I am running the update script found in the nios2-linux directory and, among other things, it appears to be updating the tools in toolchain-mmu/x86-linux2/bin but renaming them in the process. Should I use this script to update this distro or should I just use git for updates?
Thanks ahead!Link Copied
use the script, it just calls git. the toolchain naming update is expected.
I thought everything was working properly with the update script but now, my CROSS_COMPILE is still pointing to nios2-wrs-linux-gnu. Where can I change this?
Please try pull in the uClinux-dist directly.
cd uClinux-dist git pull origin trunk Then check if you have the correct vendors/config/nios2/config.arch line 18. - Hippo
Topic Options
