6698 Discussions
Incorrect use of MKL Library random generator
Alechiove
Hi!
I'm new with oneapi and i'm trying to do a simple program for my university project doing a custom version of Pi Montecarlo Estimation.
I'm almost done, but i have troubles creating the random numbers using uniform distribution.
Can someone please help me with this errors that i keep getting?
Leaving the code and logs of errors under this line:
#include <sycl/sycl.hpp>
#include <oneapi/mkl/rng.hpp>
using namespace sycl;
static const int N_POINTS  = 10;
static const int N_SIM  = 10;
int create_points_and_calculate_eq(queue q){
    // create basic random number generator object
    oneapi::mkl::rng::philox4x32x10 engine(q, 777);
    // create distribution object
    oneapi::mkl::rng::uniform<double, oneapi::mkl::rng::uniform_method::standard> distr(0.0, 1.0);
    // creating vectors to store the points
    std::vector<double> sum_squared(N_POINTS);
    std::vector<double> x_sim(N_POINTS);
    std::vector<double> y_sim(N_POINTS);
    // creating Buffers for X/Y
    buffer<double> buf_x(x_sim.data(),x_sim.size());
    buffer<double> buf_y(y_sim.data(),y_sim.size());
    //Generating points
    oneapi::mkl::rng::generate(distr, engine, N_POINTS, buf_x);
    oneapi::mkl::rng::generate(distr, engine, N_POINTS, buf_y);
    //Creating buffer to store the sum of x**2 + y**2
    buffer<double> sum_sq(sum_squared.data(),sum_squared.size());
    q.submit([&](handler &h){
            auto V_x = buf_x.get_access<access::mode::read_write>(h);
            auto V_y = buf_y.get_access<access::mode::read_write>(h);
            auto X_PLUS_Y_SQ = sum_sq.get_access<access::mode::read_write>(h);
            h.parallel_for(range<1>(N_POINTS),[=] (id<1> i){
                double sum = V_x[i] * V_x[i] + V_y[i] * V_y[i];
                if (sum>1){X_PLUS_Y_SQ[i] = 0;}
                else{X_PLUS_Y_SQ[i] = 1;}
    //counts points inside radius=1 circle
    int pts_in_circle = 0;
    for(int i=0;i<N_POINTS;i++){pts_in_circle+=sum_squared[i];};
    return pts_in_circle;
int main(){
    queue queue_of_simulations;
    std::cout << "Device : " << queue_of_simulations.get_device().get_info<info::device::name>() << "\n";
    //std::vector<int> results(N_SIM);
    int tot_pts_created = N_SIM * N_POINTS;
    for(int i=0;i<N_SIM;i++){pts_in_circle += create_points_and_calculate_eq(queue_of_simulations);};
    double pi = 4 * pts_in_circle / tot_pts_created;
    std::cout << "Pi Estimated:\t" << pi << std::endl;
icpx: error: linker command failed with exit code 1 (use -v to see invocation)
 Thanks in advance!
VidyalathaB_Intel
Hi Alessio,
Could you please try the below command and see if it works on your end?
icpx -fsycl -qmkl *.cpp
Please get back to us if you still face any issues.
Vidya.
VidyalathaB_Intel
Hi Alessio,
Vidya.
VidyalathaB_Intel
Hi @Alechiove ,
As we haven't heard back from you, could you please provide us with an update regarding the issue?
Vidya.
Alechiove
Yes, Thank you so much!
Solved my problem!
VidyalathaB_Intel
Hi Alessio,
Thanks for accepting the solution.
Please post a new question if you need any additional assistance from Intel as this thread will no longer be monitored.
Have a Great Day!
Vidya.
