3088 Discussions
Valgrind shows memory leak in Simple_decode/Transcode . on NUC(D54250WYKH) machine
sumit_j_1
Hi All,
I  am working with  one of the H264 stream available at http://download.openbricks.org/sample/H264/big_buck_bunny_480p_H264_AAC_25fps_1800K_short.MP4/  and used  Elecard Software to  extract H264 stream.
I used Valgrind  for Decode and Transcode and seeing many occurrences  of Invalid read of size 4/ Invalid write of size 8. Also significant number of bytes are lost.
Valgrind Commad- valgrind  --leak-check=full --show-leak-kinds=all  --log-file=/tmp/ValgrndDecode.txt ...
I have attached Valgrind log for decode and Transcode. Please refer them for more details.
My system config-
$ uname -a
>>Linux NUC 3.10.0-229.1.2.39163.MSSr4.el7.centos.x86_64
CentOs Version
$ cat /etc/centos-release
>>CentOS Linux release 7.1.1503 (Core)
NUC machine-NUC(D54250WYKH) machine
           >> MSDK version --  MediaServerStudioEssentials2015R6
Sumit Jha
Sravanthi_K_Intel
Hi Sumit - Thank you for pointing the memory leaks. We will take a look at them from our end. Were you able to observe similar leaks with sample_decode application as well? (I see the leaks are coming from iHD module and would be common between tutorials ans samples, but I want to be sure).
sumit_j_1
Can  you please share  your  opinion about the invalid memory read/write part as well in the logs?  I mean how you interpret it and  from where it might be coming ?
Do you  think it is a wrong interpretation by memcheck?
Sumit Jha
Sravanthi_K_Intel
Hi Sumit - Apologies for the delayed response. Most of the invalid reads and writes are coming from the iHD driver module which is a closed source driver and other libraries. Although I do not have much to offer immediately, I have escalated this behavior to get some information on this - I will get back to you as soon as I have something to share.
Rajarshi_H_
Hi Sravanthi,
I am getting same "Invalid read/write" while running sample decode or sample_decvpp,
As you have mentioned in your earlier posts' that these errors are due to the iHD driver.Same is the issue here.
Kindly suggest how can it be rectified.
Thanks in advance!!
Br,
Rajarshi Haldar
+919958767381
Surbhi_M_Intel
Hi Rajarshi,
Can you please start a new thread for the issue you have reported above, this help us to track the customer and their issues properly.
Also please send machine details - CPU, GPU, OS, media server studio version, samples version and o/p of cmd "unamke -r" and o/p of result of running pre build binaries, part of the package.
Surbhi
