Can opeapi be combined with GPU for ray tracing?
wang__qiang
ray tracing need to consume amount of time,so i think whether the oneapi can be used to accelerate it.
GouthamK_Intel
Hi Qiang,
We are working on this and will get back to you.
Goutham
Subarnarek_G_Intel
Hi Qiang,
Can you give some more idea regarding the application you want to accelerate?
Subarna
Michael_C_Intel1
Hi QiangW,
Can you give more detail of you goal? Understanding your goal is needed to give appropriate guidance.
That being said, there are two OneAPI toolkits relevant for ray tracing in general.
1) The rendering toolkit
The rendering toolkit contains a suite of rendering related libraries. In particular, Embree and OSPRay provide both a ray tracing primitives API and a render engine respectively. They are available in the toolkit itself as well as open source repositories. Sources for Embree and OSPRay are available on GitHub.
The toolkit serves as a platform to get started and try applications... for best performance on hardware, many users redeploy the Embree or OSPRay implementation specifics within their own applications. Many also rebuild Embree and OSPRay specifically for their targets and feature sets, then use them as an off the shelf/self contained library.
2) The base toolkit
The base toolkit contains a compiler. Data Parallel C++… 'dpcpp' or 'DPC++'. Densely parallel or repeated operations can leverage command group handler functions like parallel_for (and it's functor/lamda) in search of acceleration on various device targets.
A developer could consider implementing a ray tracer with DPC++ offload regions. Performance will vary on the implementation and the device targets employed. However, currently (and fortunately), Intel has off the shelf ray tracing related implementations that aim to provide performance on Intel hardware.
3) Comment
For a user application its possible to mix and match a DPC++ application with the Rendering toolkit components. At this time, Embree or OSPRay API calls wouldn't reside in control group handler functors/lambdas... however, raw data out of such APIs could be passed to a DPC++ offload region for developer custom compute. The base toolkit is not a prerequisite for the rendering toolkit.
-MichaelC
Subarnarek_G_Intel
Hi Qiang,
I hope Michael's response has solved your query. Closing the ticket. Please feel free to reach out to us for further queries.
Subarna
