Perhaps a novice question, but after ugrading my QuartusII installation to version 5.1 (build 176), my old and previously working Nios II projects fails to compile. Any other that has experienced the same problems?
Not sure how to answer without more data. What is the compilation error? Was it HW or SW that did not compile? Did you try installing 5.1 on a virgin platform? -Baycool- Mark as New
If you update to Quartus 5.1, you'll have to update to Nios II 5.1, as well.
Cheers, - slacker
