injector@Vbad_executor@asio@boost@@@exception_detail@boost@@@exception_detail@boost@@
clone_impl@U?
wrapexcept@Vbad_executor@asio@boost@@@boost@@
error_info_injector@Vsystem_error@system@boost@@@exception_detail@boost@@
error_info_injector@Vsystem_error@system@boost@@@exception_detail@boost@@@exception_detail@boost@@
clone_impl@U?
wrapexcept@Vsystem_error@system@boost@@@boost@@
.?AVsystem_error@system@boost@@
.?AVservice_already_exists@asio@boost@@
error_info_injector@Vservice_already_exists@asio@boost@@@exception_detail@boost@@
error_info_injector@Vservice_already_exists@asio@boost@@@exception_detail@boost@@@exception_detail@boost@@
clone_impl@U?
wrapexcept@Vservice_already_exists@asio@boost@@@boost@@
.?AVlogic_error@std@@
.?AVinvalid_service_owner@asio@boost@@
error_info_injector@Vinvalid_service_owner@asio@boost@@@exception_detail@boost@@
error_info_injector@Vinvalid_service_owner@asio@boost@@@exception_detail@boost@@@exception_detail@boost@@
clone_impl@U?
wrapexcept@Vinvalid_service_owner@asio@boost@@@boost@@
.?AVclone_base@exception_detail@boost@@
.?AVexception@boost@@
Ref_count_resource@PEAUDIR@@V<lambda_05997e67cf84397614b9761a09c97b73>@@@std@@
.?AVAESMLogic@@
.?AUIPceService@@
.?AUIPseprService@@
.?AUINetworkService@@
.?AUIDeviceService@@
.?AUIPseopService@@
.?AUIQuoteProxyService@@
.?AUIEpidQuoteService@@
.?AUILaunchService@@
.?AVServiceException@cppmicroservices@@
.?AVruntime_error@std@@
.?AVexception@std@@
.?AVbad_array_new_length@std@@
.?AVCRegObject@ATL@@
.?AUIRegistrarBase@@
.?AUIUnknown@@
.?AVCAtlException@ATL@@
0A@VCAESMServiceModule@@@ATL@@
CAtlValidateModuleConfiguration@
CAtlModuleT@VCAESMServiceModule@@@ATL@@
CAtlExeModuleT@VCAESMServiceModule@@@ATL@@
CAtlServiceModuleT@VCAESMServiceModule@@
.?AVCAESMServiceModule@@
.?AVCAtlModule@ATL@@
ABCDEFGHIJKLMNOPQRSTUVWXYZ
abcdefghijklmnopqrstuvwxyz
C:\SGXWindows\src_Release\windows-trunk\psw\ae\aesm_service\source\build\x64\HW_Release\onecore\bin\RelWithDebInfo\aesm_service.pdb
uz-uz-latn
uz-uz-cyrl
sr-sp-latn
sr-sp-cyrl
sr-ba-latn
sr-ba-cyrl
bs-ba-latn
az-az-latn
az-az-cyrl
sr-BA-Cyrl
sr-BA-Latn
bs-BA-Latn
sr-SP-Cyrl
uz-UZ-Cyrl
az-AZ-Cyrl
sr-SP-Latn
uz-UZ-Latn
az-AZ-Latn
united-states
united-kingdom
south-korea
south-africa
puerto-rico
pr-china
new-zealand
hong-kong
holland
england
britain
america
swedish-finland
spanish-venezuela
spanish-uruguay
spanish-peru
spanish-paraguay
spanish-panama
spanish-nicaragua
spanish-modern
spanish-mexican
spanish-honduras
spanish-guatemala
spanish-ecuador
spanish-colombia
spanish-chile
spanish-bolivia
spanish-argentina
portuguese-brazilian
norwegian-nynorsk
norwegian-bokmal
norwegian
italian-swiss
irish-english
german-swiss
german-luxembourg
german-lichtenstein
german-austrian
french-swiss
french-luxembourg
french-canadian
french-belgian
english-usa
english-us
english-uk
english-nz
english-jamaica
english-ire
english-caribbean
english-can
english-belize
