Hey, i have working ubuntu 14.04 with mediasdk and ffmpeg to transcode video files. but now i see that there is an error in my installation...
root@lenovo:~# ./sys_analyzer_linux.py -------------------------- Hardware readiness checks: -------------------------- [ OK ] Processor name: Intel(R) Core(TM) i5-4570T CPU @ 2.90GHz -------------------------- OS readiness checks: -------------------------- [ OK ] GPU visible to OS -------------------------- Media Server Studio Install: -------------------------- [ OK ] user is root [ ERROR ] libva.so.1 not found. Check LD_LIBRARY_PATH contains '/usr/lib64;/usr/local/lib' [ OK ] vainfo reports valid codec entry points [ ERROR ] no /dev/dri/renderD* interfaces found -------------------------- Component Smoke Tests: -------------------------- [ ERROR ] no Media SDK include files. Are Intel components installed? [ ERROR ] no OpenCL include files. Are Intel components installed? -------------------------- Media SDK Plugins available: (for more info see /opt/intel/mediasdk/plugins/plugins.cfg) -------------------------- [ ERROR ] no plugins/plugins.cfg. Are Intel components installed?
it is kernel 3.8 and then mediasdk + ffmpeg installed...
so i try to install ubuntu 16.04 with mediasdk but there i found no working solution. can anybody help me? i found a way to install it in centos but i want to use ubuntu...
I've also seen some issues with Ubuntu 16.04. However, Ubuntu 14.04 should work well for this machine following these steps:
https://software.intel.com/en-us/articles/how-to-setup-media-server-studio-on-secondary-os-of-linux
More details on how to check your install are in this article:
http://www.intel.com/content/www/us/en/cloud-computing/quicksync-video-ffmpeg-install-valid.html
