I am trying to compute a Cholesky factorization of a large matrix with an Intel Data Center Max 1550s GPU. The matrix size is 100,000 x 100,000. For testing, I am creating a random SPD matrix and seeing what the factorization/solve times are. The code file is attached. In the file, there is a commented out portion where it was making a random matrix. I changed it to just try a scaled Identity matrix first.
To compile:
icpx -fsycl -DGPU -o cholesky_gpu cholesky_gpu.cpp -lmkl_sycl -lmkl_intel_ilp64 -lmkl_core -lmkl_sequential -lsycl -lOpenCL
And then run:
./cholesky_gpu <N>
where N is the matrix size. This works fine for matrices up to 40,000 or so. If I use the random matrix version, I start seeing errors like
Provided range is out of integer limits. Pass `-fno-sycl-id-queries-fit-in-int' to disable range check.
I thought this had to do with the `range<2>(N,N)` becoming too big (I am using size_t and not int). With the scaled identity matrix, the potrf call gives an error saying the matrix is not positive definite.
Can someone help me solve this issue? I am very new to SYCL, so I might be making a very silly mistake somewhere. If there is an example Cholesky code that works on an arbitrary size matrix, that would be perfect!
Could you please check the oneMKL example for Cholesky factorization located in the following folder:
mkl/latest/share/doc/mkl/examples/examples_sycl.tgz
The Cholesky factorization examples can be found at:
sycl/lapack/source/potrs.cpp
sycl/lapack/source/potrs_usm.cpp
If you are working with a large matrix, please define the dimension as 64-bit integers and use the oneMKL 64-bit integer interface.