english-aus
english-american
dutch-belgian
chinese-traditional
chinese-singapore
chinese-simplified
chinese-hongkong
chinese
canadian
belgian
australian
american-english
american
JanFebMarAprMayJunJulAugSepOctNovDec
SunMonTueWedThuFriSat
UNICODE
UNICODE
api-ms-win-appmodel-runtime-l1-1-2
ext-ms-win-ntuser-windowstation-l1-1-0
ext-ms-win-ntuser-dialogbox-l1-1-0
api-ms-win-security-systemfunctions-l1-1-0
api-ms-win-rtcore-ntuser-window-l1-1-0
api-ms-win-core-xstate-l2-1-0
api-ms-win-core-winrt-l1-1-0
api-ms-win-core-sysinfo-l1-2-1
api-ms-win-core-synch-l1-2-0
api-ms-win-core-string-l1-1-0
api-ms-win-core-processthreads-l1-1-2
api-ms-win-core-localization-obsolete-l1-2-0
api-ms-win-core-localization-l1-2-1
api-ms-win-core-file-l1-2-2
api-ms-win-core-fibers-l1-1-1
api-ms-win-core-datetime-l1-1-1
nextafter
SystemFunction036
SetThreadStackGuarantee
AppPolicyGetWindowingModel
AppPolicyGetShowDeveloperDiagnostic
AppPolicyGetThreadInitializationType
AppPolicyGetProcessTerminationMethod
RoUninitialize
RoInitialize
MessageBoxW
MessageBoxA
LocateXStateFeature
LocaleNameToLCID
LCIDToLocaleName
LCMapStringEx
IsValidLocaleName
GetXStateFeaturesMask
GetUserObjectInformationW
GetUserDefaultLocaleName
GetTimeFormatEx
GetProcessWindowStation
GetLocaleInfoEx
GetLastActivePopup
GetEnabledXStateFeatures
GetDateFormatEx
GetActiveWindow
FlsSetValue
FlsGetValue
FlsFree
FlsAlloc
EnumSystemLocalesEx
CompareStringEx
AreFileApisANSI
December
November
October
September
February
January
Saturday
Thursday
Wednesday
Tuesday
December
November
October
September
February
January
Saturday
Thursday
Wednesday
Tuesday
nan(snan)
NAN(SNAN)
LC_NUMERIC
LC_MONETARY
LC_CTYPE
LC_COLLATE
mscoree.dll
<program name unknown>
Program:
abcdefghijklmnopqrstuvwxyz{|}
CorExitProcess
ABCDEFGHIJKLMNOPQRSTUVWXYZ{|}
!_is_double
crt_strtox::floating_point_value::as_float
is_double
crt_strtox::floating_point_value::as_double
minkernel\crts\ucrt\inc\corecrt_internal_strtox.h
cli::array<
cointerface
coclass
volatile
<unknown>
noexcept
,<ellipsis>
<ellipsis>
std::nullptr_t
std::nullptr_t
volatile
volatile
unsigned
protected:
private:
virtual
adjustor{
vtordisp{
vtordispex{
template-parameter
generic-method-parameter-
generic-class-parameter-
template-type-parameter-
non-type-template-parameter
generic-type-
generic-type-
template-parameter-
template-parameter-
operator<=>
string'
typeof'
vbtable'
vftable'
operator
restrict(
unaligned
restrict
clrcall
vectorcall
fastcall
thiscall
stdcall
0123456789abcdefghijklmnopqrstuvwxyz
:Jan:January:Feb:February:Mar:March:Apr:April:May:May:Jun:June:Jul:July:Aug:August:Sep:September:Oct:October:Nov:November:Dec:December
:Sun:Sunday:Mon:Monday:Tue:Tuesday:Wed:Wednesday:Thu:Thursday:Fri:Friday:Sat:Saturday
A:Sun:Sunday:Mon:Monday:Tue:Tuesday:Wed:Wednesday:Thu:Thursday:Fri:Friday:Sat:Saturday
interrupted
regex_error
regex_error(error_syntax)
regex_error(error_parse)
arguments.
