NIOS II SBT problem
Hi all,
I am using NIOS II SBT v11.0.I am not able to create new project in NIOS II SBT.Every time I am getting "Failed to execute ./create-this -app --no make." error and I am not able to create new project.When I import old projects and debug then it got stuck in altera_spi.c file.
Could somebody please tell me how to get rid from this error?
I have uninstalled the Quartus v11.0 and reinstall it.But Error is same.
Krupesh.
Same problem for me
Hi all,
I have figured out one possible solution of the issue.I am using Windows7 and I haven't selected Windows7 under compatibility mode.To select it follow the procedure.
Right Click on Nios II 11.1 Software Build Tools and select properties.
Select Compatibility tab.
Select Windows7 under Compatibility mode.
Restart PC.
I hope this will help you.
Krupesh.
Also try right click on niosII icon and execute it in administrator mode.
be lucky.
