12612 Discussions
NIOS V/g version 1.0 vs 2.0 Atomic instruction
tcmichals_home
Using NIOS/g 1.0  the following code works:
00001604: lw a5,-20(s0)
00001608: lw a4,-24(s0)
0000160c: fence iorw,ow
00001610: amoswap.w.aq zero,a4,(a5)
Using NIOS/g 2.0 an exception occurs when 1610 executes, amoswap.   The mcause register value is 2, stating it is an illegal instruction.
Recompile the code, did not fix issue.  Validated the memory location is accessible.
According to the web site, A (atomic instructions should be supported).    The API C/C++ API is std::atomic<uint32_t>  value being updated.
_GLIBCXX_ALWAYS_INLINE void
store(__int_type __i, memory_order __m = memory_order_seq_cst) noexcept
memory_order __b __attribute__ ((__unused__))
= __m & __memory_order_mask;
__glibcxx_assert(__b != memory_order_acquire);
__glibcxx_assert(__b != memory_order_acq_rel);
__glibcxx_assert(__b != memory_order_consume);
__atomic_store_n(&_M_i, __i, int(__m)); <--- the function calling the fence/swap
   From https://www.intel.com/content/www/us/en/docs/programmable/683632/23-4/processor-73511.html the processor should support Atomic instructions.  Version 1.0 did.
Tim
tcmichals_home
OK, looking see link:
  • RV32IAZicsr (Pipelined) & RV32IZicsr (Non-Pipelined)
Another web has:
 States:
  • Pipelined
    • Applies RV32IZicsr instruction set.
    • Supports five-stages pipeline datapath.
  • Non-pipelined
    • Supports non-pipeline datapath.
This post is having the same issue
So, Atomic is not supported?  Or is it?
tcmichals_home
according to the toolchain.cmake generated by niosv-bsp-editor  there is -march=rv32ia  this should be rv32i if the processor does not support Atomic.  Using this option the code now works.
Kevin26
That's what I changed also but your original question about does the RISC V/m Pipelined and RISC V/g support atomic instructions is still valid.  The documentation says it should.
EBERLAZARE_I_Intel
Let me quick check with our internal team.
EBERLAZARE_I_Intel
Unfortunately, our Nios V currently does not support Atomic instruction yet.
I will channel this to our internal team as feedback request.
Is there any other questions from your side?
tcmichals_home
Issue resolved.
niosv-bsp-editor needs to be updated to remove atomic support from compiler option
EBERLAZARE_I_Intel
Thank you for your feedback, I will check that out and send this feedback to our internal team as feedback request to make the proper changes.
EBERLAZARE_I_Intel
Thanks for your feedback, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
