Every time, i try to download the "hello world" - example from the NIOSII IDE, i get the following error message.
***************************************************************** Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused ****************************************************************** I have no idea, whats going wrong, because i can succesful configure my hardware/board with the "standard.sof" file under the examples folder of NIOSII IDE. After i doing that, i start the NIOS IDE, build a new project, based on the "hello world" example and compiled the source code, with no errors. If the USB-Blaster [JTAG] want to download the software, the cpu doesn,t response. In this forum, many other users have the same problem, but i have not fount a detail solution. Is there a bug in the pin assignments of the example file? Please help me. It frustrates me.Link Copied
After i designed my hardware with the SOPC Builder, i get the pins named "n_reset" and "clk". I mapped "clk" to the PIN_N2 location, but what is the setting for the n_reset-signal??? (DE2 Board with a Cyclone II EP2C35F672C6N)
Which standard.sof file are you referring to? I'm not aware of any DE2-based "standard.sof" files. You need to use designs that are actually created (ftp://ftp.altera.com/up/pub/de2/de2_system_v1.5.zip) for the DE2 board. Any other designs will likely fail....in unpredictable (and perhaps) board damaging ways :-)
Cheers, - slacker- Mark as New
..\altera\kits\nios2_60\examples\vhdl\niosII_cycloneII_2c35\standard.sof
This is the system, which i have use and it comes with the nios II ide installing. Next i have try to build my own hardware design: - niosII/e core - jtag_uart - onchip_memory (32kB) for software download But with the same result! --> CPU doesn´t response After i setting up my hardware in the sopc builder, i get a n_reset signal. Which pin / location have i to set for it?- Mark as New
--- Quote Start --- originally posted by tux.2000@Jan 24 2007, 12:23 PM ..\altera\kits\nios2_60\examples\vhdl\niosii_cycloneii_2c35\standard.sof
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20835)
--- quote end ---
--- Quote End --- Right. My point exactly! That design will only function on the Altera Nios II Cyclone II Dev. Boards....not the DE2 board. Use one of the designs from the link I provided in my previous post as a starting point for whatever you're trying to do. At the very least, these designs should have the correct pinout. Best Regards, - slacker
Hi, with the right pin assignment now, all works fine.
Thanks for your help. I am so happy!- Subscribe to RSS Feed
