3044 Discussions
Decode Header Status:-3 while trying to use OneVPL Libraries for decoding H265 file
Shivananda_H_Intel
I am trying to use the OneVPL Libraries for decoding instead of MediaSDK Libraries.
As part of this , i have modified our testapp similar to hello-decode sample avaialble in github,
but while running the sample, get the decode header error -3 (which means not supported ).
I am running the sample on TGLH-DG2512-FRD-D Board.
The video type is set to H265, as done in hello-decode sample. Implimentation type is set to HARDWARE.
sample input file is used for examples folder of OneAPI Folder.
Below is the log.
Input File: akiyo_cif_h265.h265
Output File: out.raw
+++++MFXCreateSession return value =0
Implementation details:
ApiVersion: 2.7
Implementation type: HW
AccelerationMode via: D3D11
Path: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_c590ba24fc90a79e\libmfx64-gen.dll
videoType : 1129727304
bitstream_codec :1129727304 decode_Codec :1129727304
+++++Prepare input bitstream and start decoding....
+++++ReadEncodedStream=0
Bitstream: :0 :1129727304 :0 :0
:0 : :0 :2000000
:2000000 :0 :0 :0 :0
decodeParams: :0 :0 :0 :0
:0 :32
:0 :0
Error decoding header
Makefile has changes done to link against vpl lib like below.
ONEVPL_LIB = $(ONEVPL_DIR)\lib\vpl.lib
Can you pls help me in resolving this issue. ?
1. Is additional libraries needed for  GPU Based decode ?
2. Is the video type passed as H265 needs further type casting ?
Shiva
JananiC_Intel
Since this is a duplicate thread of https://community.intel.com/t5/Media-Intel-oneAPI-Video/Decode-Header-Status-3-while-trying-to-use-OneVPL-Libraries-for/m-p/1399338#M14248, we will no longer monitor this thread. We will continue addressing this issue in the other thread.
Janani Chandran
