Hello all,
I am having some difficulties with the TSE MAC in uClinux with MMU. I am working on Terasic DE4 board, with "unstable-nios2mmu" in linux-2.6 and "trunk" in uClinux-dist. All folders are updated with the update script. I am able to boot the uclinux correctly with my base system, having a ddr2 controller. My next step is to add the tse mac, sgdma-tx, sgdma-rx and descriptor memory for networking. In uClinux configuration (#make menuconfig), I check the Marvell Phy Support and TSE Drivers (SLS). The uClinux compiles and boots, however when I check the networking devices (#ifconfig), the only device is lo; there is no eth0 device. I made no changes on arch/nios2/include/asm/nios.h. Do I need to define a new variable? What if I have multiple TSE instances, then? I don't blame it on my sopc system, at the moment, but more on the configuration I have in uClinux. Any ideas will be appreciated. Kind Regards, TurhanLink Copied
when it starts run on linux
ifconfig eth0 "ip, f.e 192.168.0.1" up you may need to define a mac adress also- Mark as New
Thanks Aprado for your response, however eth0 cannot be configured since it is not on the ifconfig list.
When I try to set the Mac address or the IP address# ifconfig eth0 192.168.0.1 up , the response is: ifconfig: SIOCSIFADDR: No such device All the best, Turhan- Mark as New
Are you using the device tree method as specified at http://www.alterawiki.com/wiki/devicetree? For now you will need to manually add two properties to the TSE MAC entry in the dts file, so the driver is able to find the PHY. The final entry should look something like this (values may vary depending on your SOPC design):
tse_mac: ethernet@0x8002400 {
compatible = "ALTR,tse-9.1","ALTR,tse-1.0";
reg = < 0x8002400 0x400 0x8100000 0x40 0x8200000 0x40 0x4840000 0x2000>;
interrupt-parent = < &cpu_0 >;
interrupts = < 4 5 >;
ALTR,rx-fifo-depth = <1024>; //embeddedsw.CMacro.RECEIVE_FIFO_DEPTH type NUMBER
ALTR,tx-fifo-depth = <1024>; //embeddedsw.CMacro.TRANSMIT_FIFO_DEPTH type NUMBER
address-bits = <48>;
max-frame-size = <1518>;
local-mac-address = ;
ALTR,mii-id = <0>; // manually added
ALTR,phy-addr = <2>; // manually added
}; //end ethernet (tse_mac)
I cannot thank you enough Tobias. I see now why the devices were not recognized before.
Yes, I use the devicetree method. Could you please explain how do I obtain the values for mii-id and phy addr? The only value with a similar name in SOPC is the PHY ID in SGMII options for the TSE component. I can see that this would work with multiple TSEs and PHYs. How would this affect the mii-id and phy-addr values? Thank you very much, Regards, Turhan- Mark as New
On (http://comments.gmane.org/gmane.linux.uclinux.nios2.devel/10), in your discussion with Walter, you have stated that phy-addr is optional. When I tried to use mii-id only, the linux boots and I have the eth0 recognized.
When I run# ifconfig eth0 hw ether 00:11:22:33:44:55 the mac address is set without problems. Then I run# ifconfig eth0 10.0.1.37 skb_over_panic: text:d016ef48 len:65533 put:65533 head:df36e800 data:df36e822 tail:0xdf37e81f end:0xdf36ee20 dev:eth0 BUG: failure at /home/user/Desktop/linuxonAltera/nios2-linux/linux-2.6/net/core/skbuff.c:128/skb_over_panic()! Kernel panic - not syncing: BUG! Is this because I don't have phy-addr variable in dts, or caused by another problem? Have you ever seen such an error before?- Mark as New
Tuhran
The phy-addr is determined by which phy you are using. For the Tarasic DE-4 this is hardwired and mapped as follows (see the schematic): Ethernet 0 is phy-addr 0 Ethernet 1 is phy-addr 1 Ethernet 2 is phy-addr 2 Ethernet 3 is phy-addr 3 If you don't specify a phy-addr I think the driver will go search all 32 addresses for attached phys. When I created my CPU design, I used the terasic update portal example to get the ALTERA-TSE settings and connections. This uses the SGMII PCS core variation. Also, the DE4 has the phys connected to the MAC using SGMII. Currently the altera tse driver has the phy interface mode hardcoded, so a little change to the source is required: go to linux-2.6\drivers\net\altera_tse.c In init_phy changeiface = PHY_INTERFACE_MODE_RGMII
to iface = PHY_INTERFACE_MODE_SGMII
also, the PCS variation of the core uses MDIO space 0 for PCS functions, so you must use MDIO space 1 instead to access the phy registers modify altera_tse_mdio_read (note the 1 instead of the 0)
/* set MDIO address */
writel(mii_id, &mac_dev->mdio_phy1_addr);
mdio_regs = (unsigned int *) &mac_dev->mdio_phy1;
and modify altera_tse_mdio_write in the same way
One last important thing of course is that you must have the marvell phy drivers selected in your kernel configuration Cheers Antonie
I wouldn't be able to find out about these myself. Thank you so much. Now, as the linux boots, the phy is listed. Which means I am one step closer.
