- Email to a Friend
Hi everybody,
I am new on forums. I wanted to do a DMA with a StratixIV on a CentOS 6.5 in C with a driver. So to start, I search how to enable, set and configure the pci device. Which I did (with pci_enable, ...). I succeed to write in the virtual address provide by the BAR0 (pci_iomap). Then I wanted to make a DMA between the cpu and the Fpga ram, so I searched how to allocate and use a Dma buffer, thanks of the function dma_alloc_coherent. But among all the documentation I read, it didn't mention how to start / launch the dma. So I have a virtual address (provided by dma_alloc_coherent) and if I wrote in it it's very fast. For example to copy a file of 100 Mo. I concluded I was in the local RAM. Maybe I do a step wrong so do you have some explanations about the step of the dma ? I read a lot of free electron source and the DMA-API.txt. My BAR 0 has 256 MB. Thank you for your help. SincerelyLink Copied
Topic Options
