Is enumerable_thread_specific reuseable?
cake
Hi I would like to reuse thread local storage in multiple parallel_for as following:
tbb::enumerable_thread_specific<T> ParallelT;
tbb::parallel_for(tbb::blocked_range<int>(0, n)), [&](const tbb::blocked_range<int> &r) {
  tbb::enumerable_thread_specific<T>::reference local_T = ParallelT.local();
  for (auto i = r.begin(); i < r.end(); i++) {
     /// local_T changed and stored
// Then I do some work, and try to reuse the ParallelT via iterating them.
tbb::parallel_for_each( ParallelT.begin(), ParallelT.end(), [&](...) {
  // Question: do I still get the thread local storage in this parallel_for_each?
As shown, I want to reuse my built TLS in another parallel_for_each. Do I get the TLS correctly without calling `.local` function? Is here a parallel_for_each or a parallel_for a correct behavior to reuse the TLS?
SeshaP_Intel
The Class enumerable_thread_specific(ETS) provides thread local storage that acts like an STL container with one element per thread.
You can get the thread local storage in the tbb::parallel_for_each block. You can use another reference and call the .local() function in tbb::parallel_for_each block.
You can refer to the OneTBB Pro Textbook, page no:165.
Thanks and Regards,
Pendyala Sesha Srinivas
SeshaP_Intel
Has the information provided above helped? If yes, could you please confirm whether we can close this thread from our end?
Thanks and Regards,
SeshaP_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks and Regards,
