12606 Discussions
NIOS V/m SC.W instruction generating Illegal Instruction Exception
Kevin26
I have ported the RTEMS RTOS over to the NIOS V/m processor.  During a context switch, there is a dummy sc.w instruction to clear any reservations.  When this instruction is executed, an illegal instruction exception occurs.  After reading the processor reference guide, I don't see anywhere that would say this is a problem.  Is the SC instruction illegal in the NIOS V/m processor?
JingyangTeh
Hi Kevin
Have you considered using FreeRTOS instead of RTEM RTOS?
Unfortunately we do not officially support RTEM RTOS but however maybe we could figure it out here.
Could you share the error message that you are seeing?
Jingyang, Teh
Kevin26
I'm not receiving an error message.  I'm just getting an illegal instruction exception when the NIOS V/m is trying to execute a sc.w instruction.  I just need to know whether the NIOS V/m supports the LR/SC instructions and if so why would the NIOS V/m generate the exception.
JingyangTeh
Hi Kevin
If you are running LR/SC instruction, the instruction set is part of the Atomic extension set for RiscV.
Sorry to inform that it is removed from NiosV, and it is the cause of the illegal instruction message that you are seeing now.
For now there is no plan to add in the RiscV Atomic extension into for NiosV.
Jingyang, Teh
Kevin26
That makes sense now.  I just upgraded to Quartus Prime Lite 23.1 when this started happening.  I think in 22.1, the atomic instructions were supported.
JingyangTeh
Hi
Sorry for the confusion the Atomic extension have just recently removed and they have not updated the webpage on this.
Please refer the release note and the Reference Manual below:
Release Note
https://www.intel.com/content/www/us/en/docs/programmable/683098/23-1std/processor-v2-0-0-89647.html
Reference Manual
3. Nios® V/m Processor (intel.com)
Jingyang,Teh
JingyangTeh
Hi
Any more follow up question for this case?
If no, could i close the case?
Jingyang, Teh
JingyangTeh
Hi
Since this thread been resolve, I shall set this thread to close pending. If you still need further assistance, you are welcome to reopen this thread within 20days or open a new thread, some one will be right with you. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 4 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
