I just purchased the Microtronix OpenCore Ethernet solution. They include example projects, but they are not complete, as in you can't click on the CPU (SOPC builder) and see how they configured it! Anyway, the project loads, and the kernel builds without errors, but when you run uClinux, the Ethernet device does not exist! (I'm including the Igor Ethernet Device drivers) Does anyone have some advice? Or can someone send me a project that works, that I can look at the SOPC builder? Thank you very much RandyLink Copied
To see the SOPC Builder configuration for these projects, select "SOPC Builder..." from the "Tools" menu in Quartus II.
Dennis Scott Microtronix Datacom Ltd.- Mark as New
Thank you! I never accesed the SOPC builder that way. That worked great, building the project (in Quartus) right now. I will see if I can get the Igor Mac to work properly then. We will see.
Randy- Mark as New
Once you rebuild the SOPC Builder part, you should be able to re-access it with the usual double-click on the block. It doesn't work the first time due to our stripping out of most of the project files to keep the distribution as small as possible.
