mk_target_board
I have created a custom board with mk_target_board command as stated under:
"Porting the Nios II Flash Programmer to Custom Boards" of the Nios II Flash Programmer User Guide - document version 1.1
CFI-Flash: AM29DL640D
Target Board: Altera PCI Development Board, Stratix (EP1S25)
I have specified:
address size: 22 bits
data size: 16 bits
but the block diagram shows address size of 23 bits (address[22..0]).
How can I correct this?
If your 29DL640D flash is 16-bit data bus, just use CFI ADDR[1..22] to map to your flash device A[0..21]. Leave CFI ADDR[0] unused.
LiangYi
--- Quote Start ---
originally posted by liangyi@Oct 1 2005, 02:17 AM
hi,
if your 29dl640d flash is 16-bit data bus, just use cfi addr[1..22] to map to your flash device a[0..21]. leave cfi addr[0] unused.
liangyi
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10083)
--- quote end ---
--- Quote End ---
Thanks for your reply
you mean leave cfi_addr[0] from the sopc generated block diagram unconnected?
By the way, do you happen to know what is the setup, wait and hold time for this flash device?
I have setup: 35
wait: 130
hold: 35
Thanks again
> You mean leave cfi_addr[0] from the sopc generated block diagram unconnected?
Yes.
I think the default values are jusk OK. You can try.
LiangYi