C:\SGXWindows\src_Release\windows-trunk\external\protobuf\src\google\protobuf\stubs\stringprintf.cc
C:\SGXWindows\src_Release\windows-trunk\external\protobuf\src\google\protobuf\io\strtod.cc
serializing
a protocol
C:\SGXWindows\src_Release\windows-trunk\external\protobuf\src\google\protobuf\wire_format_lite.cc
C:\SGXWindows\src_Release\windows-trunk\external\protobuf\src\google/protobuf/extension_set_inl.h
C:\SGXWindows\src_Release\windows-trunk\external\protobuf\src\google/protobuf/arena.h
C:\SGXWindows\src_Release\windows-trunk\external\protobuf\src\google\protobuf\extension_set.cc
C:\SGXWindows\src_Release\windows-trunk\external\protobuf\src\google\protobuf\repeated_field.cc
C:\SGXWindows\src_Release\windows-trunk\external\protobuf\src\google/protobuf/repeated_field.h
C:\SGXWindows\src_Release\windows-trunk\external\protobuf\src\google\protobuf\io\zero_copy_stream_impl.cc
StringOutputStream.
C:\SGXWindows\src_Release\windows-trunk\external\protobuf\src\google\protobuf\io\zero_copy_stream_impl_lite.cc
C:\SGXWindows\src_Release\windows-trunk\external\protobuf\src\google\protobuf\io\zero_copy_stream.cc
C:\SGXWindows\src_Release\windows-trunk\external\protobuf\src\google\protobuf\stubs\strutil.cc
ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789-_
ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/
C:\SGXWindows\src_Release\windows-trunk\external\protobuf\src\google\protobuf\stubs\int128.cc
DATA_LOSS
UNAVAILABLE
UNIMPLEMENTED
OUT_OF_RANGE
ABORTED
FAILED_PRECONDITION
RESOURCE_EXHAUSTED
UNAUTHENTICATED
PERMISSION_DENIED
ALREADY_EXISTS
NOT_FOUND
DEADLINE_EXCEEDED
INVALID_ARGUMENT
UNKNOWN
CANCELLED
parsing
C:\SGXWindows\src_Release\windows-trunk\external\protobuf\src\google/protobuf/parse_context.h
C:\SGXWindows\src_Release\windows-trunk\external\protobuf\src\google\protobuf\generated_message_util.cc
" because it is missing required fields:
C:\SGXWindows\src_Release\windows-trunk\external\protobuf\src\google\protobuf\message_lite.cc
C:\SGXWindows\src_Release\windows-trunk\external\protobuf\src\google\protobuf\arena.cc
A protocol message was rejected because it was too big (more than
C:\SGXWindows\src_Release\windows-trunk\external\protobuf\src\google\protobuf\io\coded_stream.cc
WARNING
. Please update your library. If you compiled the program yourself, make sure that your headers are from the same version of Protocol Buffers as your link-time library. (Version verification failed in "
C:\SGXWindows\src_Release\windows-trunk\external\protobuf\src\google\protobuf\stubs\common.cc
iostream
, chunked
chunked
websocket
upgrade
C:\SGXWindows\src_Release\windows-trunk\external\boost\boost/beast/core/impl/flat_buffer.hpp
string_view::copy
C:\SGXWindows\src_Release\windows-trunk\external\boost\boost/utility/string_view.hpp
C:\SGXWindows\src_Release\windows-trunk\external\boost\boost/beast/http/impl/fields.hpp
set_option
C:\SGXWindows\src_Release\windows-trunk\external\boost\boost/beast/websocket/impl/write.hpp
C:\SGXWindows\src_Release\windows-trunk\external\boost\boost/beast/websocket/impl/read.hpp
