Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
Non-intel GPU+MKL
qingfeng
I have a question.If I want to use OneAPI on a non-Intel GPU, how do I configure it? Is there a guide?
ShivaniK_Intel
Intel oneAPI doesn't support non-Intel GPUs. However, opensource version of oneAPI can be used for non-Intel GPUs
We suggest you refer to the below links to use opensource version of oneAPI on a non-Intel GPU
https://intel.github.io/llvm-docs/GetStartedGuide.html
https://github.com/oneapi-src/oneMKL
If you further face any issues please let us know.
Thanks & Regards
Shivani
qingfeng
hi
Thanks for your reply.
When I use MKL , I find that not all function areas has open source code .
So can I get all the open source code of  MKL ?
MKL link:oneapi-src/oneMKL: oneAPI Math Kernel Library (oneMKL) Interfaces (github.com)
ShivaniK_Intel
>>>So can I get all the open-source code of MKL?
Unfortunately No. The below link is the only open-sourced repository that we have in which a few MKL functions do not have the open-sourced API.
https://github.com/oneapi-src/oneMKL/tree/develop/src
Thanks & Regards
Shivani
ShivaniK_Intel
We haven't heard back from you. Is there anything else that we could help you with? If not, then could you please confirm whether to close this thread from our end.
Thanks & Regards
Shivani
ShivaniK_Intel
I have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks & Regards
Shivani
