When I look in the manual it says that serial connection should work but when I try to run the program it is not working and not even code formatting in the Nios 2 IDE works.
/* A simple program that recognizes the characters 't' and 'v' */# include <stdio.h># include <string.h>
int main ()
char* msg = "Detected the character 't'.\n";
FILE* fp;
char prompt = 0;
fp =fopen("/dev/uart1", "r+"); //Open file for reading and writing
if (fp)
while (prompt != 'v')
{ // Loop until we receive a 'v'.
prompt = getc(fp); // Get a character from the JTAG UART.
if (prompt == 't')
{ // Print a message if character is 't'.
fwrite (msg, strlen (msg), 1, fp);
if (ferror(fp))// Check if an error occurred with the file pointer
clearerr(fp);// If so, clear it.
fprintf(fp, "Closing the JTAG UART file handle.\n");
fclose (fp);
return 0;
Chapter 6 in the Embedded Peripherals IP... says that this code should work but it doesn't.
Topic Options
