hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
Intel® Tiber Developer Cloud
Help connecting to or getting started on Intel® Tiber Developer Cloud
Using HBM in FLAT mode
Yasodha
I have been trying to use the guidelines listed here for setting up HBM in FLAT mode. https://www.intel.com/content/www/us/en/content-details/769060/intel-xeon-cpu-max-series-configuration-and-tuning-guide.html?DocID=769060
numactl -H shows two nodes with capacity of 256 GB (total of 512 GB). The instance spec for memory is 1024GB.
daxctl list command results in empty list on my instance.
Would you help with setting up separate NUMA node for HBM?
Yasodha.
Faiz_Intel
Hi Yasodha,
To ensure we can assist you effectively, please provide the following details. If not applicable, please use 'N/A'. We appreciate your cooperation, and we look forward to resolving this matter promptly.
1. Severity level of the issue: Low/Medium/High/Critical
2. Reservation details:-
- Instance type:
- Instance ID/Resource ID:
- Start time/Created at:
- Instance IP address:
- Region: us-region-1/us-region-2/us-region-3
3. Cloud account ID:
4. Is there any important data stored on the instance? Yes/No
5. Can the IDC support team access the instance and perform the required operations to validate or fix an issue if needed? Yes/No
6. Screenshot of the numactl-H output.
7. Screenshot of the daxctl list output.
Faiz
Yasodha
Hello Faiz,
Thank you for your timely reply. Answers are below.
1. Severity level of the issue: Low/Medium/High/Critical : Critical - cannot use the instance for intended purpose
- Instance type: 4th Generation Intel® Xeon® Scalable processors with high bandwidth memory (HBM) Flat mode
- Instance ID/Resource ID: reservation-4839
- Start time/Created at: 01/16/2025
- Instance IP address:192.168.2.2
- Region: us-region-1/us-region-2/us-region-3 : us-region-2
4. Is there any important data stored on the instance? No
6. Screenshot of the numactl-H output. Attached
I installed daxctl module and my understanding is that the system needs a reboot for daxctl to work. So, this might be a manifest of the install process.
Yasodha.
Faiz_Intel
Hi Yasodha,
Thank you for providing the information. I have escalated your case to the appropriate team for further investigation of this matter. Upon receiving their feedback, I will provide you with an update. We greatly appreciate your patience.
Faiz
Faiz_Intel
This thread will no longer be monitored since we have provided the essential information via email. If you need any additional information from Intel, please submit a new question.
