icpx `std::views::zip` compile error
PeterFačko
Hello, when compiling this source code:
#include <algorithm>
#include <execution>
#include <ranges>
#include <utility>
#include <vector>
int main(int argc, char** argv)
    const auto input = std::vector<int>(100);
    auto output_a = std::vector<int>(input.size());
    auto output_b = std::vector<int>(input.size());
    auto zipped = std::views::zip(output_a, output_b);
    std::transform(std::execution::par_unseq,
                   input.begin(),
                   input.end(),
                   zipped.begin(),
                   [](auto) -> std::pair<int, int>
                       return {};
    return 0;
with:
icpx -std=c++23 -qtbb test.cpp -o test
I get:
In file included from test.cpp:3:
/usr/lib64/gcc/x86_64-pc-linux-gnu/13.2.1/../../../../include/c++/13.2.1/ranges:4558:14: error: type constraint differs in template redeclaration
 4558 |     template<copy_constructible _Fp, input_range... _Ws>
/usr/lib64/gcc/x86_64-pc-linux-gnu/13.2.1/../../../../include/c++/13.2.1/ranges:4458:14: note: in instantiation of template class 'std::ranges::zip_view<std::ranges::ref_view<std::vector<int>>, std::ranges::ref_view<std::vector<int>>>::_Iterator<true>' requested here
 4458 |     { return _Iterator<true>(__detail::__tuple_transform(ranges::begin, _M_views)); }
test.cpp:19:27: note: in instantiation of member function 'std::ranges::zip_view<std::ranges::ref_view<std::vector<int>>, std::ranges::ref_view<std::vector<int>>>::begin' requested here
   19 |                    zipped.begin(),
/usr/lib64/gcc/x86_64-pc-linux-gnu/13.2.1/../../../../include/c++/13.2.1/ranges:4829:12: note: previous template declaration is here
 4829 |   template<copy_constructible _Fp, input_range... _Vs>
/usr/lib64/gcc/x86_64-pc-linux-gnu/13.2.1/../../../../include/c++/13.2.1/ranges:4458:30: note: in instantiation of template class 'std::ranges::zip_view<std::ranges::ref_view<std::vector<int>>, std::ranges::ref_view<std::vector<int>>>::_Iterator<false>' requested here
2 errors generated.
 When compiling with:
g++ -std=c++23 -ltbb test.cpp -o test
the compilation is successful.
[fackop@PPpc-main PPtrading]$ g++ --version
g++ (GCC) 13.2.1 20230801
Copyright (C) 2023 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
[fackop@PPpc-main PPtrading]$ icpx --version
Intel(R) oneAPI DPC++/C++ Compiler 2024.0.2 (2024.0.2.20231213)
Target: x86_64-unknown-linux-gnu
Thread model: posix
InstalledDir: /opt/intel/oneapi/compiler/2024.0/bin/compiler
Configuration file: /opt/intel/oneapi/compiler/2024.0/bin/compiler/../icpx.cfg
Is this a bug? Thank you in advance for any help.
Peter Fačko
mayurp
To get this to work we need newer library that has this change: https://github.com/gcc-mirror/gcc/commit/be34a8b538c0f04b11a428bd1a9340eb19dec13f
With that library change applied to a preprocessed version of the test case, icpx compiles it okay.
cp /path-of-ranges-file myinclude
cd myinclude
patch ranges be34a8b538c0f04b11a428bd1a9340eb19dec13f.diff  (patch link - https://github.com/gcc-mirror/gcc/commit/be34a8b538c0f04b11a428bd1a9340eb19dec13f.diff )
icpx -Imyinclude -std=c++23 test.cpp  -- compiles fine
VipinS_Intel
Hi Peter, we would like to inform you that we are routing your query to the dedicated team for further assistance.
Thanks!
PeterFačko
Hi, is there any update on this?
mayurp
Hi Peter, we have been able to reproduce the issue and have raised it with the developer team.
mayurp
cd myinclude
arctic_circle
Dear Mayurp,
I am sorry for posting off topic but I am unable to post any questions in the forum. When I try to post a question I get this error:
"An Unexpected Error has occurred.
Your request failed. Please contact your system administrator and provide the date and time you received the error and this Exception ID: 558D0528."
Can you please let me know how to fix this and post questions? I would like to post a question about compiling DLLs with oneAPI (specifically, how to ensure that function names are exported properly - sqrt() and some other math functions seem to be interfering with exporting functions) but I can't post questions. Thank you
mayurp
I will ask the relevant team to look into this.
mayurp
This issue has been resolved and we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
