3076 Discussions
gstreamer and msdk: unable to allocate memory error when running pipeline
vandanachadha
installed msdk skylake card and gstreamer after that with msdk enabled. The sample tests for intel run fine.
Howwever, i get an out of memory error when running foll gstreamer pipeline for filesrc
LD_LIBRARY_PATH=/usr/local/lib:/opt/intel/mediasdk/lib gst-launch-1.0 -v --gst-debug-no-color=1 filesrc location=~/sample_videos/big_buck_bunny_720p_2mb.mp4 ! decodebin name=demux demux. ! queue ! audioresample ! audioconvert ! avenc_aac bitrate = 128000 ! queue ! mpegtsmux bitrate=3000000 alignment=7 name=mux ! filesink location=dvb_msdk_out_210308.mp4 demux. ! queue ! msdkh264enc i-frames=60 b-frames=4 bitrate=1200 frame-packing=-1 ! video/x-h264,stream-format=byte-stream,profile=main ! mux.
gst-launch output
libva info: VA-API version 1.11.0
libva info: User environment variable requested driver 'iHD'
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so
libva info: Found init function __vaDriverInit_1_11
libva info: va_openDriver() returns 0
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
Got context from element 'msdkh264enc0': gst.msdk.Context=context, gst.msdk.Context=(GstMsdkContext)"\(GstMsdkContext\)\ msdkcontext1";
/GstPipeline:pipeline0/GstDecodeBin:demux/GstTypeFindElement:typefind.GstPad:src: caps = video/quicktime, variant=(string)iso
/GstPipeline:pipeline0/GstDecodeBin:demux/GstTypeFindElement:typefind.GstPad:src: caps = NULL
/GstPipeline:pipeline0/GstDecodeBin:demux/GstMultiQueue:multiqueue0.GstMultiQueuePad:src_0: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, level=(string)3.1, profile=(string)main, codec_data=(buffer)014d401fffe10017674d401fda014016ec0440000003004000000c83c60ca801000468ef3c80, width=(int)1280, height=(int)720, framerate=(fraction)25/1, pixel-aspect-ratio=(fraction)1/1
/GstPipeline:pipeline0/GstDecodeBin:demux/GstH264Parse:h264parse0.GstPad:src: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, level=(string)3.1, profile=(string)main, codec_data=(buffer)014d401fffe10017674d401fda014016ec0440000003004000000c83c60ca801000468ef3c80, width=(int)1280, height=(int)720, framerate=(fraction)25/1, pixel-aspect-ratio=(fraction)1/1, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
Redistribute latency...
/GstPipeline:pipeline0/GstDecodeBin:demux/avdec_h264:avdec_h264-0.GstPad:sink: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, level=(string)3.1, profile=(string)main, codec_data=(buffer)014d401fffe10017674d401fda014016ec0440000003004000000c83c60ca801000468ef3c80, width=(int)1280, height=(int)720, framerate=(fraction)25/1, pixel-aspect-ratio=(fraction)1/1, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
/GstPipeline:pipeline0/GstDecodeBin:demux/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, level=(string)3.1, profile=(string)main, codec_data=(buffer)014d401fffe10017674d401fda014016ec0440000003004000000c83c60ca801000468ef3c80, width=(int)1280, height=(int)720, framerate=(fraction)25/1, pixel-aspect-ratio=(fraction)1/1, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
/GstPipeline:pipeline0/GstDecodeBin:demux/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, level=(string)3.1, profile=(string)main, codec_data=(buffer)014d401fffe10017674d401fda014016ec0440000003004000000c83c60ca801000468ef3c80, width=(int)1280, height=(int)720, framerate=(fraction)25/1, pixel-aspect-ratio=(fraction)1/1, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
/GstPipeline:pipeline0/GstDecodeBin:demux/GstH264Parse:h264parse0.GstPad:sink: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, level=(string)3.1, profile=(string)main, codec_data=(buffer)014d401fffe10017674d401fda014016ec0440000003004000000c83c60ca801000468ef3c80, width=(int)1280, height=(int)720, framerate=(fraction)25/1, pixel-aspect-ratio=(fraction)1/1
/GstPipeline:pipeline0/GstDecodeBin:demux/GstMultiQueue:multiqueue0.GstMultiQueuePad:src_1: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)4, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)11b0, rate=(int)48000, channels=(int)6, channel-mask=(bitmask)0x0000000000000000
/GstPipeline:pipeline0/GstDecodeBin:demux/avdec_aac:avdec_aac0.GstPad:sink: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)4, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)11b0, rate=(int)48000, channels=(int)6, channel-mask=(bitmask)0x0000000000000000
/GstPipeline:pipeline0/GstDecodeBin:demux/GstAacParse:aacparse0.GstPad:src: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)4, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)11b0, rate=(int)48000, channels=(int)6, channel-mask=(bitmask)0x0000000000000000
