12620 Discussions
Interrupt Nios II RS232 / Usart
Hello!
I am trying to use the rs232 interrupt. sending and receiving data works fine, but when i try to use the interrupt to receive data I get some problems.
this is the rs232 block in my system.h
* uart_rs232 configuration
# define UART_RS232_NAME "/dev/uart_rs232"
# define UART_RS232_TYPE "altera_avalon_uart"
# define UART_RS232_BASE 0x0a201280
# define UART_RS232_SPAN 32
# define UART_RS232_IRQ 18
# define UART_RS232_IRQ_INTERRUPT_CONTROLLER_ID 0
# define UART_RS232_BAUD 9600
# define UART_RS232_DATA_BITS 8
# define UART_RS232_FIXED_BAUD 0
# define UART_RS232_PARITY 'N'
# define UART_RS232_STOP_BITS 1
# define UART_RS232_SYNC_REG_DEPTH 2
# define UART_RS232_USE_CTS_RTS 0
# define UART_RS232_USE_EOP_REGISTER 0
# define UART_RS232_SIM_TRUE_BAUD 0
# define UART_RS232_SIM_CHAR_STREAM ""
# define UART_RS232_RELATIVEPATH 0
# define UART_RS232_FREQ 100000000
# define ALT_MODULE_CLASS_uart_rs232 altera_avalon_uart
//this is my context
typedef struct
int number;
}my_context;
//This is my ISR
void rs232_isr (void* context, alt_u32 interrupt_number)
printf("data gets in");
//this I call in my main at first
void main(){
char msg[4]="test";
int result;
result=alt_irq_register (UART_RS232_IRQ,
(void*)my_contex,
rs232_isr);
alt_irq_enable(UART_RS232_IRQ);
do{
fp = fopen("/dev/uart_rs232", "w+");
if(fp)
//printf("Connected\n");
fwrite(msg, strlen(msg), 1, fp);
//fprintf(fp, "Closing the UART file.\n");
fclose(fp);
else
printf("Error/dev/ttyS0\n");
}while(1);
If I start the my program the rs232_isr is called I think one hundred times...
I think the rs232_isr is called by the fwrite(..). Is there a method to recognize only the RXD without react everytime at TXD (text send).
Nobody who van help me?
check this thread.
http://www.alteraforum.com/forum/showthread.php?t=13134
It contains also some code samples how to do it.
I red the other thread and now my isr works, but now the write function does not work..nothing is send, only the RXD comes
volatile int counter;
init RXD
/* flush any characters sitting in the holding register */
IORD(UART_RS232_BASE, 0);
/* reset most of the status register bits */
IOWR(UART_RS232_BASE, 2, 0x00);
/* install IRQ service routine */
alt_irq_register(UART_RS232_IRQ, 0, serial_irq_0);
/* enable irq for Rx. */
IOWR(UART_RS232_BASE, 3, 0x0080);
The ISR is so:
static void serial_irq_0(void* context , alt_u32 id)
unsigned int stat,temp;
int chr[3];
// message[0]=getc(fp_read);
/* get serial status */
stat = IORD(UART_RS232_BASE, 2);
/* character Rx */
if (stat & 0x0080) {
message [counter]= IORD(UART_RS232_BASE, 0);
if(counter==2){
printf("char: %c%c%c",message[0],message[1],message[2]);
counter=0;
else
counter++;
In a Task I wrote this to write:
FILE *fp_write;
fp_write = fopen("/dev/uart_rs232", "w+"); //also used r+
if(fp_write)
//printf("Verbunden\n");
fwrite(pic_viewer->message, strlen(pic_viewer->message), 1, fp_write);
OSTimeDlyHMSM(0, 0, 0, (20));
//fwrite(msg,strlen(msg),1,fp);
//sprintf(msg,"%i",400);
//fwrite(msg, strlen(msg),1,fp);
fclose(fp_write);
sprintf(pic_viewer->message,"%s","00050200");
else
I am not really sure about your code.
I would guess message[] is a receive buffer but ...
Are you using a mix of standard lib and your own code on the same RS232?
I strictly separated then and have no trouble.