C:\SGXWindows\src_Release\windows-trunk\external\boost\boost/beast/websocket/impl/accept.hpp
C:\SGXWindows\src_Release\windows-trunk\external\boost\boost/beast/http/impl/message.hpp
C:\SGXWindows\src_Release\windows-trunk\external\boost\boost/beast/core/impl/static_string.hpp
local_endpoint
BIND_ADDR
Boost.Beast/266
aesm-websocket-server
aesm.message.Response
aesm.message.Response.GetSupportedAttKeyIDsResponse
aesm.message.Response.GetSupportedAttKeyIDNumResponse
aesm.message.Response.UnsupportedRequestResponse
aesm.message.Response.GetQuoteExResponse
aesm.message.Response.GetQuoteSizeExResponse
aesm.message.Response.InitQuoteExResponse
aesm.message.Response.SelectAttKeyIDResponse
aesm.message.Response.SGXRegisterResponse
aesm.message.Response.SGXSwitchExtendedEpidGroupResponse
aesm.message.Response.SGXGetExtendedEpidGroupIdResponse
aesm.message.Response.GetWhiteListResponse
aesm.message.Response.GetWhiteListSizeResponse
aesm.message.Response.GetPsCapResponse
aesm.message.Response.CloseSessionResponse
aesm.message.Response.ExchangeReportResponse
aesm.message.Response.InvokeServiceResponse
aesm.message.Response.CreateSessionResponse
aesm.message.Response.CheckUpdateStatusResponse
aesm.message.Response.ReportAttestationErrorResponse
aesm.message.Response.GetLaunchTokenResponse
aesm.message.Response.GetQuoteResponse
aesm.message.Response.InitQuoteResponse
aesm.message.Request
aesm.message.Request.GetSupportedAttKeyIDsRequest
aesm.message.Request.GetSupportedAttKeyIDNumRequest
aesm.message.Request.GetQuoteExRequest
aesm.message.Request.GetQuoteSizeExRequest
aesm.message.Request.SelectAttKeyIDRequest
aesm.message.Request.InitQuoteExRequest
aesm.message.Request.SGXRegisterRequest
aesm.message.Request.SGXSwitchExtendedEpidGroupRequest
aesm.message.Request.SGXGetExtendedEpidGroupIdRequest
aesm.message.Request.GetWhiteListRequest
aesm.message.Request.GetWhiteListSizeRequest
aesm.message.Request.GetPsCapRequest
aesm.message.Request.CloseSessionRequest
aesm.message.Request.ExchangeReportRequest
aesm.message.Request.InvokeServiceRequest
aesm.message.Request.CreateSessionRequest
aesm.message.Request.CheckUpdateStatusRequest
aesm.message.Request.ReportAttestationErrorRequest
aesm.message.Request.GetLaunchTokenRequest
aesm.message.Request.GetQuoteRequest
aesm.message.Request.InitQuoteRequest
C:\SGXWindows\src_Release\windows-trunk\external\boost\boost/beast/zlib/detail/inflate_stream.ipp
C:\SGXWindows\src_Release\windows-trunk\external\boost\boost/beast/zlib/detail/deflate_stream.ipp
boost.beast.zlib
; client_no_context_takeover
; server_no_context_takeover
; client_max_window_bits=
; server_max_window_bits=
permessage-deflate
keep-alive
<unknown-status>
Conflict
Forbidden
Unauthorized
Multi-Status
Accepted
Created
Processing
Continue
UBSCRIBE
OPPATCH
ALENDAR
ACTIVITY
SUBSCRIBE
X400-Recipients
X400-Received
X400-Originator
X400-MTS-Identifier
X400-Content-Type
X400-Content-Return
X400-Content-Identifier
X-VerificaSicurezza
X-Trasporto
X-TipoRicevuta
