Comunicados
Are multiple concurrent instances of sample_encode_drm supported?
Jiline__Mikhail
Principiante
698 Visualizações
We are trying to run several sample_encode_drm at the same time to encode multiple streams. However, the second instance fails in libva initialization. Are multiple concurrent instances of sample_encode_drm supported on linux?
Misha
4 Respostas
Jeffrey_M_Intel1
Funcionário
697 Visualizações
Yes, multiple concurrent instances of all Media SDK pipelines should be supported.  However, I am also seeing a bug with the current release limiting to 1 instance.  I'll investigate and get back to you.
Jeffrey_M_Intel1
Funcionário
697 Visualizações
Are you able to encode multiple instances as root?  This helped on the system where I am investigating. It isn't a full solution, but it could be an important clue.
Jiline__Mikhail
Principiante
697 Visualizações
Hi Jeffrey,
Thanks for fast reply. Definetely being the root changes things! But we still were not able to find a proper way to run it...
Running as root:
sudo /opt/intel/mediasdk/samples/_bin/x64/sample_encode_drm h264 -hw
-nv12 -vaapi -w 1920 -h 1080 -i /epiphan/shutterstock_v2844682_x5.nv12
-o shutterstock_v2844682_x5.h264 -u quality
libva info: VA-API version 0.34.0
libva info: va_getDriverName() returns 0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
libva info: va_openDriver() returns 0
Intel(R) Media SDK Encoding Sample Version 4.0.1602354.61523
Input file format NV12
Output video AVC
Source picture:
Resolution 1920x1088
Crop X,Y,W,H 0,0,1920,1080
Destination picture:
Frame rate 30.00
Bit rate(Kbps) 5009
Target usage quality
Memory type d3d
Media SDK impl hw
Media SDK version 1.6
Processing started
Output video AVC
Source picture:
Frame rate 30.00
Bit rate(Kbps) 5009
Memory type d3d
Media SDK impl hw
Return on error: error code -17,
/msdk/validation/linux_val/validation/ww29.5_Linux-HSW_vc54_Ubuntu_12.04/samples/sample_encode/src/pipeline_encode.cpp
1242
ERROR: Hardware device was lost or returned an unexpected error. Recovering...
No error when running as a normal user (in group video)
Misha.
Jeffrey_M_Intel1
Funcionário
697 Visualizações
Media SDK for Linux Servers is very sensitive to installation. While I have not seen this particular behavior before, strange behavior like this can often be traced back to not having a supported configuration set up.  Please check your configuration agains the procedure here: http://software.intel.com/en-us/forums/topic/472852
This may not help the problem of multiple sessions needing root, but carefully following this procedure may help with the error you've most recently described.
A more complete installation guide is being included in a future release.
Thanks!
Responder