/GstPipeline:pipeline0/GstDecodeBin:demux/GstAacParse:aacparse0.GstPad:sink: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)4, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)11b0, rate=(int)48000, channels=(int)6, channel-mask=(bitmask)0x0000000000000000
/GstPipeline:pipeline0/GstDecodeBin:demux/GstMultiQueue:multiqueue0: max-size-buffers = 5
/GstPipeline:pipeline0/GstDecodeBin:demux/GstMultiQueue:multiqueue0: max-size-time = 0
/GstPipeline:pipeline0/GstDecodeBin:demux/GstMultiQueue:multiqueue0: max-size-bytes = 2097152
/GstPipeline:pipeline0/GstDecodeBin:demux/GstMultiQueue:multiqueue0.GstMultiQueuePad:sink_0: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, level=(string)3.1, profile=(string)main, codec_data=(buffer)014d401fffe10017674d401fda014016ec0440000003004000000c83c60ca801000468ef3c80, width=(int)1280, height=(int)720, framerate=(fraction)25/1, pixel-aspect-ratio=(fraction)1/1
/GstPipeline:pipeline0/GstDecodeBin:demux/GstMultiQueue:multiqueue0.GstMultiQueuePad:sink_1: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)4, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)11b0, rate=(int)48000, channels=(int)6, channel-mask=(bitmask)0x0000000000000000
/GstPipeline:pipeline0/GstDecodeBin:demux/avdec_aac:avdec_aac0.GstPad:src: caps = audio/x-raw, format=(string)F32LE, layout=(string)non-interleaved, rate=(int)48000, channels=(int)6, channel-mask=(bitmask)0x000000000000003f
/GstPipeline:pipeline0/GstDecodeBin:demux/avdec_h264:avdec_h264-0.GstPad:src: caps = video/x-raw, format=(string)I420, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, framerate=(fraction)25/1
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:sink: caps = audio/x-raw, format=(string)F32LE, layout=(string)non-interleaved, rate=(int)48000, channels=(int)6, channel-mask=(bitmask)0x000000000000003f
/GstPipeline:pipeline0/GstQueue:queue2.GstPad:sink: caps = video/x-raw, format=(string)I420, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, framerate=(fraction)25/1
/GstPipeline:pipeline0/GstDecodeBin:demux.GstDecodePad:src_0.GstProxyPad:proxypad2: caps = video/x-raw, format=(string)I420, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, framerate=(fraction)25/1
/GstPipeline:pipeline0/GstAudioResample:audioresample0.GstPad:src: caps = audio/x-raw, format=(string)F32LE, layout=(string)non-interleaved, rate=(int)48000, channels=(int)6, channel-mask=(bitmask)0x000000000000003f
/GstPipeline:pipeline0/GstAudioConvert:audioconvert0.GstPad:src: caps = audio/x-raw, rate=(int)48000, channels=(int)6, format=(string)F32LE, layout=(string)interleaved, channel-mask=(bitmask)0x000000000000003f
/GstPipeline:pipeline0/avenc_aac:avenc_aac0.GstPad:sink: caps = audio/x-raw, rate=(int)48000, channels=(int)6, format=(string)F32LE, layout=(string)interleaved, channel-mask=(bitmask)0x000000000000003f
/GstPipeline:pipeline0/GstAudioConvert:audioconvert0.GstPad:sink: caps = audio/x-raw, format=(string)F32LE, layout=(string)non-interleaved, rate=(int)48000, channels=(int)6, channel-mask=(bitmask)0x000000000000003f
/GstPipeline:pipeline0/GstAudioResample:audioresample0.GstPad:sink: caps = audio/x-raw, format=(string)F32LE, layout=(string)non-interleaved, rate=(int)48000, channels=(int)6, channel-mask=(bitmask)0x000000000000003f
/GstPipeline:pipeline0/avenc_aac:avenc_aac0.GstPad:src: caps = audio/mpeg, channels=(int)6, rate=(int)48000, mpegversion=(int)4, base-profile=(string)lc, framed=(boolean)true, stream-format=(string)raw, channel-mask=(bitmask)0x000000000000003f, level=(string)4, profile=(string)lc, codec_data=(buffer)11b056e500
/GstPipeline:pipeline0/GstQueue:queue1.GstPad:sink: caps = audio/mpeg, channels=(int)6, rate=(int)48000, mpegversion=(int)4, base-profile=(string)lc, framed=(boolean)true, stream-format=(string)raw, channel-mask=(bitmask)0x000000000000003f, level=(string)4, profile=(string)lc, codec_data=(buffer)11b056e500
/GstPipeline:pipeline0/GstMpegTsMux:mux.GstBaseTsMuxPad:sink_0: caps = audio/mpeg, channels=(int)6, rate=(int)48000, mpegversion=(int)4, base-profile=(string)lc, framed=(boolean)true, stream-format=(string)raw, channel-mask=(bitmask)0x000000000000003f, level=(string)4, profile=(string)lc, codec_data=(buffer)11b056e500
/GstPipeline:pipeline0/GstMsdkH264Enc:msdkh264enc0.GstPad:sink: caps = video/x-raw, format=(string)I420, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, framerate=(fraction)25/1
ERROR: from element /GstPipeline:pipeline0/GstDecodeBin:demux/avdec_h264:avdec_h264-0: Unable to allocate memory
Additional debug info:
../subprojects/gst-libav/ext/libav/gstavviddec.c(955): gst_ffmpegviddec_get_buffer2 (): /GstPipeline:pipeline0/GstDecodeBin:demux/avdec_h264:avdec_h264-0:
The downstream pool failed to allocated buffer.
ERROR: pipeline doesn't want to preroll.
Setting pipeline to NULL ...
Freeing pipeline ...