X-Riferimento-Message-ID
X-Ricevuta
X-PGP-Sig
X-Mittente
X-Frame-Options
X-Device-User-Agent
X-Device-Accept-Language
X-Device-Accept-Encoding
X-Device-Accept-Charset
X-Device-Accept
X-Archived-At
WWW-Authenticate
Warning
Want-Digest
Version
Variant-Vary
User-Agent
Urgency
Upgrade
UA-Windowpixels
UA-Resolution
UA-Pixels
UA-Media
UA-Color
Transfer-Encoding
Trailer
Timeout
Surrogate-Control
Surrogate-Capability
Supersedes
Summary
Subject
Strict-Transport-Security
Status-URI
Solicitation
SoapAction
SIO-Label-History
SIO-Label
SetProfile
Set-Cookie2
Set-Cookie
Sensitivity
See-Also
Security-Scheme
Sec-WebSocket-Protocol
Sec-WebSocket-Key
Sec-WebSocket-Extensions
Schedule-Tag
Schedule-Reply
Return-Path
Retry-After
Resolver-Location
Resolution-Hint
Resent-To
Resent-Sender
Resent-Reply-To
Resent-Message-ID
Resent-From
Resent-Date
Resent-Cc
Resent-Bcc
Require-Recipient-Valid-Since
Reply-To
Reply-By
Relay-Version
Referer-Root
Referer
References
Redirect-Ref
Received-SPF
Received
Public-Key-Pins-Report-Only
Public-Key-Pins
Proxy-Instruction
Proxy-Features
Proxy-Connection
Proxy-Authorization
Proxy-Authentication-Info
Proxy-Authenticate
Protocol-Request
Protocol-Query
Protocol-Info
Protocol
ProfileObject
Privicon
Priority
Prevent-NonDelivery-Report
Preference-Applied
Posting-Version
Position
PICS-Label
Pep-Info
Overwrite
Originator-Return-Address
Original-Subject
Original-Sender
Original-Recipient
Original-Message-ID
Original-From
Original-Encoded-Information-Types
Organization
Ordering-Type
Optional-WWW-Authenticate
Optional
Obsoletes
Non-Compliance
NNTP-Posting-Host
NNTP-Posting-Date
Newsgroups
Negotiate
MT-Priority
MMHS-Subject-Indicator-Codes
MMHS-Primary-Precedence
MMHS-Other-Recipients-Indicator-To
MMHS-Other-Recipients-Indicator-CC
MMHS-Originator-Reference
MMHS-Originator-PLAD
MMHS-Message-Type
MMHS-Message-Instructions
MMHS-Handling-Instructions
MMHS-Extended-Authorisation-Info
MMHS-Exempted-Address
MMHS-Copy-Precedence
MMHS-Codress-Message-Indicator
MMHS-Authorizing-Users
MMHS-Acp127-Message-Identifier
MIME-Version
Method-Check-Expires
Method-Check
Message-Type
Message-ID
Message-Context
Memento-Datetime
Max-Forwards
Lock-Token
Location
List-Unsubscribe-Post
List-Unsubscribe
List-Subscribe
List-Post
List-Owner
List-Help
List-Archive
Latest-Delivery-Time
Last-Modified
Language
Keywords
Keep-Alive
Jabber-ID
Injection-Info
Injection-Date
Incomplete-Copy
Importance
If-Unmodified-Since
If-Schedule-Tag-Match
If-Range
If-None-Match
If-Modified-Since
If-Match
HTTP2-Settings
Hobareg
GetProfile
Generate-Delivery-Report
Forwarded
Followup-To
Expiry-Date
Expires
Errors-To
Encrypted
Encoding
Eesst-Version
EDIINT-Features
Downgraded-To
Downgraded-Sender
Downgraded-Return-Path
Downgraded-Resent-To
Downgraded-Resent-Sender
Downgraded-Resent-Reply-To
Downgraded-Resent-From
Downgraded-Resent-Cc
Downgraded-Resent-Bcc
Downgraded-Reply-To
Downgraded-References
Downgraded-Rcpt-To
Downgraded-Original-Recipient
Downgraded-Message-Id
Downgraded-Mail-From
Downgraded-In-Reply-To
Downgraded-From
