3075 Discussions
why gstreamer not working with mfxdecoder and using samples of media sdk video playing very fast anf flickering also ?
satinder_s_
Hi ,
I am working on media sdk and I successfully installed media sdk on linux and I also installed intel media sdk with gstreamer . But gstreamer can not play a single video . Gstreamer giving following error every time :
gst_vaapi_decoder_parse assertion decoder != NULL failed
But using samples of media sdk I am able to play ES stream but that is play very fast when I am using -hw option , for -sw that is playing smooth . But I wanna play using -hw and I also wanna play other video formats so What I can do in that situation ?
following are main issues :
Gstreamer is not working
media sdk -hw very fast and flickering
Seunghyuk_P_Intel
We need more information to investigate your issue.
Could you give answers following questions?
* Platform, OS, MediaSDK version,
* Have you tried through gstreamer command line testing with "gst-launch-1.0"?
* Could you attach one of your ES?
* And if OS is linux, please collect "$ vainfo" output.
Peter.
satinder_s_
Hi ,
OS : Ubuntu
Media SDK have latest version
Yes I am trying command line and getting error like above I mentioned .
Yes I tried both gst-launch and gst-play both giving error like above .
Yes I already collection output of vainfo that is following :
libva info: VA-API version 0.99.0
libva info: va_getDriverName() returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /usr/lib/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
libva info: va_openDriver() returns 0
vainfo: VA-API version: 0.99 (libva 1.67.0.pre1)
vainfo: Driver version: 16.7.60601-production
vainfo: Supported profile and entrypoints
      VAProfileH264Main               :    VAEntrypointVLD
      VAProfileH264Main               :    VAEntrypointEncSlice
      VAProfileH264Main               :    <unknown entrypoint>
      VAProfileH264High               :    VAEntrypointVLD
      VAProfileH264High               :    VAEntrypointEncSlice
      VAProfileH264High               :    <unknown entrypoint>
      VAProfileH264ConstrainedBaseline:    VAEntrypointVLD
      VAProfileH264ConstrainedBaseline:    VAEntrypointEncSlice
      VAProfileH264ConstrainedBaseline:    <unknown entrypoint>
      VAProfileMPEG2Simple            :    VAEntrypointVLD
      VAProfileMPEG2Main              :    VAEntrypointVLD
      VAProfileVC1Advanced            :    VAEntrypointVLD
      VAProfileVC1Main                :    VAEntrypointVLD
      VAProfileVC1Simple              :    VAEntrypointVLD
      VAProfileJPEGBaseline           :    VAEntrypointVLD
      VAProfileJPEGBaseline           :    VAEntrypointEncPicture
      VAProfileVP8Version0_3          :    VAEntrypointVLD
      VAProfileVP8Version0_3          :    VAEntrypointEncSlice
      VAProfileHEVCMain               :    VAEntrypointVLD
      VAProfileHEVCMain               :    VAEntrypointEncSlice
      VAProfileHEVCMain10             :    VAEntrypointVLD
      VAProfileVP9Profile0            :    VAEntrypointVLD
      VAProfileVP9Profile0            :    <unknown entrypoint>
      VAProfileNone                   :    VAEntrypointVideoProc
      VAProfileNone                   :    <unknown entrypoint>
Please response as soon as possible .
satinder_s_
Actually I wanna use gstreamer for play ts file because media sdk only works on es .
Ishmael_Sameen
Can you remove gstreamer vaapi from your system? It should be in your LDPATH (libgstvaapi.so.x.xx)
satinder_s_
ok , I did not remove but I think we can remove it .
satinder_s_
I did not find and locate libgstvaapi.so.x.xx , So please let me know I can do now , Please help asap.
Seunghyuk_P_Intel
Hi Satinder,
It seems like you are using Media server sdk.
Its gold bkc is CentOS.
I know that it's tough to enable Media SDK in Ubuntu.
I have some suggestions.
1. Can you verify Media SDK operation with Media SDK samples here?
    - https://software.intel.com/en-us/intel-media-server-studio-support/code-samples
    If every tweak was correct and Media SDK is working good basically, these samples should be working also.
    You can just try sample_encode and sample_decode.
2. About elementary stream you are using,
    Is this output from Media SDK?
    if not, why don't you create sample from Media SDK and use for now?
Peter.
