I am trying to run a gaussian blur example on oneAPI dev cloud. I am able to build the example after some tweaking but the execution aborts without throwing any exception or errors. attaching files
u33211@login-1:~/MyFiles/gaussian_blur$ ./q run.sh
Submitting job:
439820.v-qsvr-1.aidevcloud
Job ID Name User Time Use S Queue
438492.v-qsvr-1 ...ub-singleuser u33211 00:03:04 R jupyterhub
439820.v-qsvr-1 run.sh u33211 0 Q batch
Waiting for Output...........
# Date: Tue Dec 10 03:16:11 PST 2019
# Job ID: 439820.v-qsvr-1.aidevcloud
# User: u33211
# Resources: neednodes=1:gpu:ppn=2,nodes=1:gpu:ppn=2,walltime=06:00:00
rm -rf ./gaussian-blur.exe
dpcpp gaussian-blur.cpp -o ./gaussian-blur.exe -I. -lOpenCL -lsycl
./gaussian-blur.exe Lenna.png
Gaussian filter created..
Optimal Local Size =64
Starting Kernel..
Finished Kernel..
Makefile:16: recipe for target 'run' failed
# End of output for job 439820.v-qsvr-1.aidevcloud
# Date: Tue Dec 10 03:16:18 PST 2019
make: *** [run] Aborted
Any help is appriciated.
- Tags:
- General Support
Hi Kuljeet,
I have gone through your code. I can see that you haven't specified inputData and outputData argument to the image<2> constructor. Advising you to make the following changes to your code on line numbers 154 and 155.
On line number 154, From cl::sycl::image<2> image_in(co::rgba, ct::unorm_int8, imgRange); (your code) to cl::sycl::image<2> image_in(inputData,co::rgba, ct::unorm_int8, imgRange); (suggested change)
On line number 155, From cl::sycl::image<2> image_out(co::rgba, ct::unorm_int8, imgRange); (your code) to cl::sycl::image<2> image_out(outputData,co::rgba, ct::unorm_int8, imgRange); (suggested change)
Let us know if the suggested changes resolve your issue.
Rahul
Hello Kuljeet,
Thanks for reaching out to us. We will get back to you soon.
Sushma
Hi Kuljeet,
Rahul
Many thanks Rahul,
I was able to execute the code sucessfuly with the changes suggested.
Is there any document that captures the differences / enhancements between DPC++ and SYCL1.2 ?
Hi Kuljeet,
Good to know that your issue is resolved. We are closing this thread.
Request you to raise a new thread for "Is there any document that captures the differences/enhancements between DPC++ and SYCL1.2 ?" query.
Kaleem