Downgraded-Final-Recipient
Downgraded-Disposition-Notification-To
Downgraded-Cc
Downgraded-Bcc
DL-Expansion-History
DKIM-Signature
Distribution
Disposition-Notification-Options
Disclose-Recipients
Discarded-X400-MTS-Extensions
Discarded-X400-IPMS-Extensions
Differential-ID
Destination
Derived-From
Delta-Base
Delivery-Date
Deferred-Delivery
Default-Style
Date-Received
Conversion-With-Loss
Conversion
Control
Content-Version
Content-Type
Content-Transfer-Encoding
Content-Style-Type
Content-Script-Type
Content-Return
Content-Range
Content-MD5
Content-Location
Content-Length
Content-Language
Content-Identifier
Content-ID
Content-features
Content-Encoding
Content-Duration
Content-Disposition
Content-Description
Content-Base
Content-Alternative
Connection
Compliance
Comments
Cancel-Lock
Cancel-Key
CalDAV-Timezones
Cache-Control
C-PEP-Info
Autosubmitted
Autoforwarded
Auto-Submitted
Authorization
Authentication-Results
Authentication-Info
Authentication-Control
Article-Updates
Article-Names
Archived-At
Archive
Approved
Apply-To-Redirect-Ref
Apparently-To
Alternates
Alternate-Recipient
Alt-Used
Also-Control
Access-Control-Request-Method
Access-Control-Request-Headers
Access-Control-Max-Age
Access-Control-Expose-Headers
Access-Control-Allow-Origin
Access-Control-Allow-Methods
Access-Control-Allow-Headers
Access-Control-Allow-Credentials
Access-Control
Accept-Ranges
Accept-Post
Accept-Patch
Accept-Language
Accept-Features
Accept-Encoding
Accept-Datetime
Accept-Charset
Accept-Additions
<unknown-field>
beast.http
A WebSocket protocol violation occurred
AESMLogic::service_start
boost.beast.websocket
C:\SGXWindows\src_Release\windows-trunk\external\boost\boost/beast/core/impl/static_buffer.ipp
C:\SGXWindows\src_Release\windows-trunk\external\boost\boost/beast/core/impl/flat_static_buffer.ipp
thread.exit_event
thread.entry_event
asio.misc
boost.beast
generic
C:\SGXWindows\src_Release\windows-trunk\external\protobuf\install\x64-Release\include\messages.pb.cc
winsock
bundles
RegServerPerUser
UnregServerPerUser
RegServer
UnregServer
Service
LocalService
aesm_helper.dll
Version
SOFTWARE\Intel\SGX_PSW
SYSTEM\CurrentControlSet\Services\AESMService
InitHelper
SeSystemEnvironmentPrivilege
SeCreateGlobalPrivilege
SeChangeNotifyPrivilege
ncalrpc
AesmRpcEndpoint
REGISTRY
Module_Raw
Classes
Software
HKEY_CURRENT_CONFIG
HKEY_DYN_DATA
HKEY_PERFORMANCE_DATA
HKEY_USERS
HKEY_LOCAL_MACHINE
init_helper
HKEY_CURRENT_USER
HKEY_CLASSES_ROOT
TypeLib
Software
SECURITY
Hardware
Interface
FileType
Advapi32.dll
Intel.SGXAESM_8j3eq9eme6ctt
atlTraceISAPI
atlTraceSync
atlTraceSecurity
atlTraceUtil
atlTraceMap
atlTraceString
NoRemove
ForceRemove
atlTraceStencil
atlTraceCache
atlTraceTime
atlTraceException
atlTraceAllocation
atlTraceNotImpl
atlTraceSnapin
atlTraceDBProvider
atlTraceDBClient
atlTraceHosting
atlTraceControls
atlTraceWindowing
atlTraceRefcount
atlTraceRegistrar
atlTraceQI
atlTraceCOM
atlTraceGeneral
RegDeleteKeyExW
RegDeleteKeyTransactedW
RegCreateKeyTransactedW
RegOpenKeyTransactedW
INTERNALH
