12517 Discussions
Programming NIOSII interfaced with custom component, using Avalon MM Interface
Hello Everyone,
I am trying to interface NIOS II with a custom component using Avalon MM Inferface where NIOS acts as Master.
During the C coding, how do i get access to the function to send/receive data through the Avalon MM interface ?
Can i get direct access to the ports dedicated for the interface ? and Do i need to follow some particular protocol while C coding for the interface ?
I implemented 16 Bit 128 Tap FIR Filter with two approach:
First with implementing the FIR on NIOS II core using C language (Software FIR Design).
Second with implementing FIR as Hardware Accelerator on FPGA which get i/p values & coeff from NIOS II core and returns the the result to NIOS II core (Hardware FIR Design).
Below are the links to project. Hope it helps.
Software FIR Design:
https://www.youtube.com/watch?v=sjjbu-lhzpc
Hardware FIR Design:
https://www.youtube.com/watch?v=-egwtmwg0ku
Hello everyone
I need to sent 5 different 16 bits data in 5 five clock cycles to my costum component.
My Altera board is driven by a 50MHz oscillator (a period of 0.02 µs).
so should I write
IOWR_16DIRECT(BASE , OFFSET, DATA_1);
usleep(0.02);
IOWR_16DIRECT(BASE , OFFSET, DATA_2);
usleep(0.02);
IOWR_16DIRECT(BASE , OFFSET, DATA_5);
--- Quote Start ---
I succeeded in implementing the system on board. My custom component is a 128 tap FIR filter which is to be started by NIOS and stimuli is also provided by nios. I made the custom component in Qsys and implemented the system.
Now i am able to write the c code successfully on the NIOS without any tool errors.
But, i am not able to communicate properly. Below is my code:
int var =1234;
IOWR(20496,0,11);
printf("%d\n",var); //prints 1234
var = IORD(20496,0);
printf("%d\n",var); // prints 0
When I am reading the same address and offset, it gives 0.
--- Quote End ---
HI,
I'm currently facing the issues as mentioned in the quote above.
May I know the way you resolve it?
HY
