Intel® oneAPI Base Toolkit
Support for core tools and libraries to build and deploy high-performance data-centric applications
346 Discussions
GMM error with recent OneAPIToolKit
skbm
Installed Arc Drivers for Arc A750 Graphics card on Ubuntu from Ubuntu* 22.04 (jammy) — Intel® software for general purpose GPU capabilities documentation
Installed recent OneAPIToolKit version 2023.0.0.25537. Followed steps mentioned in Install with Command Line (intel.com) .
After activating OneAPI environment, running 'sycl-ls' results in GMM Abort:
rpls@rpls-Raptor-Lake-Client-Platform:~$ sycl-ls
Abort was called at 39 line in file:
./shared/source/gmm_helper/client_context/gmm_client_context.cpp
Aborted (core dumped)
ShanmukhS_Intel
Hi Shravan,
Thanks for posting on Intel Communities.
Could you please confirm if the command ran without any issue before driver installation?
We would like to suggest you try re-installing and setting up the oneAPI environment and let us know if issue persists.
Shanmukh.SS
ShanmukhS_Intel
Hi Shravan,
A gentle reminder:
It has been a while since we heard back from you. could you please let us know if any updates on your issue?
Shanmukh.SS
ShanmukhS_Intel
Hi Shravan,
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Shanmukh.SS
