I connected a counter pin to the PIO in order to generate IRQ every 256 cycles. Appropriate IRQ handler is called after the interrupt triggers. However, after handling the interrupt, the alt_irq_handler stays in the loop because ipending is still set. So, how shall I clear the interrupt request ? Best regards, JoelLink Copied
problem solved
Can you please write how you solved the problem? thanks- Mark as New
In the handler routine reset the edge register by writing 0 to it or ones ( ones didnt work for me but the manual states it) in dependence of PIO configuration.
regards- Mark as New
thank you :)
