12612 Discussions
Nios II+uClinux frambuffer in single SDRAM
Hi All,
I am intending to run uclinux on NIOS 2/f on cyclone 3 fpga. I have one SDRAM 32MB connected to the cyclone 3.
The system is connected to CCD sensor, I would like video to be streamed to another computer via ethernet.
I have seen couple of IP camera design solutions that use 2 SDRAMs (1 for ucLinux, 1 for frame buffer). I woundn't want this approach as I have space and IO constraints to go with 2 SDRAMs on the board.
Would it be possible to run both uclinux (nios 2) and frame buffer on the same SDRAM?
Highly Appreciate any pointers.
Thank you
--- Quote Start ---
--- Quote End ---
Maybe, it's possible. But please be careful about the bus bandwidth. Also you may need a special frame buffer driver.
Kazu
