Previously I had tested mkl cblas_dgemm for m=n=k=10000 and found a performance of approximately 2 TFlop but now the same give me a performance of around 0.8 TFlops.
Case 1:
CentOS 7.2.* and Intel Parallel Studio XE
MKL cblas_dgemm
m=n=k=10000
Performance: 1900+ GFlops
Case 2:
CentOS 8.5.* and Intel OneAPI
MKL cblas_dgemm
m=n=k=1000
Performance: 750+ GFlops
Why this is the huge gap. something is wrong
What is the reason?
Please assist and guide
- « Previous
- 1
- 2
- Next »
Following with this log, you once again linked against MKL 2022.0 -- see line #3 of the log file, But we asked you to link against MKL 2017 and show a similar log.
Dear,
I don't have that previous version of MKL now.
Could you please share your test machine environment variables?
Please let me know how can I download previous version of Intel OneAPI Base Kit and HPC Kit
there is no specific environment setting at this machine. The attached _2017u2.zip contains the statically linking version of MKL 2017 u2. the password is the same as with the previous zip.
run this code on your systems: MKL_VERBOSE=1 ./a.out 10000
To run this every time I got message Permission Denied
Ok, I found out the Xeon Phi ( KNL) machine and run the dgemm code on this system with verbose mode enabled:
MKL 2017 u2:
MKL_VERBOSE Intel(R) MKL 2017.0 Update 2 Product build 20170126 for Intel(R) 64 architecture Intel(R) Advanced Vector Extensions 512 (Intel(R) AVX-512) for Intel(R) Many Integrated Core Architecture (Intel(R) MIC Architecture) enabled processors, Lnx 1.30GHz lp64 intel_thread NMICDev:0
MKL 2020.0
MKL_VERBOSE oneMKL 2022.0 Product build 20211112 for Intel(R) 64 architecture Intel(R) Advanced Vector Extensions 2 (Intel(R) AVX2) enabled processors, Lnx 1.30GHz lp64 intel_thread
You may see that running the dgemm linked against the latest MKL 2020, the AVX2 code path is used. That is exactly what was announced at the MKL 2020 Release Note - see Deprecation:
Running the MKL 2017 code, we could see that the AVX-512 code path has been used.
That's the reason of the performance differences you have reported.
-Gennady
Could you please share the link because I did not see any such kind of note in 2020 Release notes
Thanks for sharing
One thing I can not understand is if Intel could not support AVX-512 in this version then how do they manage MKL performance. Didn't provide any alternative?
Please also confirm the following questions
What is the best performance of the intel mp Linpack benchmark on Intel Xeon Phi 7250?
Please share this will be a great help in this regard
Intel continues supporting AVX-512 ISA through all current types of CPU.
About Linpack’s performance benchmarks – these results were published some time ago on the MKL page when the Xeon Phi was no deprecated. You may try to make the sears some similar discussions through this forum.
The thread is closing and we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
- « Previous
- 1
- 2
- Next »
