Intel® vPro™ Platform
Intel Manageability Forum (Intel® EMA, AMT, SCS & Manageability Commander)
Intel® Endpoint Management Assistant (Intel® EMA) Cloud Start Tool for Azure* 2.0 is now available for download here.
The Intel® Manageability Commander 2.2 has been released! Learn more here.
The Intel® Endpoint Management Assistant, version 1.5.1 is now available for download here.
The Intel® Setup and Configuration Software tool will End of Life (EOL) on 12/31/2022. The Intel® Setup and Configuration Software Download will be available until March 31, 2021. For details, Please click here.
2562 Discussions
IMC SSCM Addon Support for Windows 11
HCCUser
With Windows 11, Internet Explorer has been removed from the OS and the IMC VBScript launches an IE window when using the right click context menu. Is there any update or workaround for the VBScripts to remove the dependency on Internet Explorer? Thanks.
JoseH_Intel
Hello HCCUser,
Thank you for joining the Intel community
Unfortunately SCS and its features (like the SCCM add-on) is out of support already, which means there are no updates or even support for them. The AMT functionality has migrated to the new Endpoint Management Assistant, which by the way, there is no integration with SCCM so far.
An alternate for you could be to try the Open Software Projects - MeshCommander which works similar to Intel Manageability Commander.
Hope it helps
Jose A.