However, when I# ifconfig eth0 10.0.1.37, I still get the kernel panic message in my previous post. I suspect it might be caused by the descriptor memory size in my system. Do you also have a separate memory for descriptor mem, or do you use ddr2 for that? Also, what is the size of your descriptor memory, if it is separate? Thanks again, Turhan- Mark as New
Currently my design actually has the descriptor memory located either in onchip memory or ddr2, just like the cyclone III evkit reference design for uClinux with MMU. I think that design is available somewhere on the wiki. The only reason to also have the option of using ddr2 is because u-boot currently only uses ddr2 for the descriptor memory but it is not difficult to make u-boot also use the onchip mem for descriptor use too(i think). I have had the design where only an onchip memory of size 8192 bytes is used for descriptor mem and that seemed to work fine in uClinux.
As already pointed out by tones.rsa, the phy-id is optional. If not specified, the driver will autodetect. What is needed though is the correct mii-id. This one is specific to the board hardware you're using.
Currently you'll need to use a distinguished descriptor memory, otherwise the driver won't work. There once was the option to put the descriptor memory into system memory (DDR or whatever) but that went away when device tree support was merged. We'll need to update the altera_tse driver to be able to do this again. Meanwhile I suggest you'd use a separate descriptor memory if possible.- Mark as New
It seems the kernel panic error was my mistake.
After doing the following changes: 1) change descriptor memory size from 2048 to 8192 bytes 2) set the clock domain for each component to 50Hz (no pll output), except ddr2. The ethernet ports are finally working. Cannot thank you enough Tobias and Antonie. Turhan- Mark as New
Now that the system works with one TSE, I try to have multiple TSE instances. The first one initializes correctly during the boot, but the others yield
WARNING: at nios2-linux/linux-2.6/fs/sysfs/dir.c:455 sysfs_add_one+0xb0/0xe0() sysfs: cannot create duplicate filename '/devices/virtual/mdio_bus/0' Modules linked in:... I understand that the TSEs are registered with the same name, but I cannot find out how to prevent that. Thanks.- Mark as New
Did you set a different mii-id in the device tree for the second TSE instance? Unfortunately there are some shortcomings in the driver wrt accessing the PHY from two TSEs via the same MDIO interface.
Thanks Tobias, that solved the problem. I thought all devices were connected to the same mdio interface, but that was not the case. Now things work correctly.
Hello again,
It turns out I was a little too quick to celebrate multiple port functioning correctly. They all function, but not at the same time. I have all eth0, eth1, eth2, and eth3 "installed" at the boot time. ifconfig'ing one port up, and other ports down ensures that one given port will function correctly. However, if multiple ports are up'ped, only the one which has been up'ped the earliest will work. In order to test the functionality I use "ping" command. All 4 clients that are attached to the ports have different IP's (manually set) and the same netmask. I cannot make sure if this is a system/uClinux related question, or more about my limited linux knowledge. Any ideas that pop to your mind? Any suggestions? Thanks. PS: On this link (http://forums.freescale.com/t5/other-microcontrollers/mpc8360e-one-ethernet-device-works-two-doesn-t-work/td-p/25038) the same problem is experienced because of some incorrectly set constants in marvell.c linux/drivers/net/phy. However, these constant names are not available any more.- Mark as New
Try with ping -I or ifconfig eth(x) down in order to get only on eth device up. Regards, Franck.- Mark as New
Thank you very much Franck.
"#ping -I eth(x) IP" did the trick. This means things are OK in terms of the sopc system and uClinux compilation, but there are some problems in terms of networking settings. I have already been doing "#ifconfig eth(x) down" for all the other ports, so that the up'ped one will function correctly. But this is not what I want. I need all ports up'ped. Now I will see if my multi-ethernet client-server code will work correctly. I think I will need "-I" kind of a trick for the bind function. Let's see... =) Thanks again.- Subscribe to RSS Feed
